3 inch downpipe - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 11-13-2012, 09:07 PM   #1 (permalink)
Member Number: 90397
Default 3 inch downpipe
just purschased a 3 inch downpipe and was wondering is it hard to install them and also if anyone has done it do you have pictures of how you did it ?
oscard93 is offline   Reply With Quote
Old 11-14-2012, 06:42 AM   #2 (permalink)
Fresh Meat Moderator
tunerlover3's Avatar
Member Number: 76568
Its four bolts at the O2 housing and then slipping off the stock downpipe at the exhaust.
Its easy if you are at least somewhat mechanically inclined.
I dont think there is a how to on a downpipe but check in the how to section to see.
Diablo CMR tuner ~Dan~
310HP 436TQ
XXXHP XXXTQ
Old 11-14-2012, 10:51 AM   #3 (permalink)
yea ive been looking for one but couldnt seem to find any
Old 11-14-2012, 11:11 AM   #4 (permalink)
UnseenByYou's Avatar
Member Number: 82495
Its retarded easy. No need for a how to
HTC PH39100 using AutoGuide.C
i swear its stock
UnseenByYou is online now   Reply With Quote
Old 11-14-2012, 11:13 AM   #5 (permalink)
bratz_729's Avatar
Member Number: 75591
^ this, if your not sure just pay someone...
LGL75C using AutoGuide.C
Built Engine: Eagle/ Arias 8.75:1, Dcr strapped, Ported head w/ Crane 18's and Fidanza Gears.
Turbo/Fuel: PTE 6262, DCR dual 044s, -8/-6 line
Mindmelt 101 tuning
Build Thread:
http://www.srtforums.com/forums/f451...-build-617761/
bratz_729 is online now   Reply With Quote
Old 11-14-2012, 11:18 AM   #6 (permalink)
triangles's Avatar
Member Number: 80981
Really simple ill make a how to for you right now
1. Jack up front of car enough so you can get under use jack stands. To support car please.
2. Unplug cat sensor and unscrew it from the cat. Don't get it in dirt or anything I put mine in a rag.
3. Cut downpipe at bend or match up new pipe and mark out where it goes. Then cut there.
4. Top of down pipe there are 4bolts. With nuts I belive 15 mm for stock could be wrong. Mine arnt Orginal anymore.
5. Slide down pipe out and replace with new one. Probably going to need it welded on to stock exhaust with the reducer to stock back. Or if replaceing 3 inch all the way just welded up. And change 02/ downpipr gastket. I do everytime I get it off.
6. Put in o2 sensor you removed and plug back in once tighten down snug.
Tip if you have a smog state.
I had local shop weld on a flange on my 3inch down pipe and stock downpipe and the exhaust pipe where they meet At. So when I need to swap to my stock for emmission I just unbolted. And rebolt takes me 15 mins at Max with a air tool and extensions
05 flame red
bw Stage 3 47lb 20g By Mole'
daily driven
E85
triangles is online now   Reply With Quote
Old 11-14-2012, 11:57 AM   #7 (permalink)
DKING246's Avatar
Member Number: 82074
What's the cutting all about ?
Mopar S3-E85-
DKING246 is offline   Reply With Quote
Old 11-14-2012, 11:58 AM   #8 (permalink)
05OhioSRT's Avatar
Member Number: 89667
Took me maybe 2 hours tops, and most of that time was because the bolts were a pain to get started. It was one of the first things I did, no need for a how to since its four bolts and a O2 sensor. You shouldn't have any problem doing it yourself
05OhioSRT is offline   Reply With Quote
Old 11-14-2012, 01:26 PM   #9 (permalink)
SRTSpade's Avatar
Member Number: 77114
^x2 ?
4 bolts, an O2 sensor, and maybe the power steering oil cooler if you find it gets in your way.
There's no cutting involved.
To know, is to be hated.
SRTSpade is online now   Reply With Quote
Old 11-14-2012, 01:37 PM   #10 (permalink)
05OhioSRT's Avatar
Yeah oscard93, don't cut anything. Should be 4 bolts and a slip joint on the other end, shouldn't need any cutting
Old 11-14-2012, 01:43 PM   #11 (permalink)
Ridin59vette's Avatar
Member Number: 86347
I think He said Cut it Because he had a flange welded on his
04 SRT-4: Under Construction
99 9-3: Daily Driver
FS Thread:
http://www.srtforums.com/forums/f416...5/#post9777568
Ridin59vette is online now   Reply With Quote
Old 11-14-2012, 01:50 PM   #12 (permalink)
dvoratexn's Avatar
Member Number: 52343
The slip joint or pin needs to be paid attention to. Make sure you have someone hold it with pliers when unscrewing it. We neglected it on my install in my buddys garage and we ended up having to cut the thing off and custom fit the new downpipe on. Was a big pain.
Addicted to boost!
'05
- Airbox Delete
- Greddy Type RS BOV
- PTP WGA set @18PSI
- Needswings V.5
dvoratexn is offline   Reply With Quote
Old 11-14-2012, 03:53 PM   #13 (permalink)
triangles's Avatar
Well no mine was welded on to the back half . Idk if that was stock never seen an unmolested one. But yes I did cut mine and weld a flange on it and opisite end.
05 flame red
daily driven
E85
Old 11-14-2012, 04:36 PM   #14 (permalink)
05OhioSRT's Avatar
Yeah after I posted, I had a feeling somebody had already done some welding work or something to yours. OP, yours has the factory 2.25 inch slip joint right? If so, you should be good to go after reading these. You have your how-to now for the most part, just without pictures which wouldn't show much
Old 11-14-2012, 04:47 PM   #15 (permalink)
Member Number: 82680
I'm surprised no one said to soak the nuts/top flag nut in PB blaster. You will hate life if you snap one of the studs.
JeffM is offline   Reply With Quote
