2 Step - Page 3 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 12-05-2012, 10:01 PM   #31 (permalink)
Member Number: 90033
Quote: Originally Posted by STV3 View Post
Pretty sure the video is an anti lag set up which advances the timing to build more boost on the launch. My wot box is wired ignition cut only and sure as hell doesn't do that.
So much misinformation going on, anti-lag retards timing not advances it. The point of anti-lag is to retard the timing so that most of the pressure is put on the turbine wheel of the turbo. Which is why anti-lag isn't smart for a dd, 2-step's or studder box or WOT box work way better and don't really harm anything.
AWD_Launch is offline   Reply With Quote
Old 12-05-2012, 10:35 PM   #32 (permalink)
Chief's Avatar
Member Number: 61336
stv3, look up anti lag, and you will understand.
'freedom's not free'
24-25psi 61mm
11.6@120
@3650ft
Chief is offline   Reply With Quote
Old 12-05-2012, 10:56 PM   #33 (permalink)
STV3's Avatar
Member Number: 30874
Yea I Wikipedia'd it after lol. I just knew that it did something with the timing and that it is harsh as hell on turbos.
AGP SOMETHING OR OTHER TURBO
TUNED BY NIGEL
373WHP
368WTQ
STV3 is offline   Reply With Quote
Old 12-06-2012, 02:55 PM   #34 (permalink)
greenneonsrt's Avatar
Member Number: 82185
N2mb box doesn't sound any different either way you wire it, if you're looking to make noise like an idiot look elsewhere. It makes your launches worse unless you have slicks anyways
280whp 303wtq 16g bws, injen short ram, meth injection.
Stock intercooler, manifolds, o2 housing, wastegate, and motor.
Best et: 13.4
Best trap: 107
greenneonsrt is offline   Reply With Quote
Old 12-06-2012, 04:26 PM   #35 (permalink)
MyGreenMachine's Avatar
Member Number: 24943
does anyone still sell the NDE TCS anymore? i heard good things about it with the traction control system
Edited by Inzanesrt4
MyGreenMachine is offline   Reply With Quote
Old 12-06-2012, 04:36 PM   #36 (permalink)
STV3's Avatar
Some one is selling one now in the FS section for $400
TUNED BY NIGEL
373WHP
368WTQ
Old 12-06-2012, 04:45 PM   #37 (permalink)
damn thats pretty steep... ill check it out
Old 12-06-2012, 05:42 PM   #38 (permalink)
Member Number: 82349
IMO you are the "idiot"
I asked a question not for your opnion
nsrt4 is offline   Reply With Quote
Old 12-06-2012, 05:50 PM   #39 (permalink)
guhfluh's Avatar
Member Number: 1745
I cut spark only and retard the timing to 5*. Works great for it's intended purpose.
*Language Warning*
guhfluh is offline   Reply With Quote
Old 12-06-2012, 06:00 PM   #40 (permalink)
STV3's Avatar
10.64@130 Dodge Neon - YouTube
Awesome run! How much boost do you build on your 2-step? And is a wot box? I can only build about 4 psi on my wot box @4600rpm
TUNED BY NIGEL
373WHP
368WTQ
Old 12-06-2012, 06:18 PM   #41 (permalink)
guhfluh's Avatar
Member Number: 1745
Megasquirt. 3450rpm and ~10psi there on a Delta 65. It's an auto though, so it's easier to control rpms.
*It will build more boost at that rpm, just not in the .5 seconds given for the tree to drop, with my current settings. The Delta65 isn't a small turbo though, and my Crower Stage 4 cams don't lend to quick spool either. I'm simply implying that spark cut only works well for it's intended purpose(building boost) when set up correctly.
Old 12-06-2012, 06:48 PM   #42 (permalink)
In this video mine is set to 2500 boost was at 2psi
Old 12-06-2012, 06:53 PM   #43 (permalink)
Fresh Meat Moderator
tunerlover3's Avatar
Member Number: 76568
2500 is super low.
This is at 4K. Old ass video:
https://www.youtube.com/watch?v=sDkqctbwIv8
Diablo CMR tuner ~Dan~
310HP 436TQ
2004 Eblue Neon SRT4: E85 5558 Built motor
XXXHP XXXTQ
Old 12-06-2012, 06:58 PM   #44 (permalink)
Quote: Originally Posted by tunerlover3 View Post
2500 is super low.
I know I just set it like that Because Everyone wants to hear it so I figure its not as bad at 2500 vs 5200..
This is at 5200
Old 12-06-2012, 07:51 PM   #45 (permalink)
Chief's Avatar
https://www.facebook.com/photo.php?v...type=3&theater
n2mb
24-25psi 61mm
11.6@120
@3650ft
