Old 10-31-2009, 10:07 PM   #1 (permalink)
Member Number: 65398
Default 3" o2 housing with custom SEE?
im having a custom 3" SEE put on my car here at a local shop. should i get the 3" 02 housing as well?
joewhitney is offline   Reply With Quote
Old 10-31-2009, 10:16 PM   #2 (permalink)
04SRT_08's Avatar
Member Number: 68190
Trader Rating: (15)
if they are in that area, why not. but i wouldnt do it myself, 02 housings are a bitch(well, heatshield mostly)
'04 SILVER NSRT-4
AGP 50 TRIM @10psi untuned
04SRT_08 is offline   Reply With Quote
Old 10-31-2009, 10:25 PM   #3 (permalink)
what if the heatsheild is already gone would you do it yourself?
Old 10-31-2009, 10:30 PM   #4 (permalink)
hercfe's Avatar
Member Number: 19255
in a heartbeat. bottom heatshield only took 15 minutes to get off. it is tricky, but if you read and reread all the how to's and threads on here about it, you will learn how to do it the right way the first time. its really only a 15 minute job. people just get frustrated and discouraged and then it takes forever.
hercfe is offline   Reply With Quote
Old 11-01-2009, 06:32 AM   #5 (permalink)
SeniorT2005's Avatar
Member Number: 32729
The stock o2 housing of the exhaust is the most restricted place in the exhaust system. Opening it up to 3" is a must for more power.
When the turbo spool's the B.S. ends!!!!
SeniorT2005 is offline   Reply With Quote
Old 11-02-2009, 11:10 AM   #6 (permalink)
red04's Avatar
Member Number: 24993
Trader Rating: (49)
The O2 housing is a pain to install and only worth a minimal gain. I personally wouldn't worry about it.
Scott @ Forward Motion Inc.
302-658-2829
www.forwardmotioninc.com
Email: scott@forwardmotioninc.com
Paypal Address: scott@forwardmotioninc.com
Owner of FM's GT37R powered SRT4 513 whp 469 wtq pump gas (93 octane) @ 6,000 rpms
11.31 @ 131.74 mph w/ 1.90 60'
red04 is offline   Reply With Quote
Old 11-02-2009, 05:42 PM   #7 (permalink)
Sceanzo's Avatar
Member Number: 65430
Anyone care to comment on these? LOL
Sceanzo is offline   Reply With Quote
Old 11-02-2009, 11:54 PM   #8 (permalink)
josh3000GTSRT4's Avatar
Member Number: 70737
Its worth it forsure, while your down there you might as well do it, while your at it hack up the heat shield so its easier to take out with out having to remove the bar and shit, well thats what i did, i just cut the shield into two peices after it was out to make it easier to install and take out, its up to you really.
josh3000GTSRT4 is offline   Reply With Quote
Old 11-03-2009, 02:20 PM   #9 (permalink)
harrydeal's Avatar
Member Number: 18616
in a word yes i would get the 3 in O2 housing. anything to help the car breathe better!
harrydeal is offline   Reply With Quote
Old 11-03-2009, 02:24 PM   #10 (permalink)
GreaseMonkey69's Avatar
Member Number: 43017
Trader Rating: (23)
on a stock turbo 3in o2 housings are great mods! it reduces back pressure and will give you more power and torque.
as for removing and installing O2 housings they are kinda a pain in the ass. i can do it really easy now. getting around the manifold support bracket is a pain, but i usually get a air hammer with a chisel tip and cut it away. (those who don't want it) mos of the time i will cut some of it away to make installing it much easier.
GreaseMonkey69 is offline   Reply With Quote
Old 11-03-2009, 02:51 PM   #11 (permalink)
jessebeachusmc's Avatar
Member Number: 70610
I always read about how hard it is to take off the heatshields but hen I took mine off it took like 20 mins. It wasn't hard at all. I would get the 3" o2 housing, it'll open things up before the dp and it'll also make ur SEE sound a little more ballsy
AGP borg warner s256 powered
jessebeachusmc is offline   Reply With Quote
Page generated in 0.16267 seconds with 13 queries
