Old 03-08-2006, 10:07 PM   #31 (permalink)
tURBOsetch's Avatar
Member Number: 24746
Yeah I clamp at 4.3 which is 15PSI. Its perfect for WI ..IMO anyway. No fuel mods except the water and it pulls like crazy. I like to keep things as stock looking as possible as well. I just added the hard pipes and thats the biggest non stock looking item now so I guess I'm out of that now. I can't tell if the hard pipes helped but I used the hole on the JMB UPP that you hook the TIP sensor to for the WI nozzle so that was cool. Cya later..
Yep. How do it know?
tURBOsetch is offline   Reply With Quote
Old 03-09-2006, 07:17 AM   #32 (permalink)
bnice01's Avatar
Member Number: 34888
Funny I just got the JMB performance hard pipes and didnt notice too much but great customer service. Also how are those 245's treating you? Do they fit well any rubbing and do you have all 4? Cause I was thinking the same tire size. Some dude locally has 245's on the front and 205's in the back. Water injection is one of the best mods i did. I made my own kit cost about 100 but powerband and top end is just sick.
PT
hey how many springs do you have in stock?
Click On Sig For Custom Tunes\Installs
Garage
bnice01 is offline   Reply With Quote
Old 03-09-2006, 08:21 PM   #33 (permalink)
Member Number: 24782
I find this to be a interesting mod. I will have to dive into it a little more.
04 GT 5-speed
S1, K&N drop-in, air box mod,05 mani, TTAB & UCP, Magnacor wires & NGK plugs .035, Mopar dual exhaust
Eibach springs, Mopar Sways, strut bar
PTeazer bumperette, grille, Cowl Induction hood & rollpan, Wheel Vintiques Ralleye Billet Rims
01 painted heated mirrors, painted trim, debadged
Maxxfab O2 & DP pipes, AGP WGA, PPQ, soon to be adding Josh's stuff!!!
GR8FLPT is offline   Reply With Quote
Old 03-09-2006, 09:00 PM   #34 (permalink)
tURBOsetch's Avatar
If you find anything else on this let me know, I searched all over for info on this mod and never found much. I knew it had been done but never found details. Post links if you find anything.
Old 03-11-2006, 12:39 AM   #35 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (532)
Quote: Originally Posted by bnice01
PT
More then enough. I got enough made up to do my own WGA's for when the SRT-4 caliber comes out.
Old 03-12-2006, 02:46 AM   #36 (permalink)
tURBOsetch's Avatar
OT: I heard the rumor that the Caliber transmission can olny handle about 300 tq. That would mean that any mods to the Caliber and the tranny would break. Any confirmation on this?
Old 03-12-2006, 11:08 AM   #37 (permalink)
Its the clutch not the tranny that is limited. The manufacture would never rate the tranny at such a low rating due to the fact it will be a "tuner" car and the warranty issues of people taking them back to stock after the tranny came apart would be crazy.
Old 03-12-2006, 11:09 AM   #38 (permalink)
Just some food for thought, the upgraded spring might work on a stg 2 WGA. For all those wanting some adjustability while still looking stock. The spring might be a much needed upgrade.
Old 03-12-2006, 11:22 AM   #39 (permalink)
04TurboSRT's Avatar
Member Number: 12748
will this spring mod work for the Stage 3 WGA? i mean i know it would fit but is it stiffer than the spring i have now?
S3RToys, E-Manage, Walbro 255, CTI HS pipe, JMB L/UPP w/ 1gdsm bov, DCR oil mod, AGP Race FMIC, AGP WGA, BWoody CBar, Kinetic 60mm TB, ExHone ITM, Injen SRI, CMist W/I, MaxxFab O2H, Mopar CatD/B, Prothane Inserts, PTPcheckvalve, 8mm wires, ClutchMasters Stg4 w/Alum Fly, slow4drSTS, DCS F/R STBs, PT/ACR sway/tension bars, Revitup TractionBar, Eibach Coilovers.
1/4 mile: 11.93@115mph on M&H 24.5" slicks (1.85 60ft) & HOM drop in 4th IM GAY!!!!!!
04TurboSRT is offline   Reply With Quote
Old 03-12-2006, 11:29 AM   #40 (permalink)
I dont have a spare stg 3 laying around to tear apart. The spring in side the stage 3 is just as week as the stg 2 spring so I would suspect that it would work better then the stg 3 spring.
Old 03-14-2006, 07:07 PM   #41 (permalink)
tURBOsetch's Avatar
So anyone else do this yet?? I am curious to find out how it works for others.
Old 03-14-2006, 07:25 PM   #42 (permalink)
bnice01's Avatar
I am ordering my spring tomorrow and I will let you know my inputs when I get and install it. But judging from your results it just motivates me to do it as well.
Old 03-14-2006, 07:43 PM   #43 (permalink)
SRToc Member
blair_t's Avatar
Member Number: 31087
Is the PT spring a 15ib spring?
Would this work with the stage 2 wastegate and PCM controlled boost?
I dont want to mess with the way the car drives now I have had forge wastegate and the PTB sucked ass. If this mod would give me a few more psi to redline its worth the 20 bucks!
I have a stock wastegate laying around would it be smarter to put the spring in the stock wastegate and then put that on my stage 2?
{~}mOpAr sTaGe II w/ToYs
{~}mOpAr cAt-BaCk
{~}mOpAr bOv
{~}mOpAr dRoP-iN fIlTeR
{~}nGk wIdEbAnD
{~}dAsMoPaR mApClAmP
{~}kInEtIc wAsTeGaTe
{~}eRz 3'' dOwNpIpE
{~}nGk'S .035
{~}sPoRtLiNeS
{~}sIlVeRsTaRs
blair_t is offline   Reply With Quote
Old 03-14-2006, 08:05 PM   #44 (permalink)
Back-n-Black's Avatar
Member Number: 15950
Trader Rating: (42)
WGA is on the way, spring will bo problem i can just go pick it up, and seeing how the upper heat shield is MIA on my car it should be an easy swap. Then i will head out with the data loggers and record some stuff.
Randy
S&P Tech Rep
Mopar & Dodge parts!!email:randy.speedandpower@gmail.com
Build it!!! Photo=Suzq044
Wood Frog's where the NW gets fast!!
Back-n-Black is offline   Reply With Quote
Old 03-14-2006, 08:08 PM   #45 (permalink)
bnice01's Avatar
Randy
I want to remove my heat shield, how is it holding up w/o it? I know some cars must have it but mines is all dinged up from my messing with it from the spring mod. Also you have any pic's w/o the shield
