2 Step - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 12-04-2012, 06:26 PM   #1 (permalink)
Member Number: 82349
Default 2 Step
why does this guys 2 step sound crazy loud? Its almost like its not cutting fuel?
nsrt4 is offline   Reply With Quote
Old 12-04-2012, 06:35 PM   #2 (permalink)
SRT of the Month
underSRTarmor's Avatar
Member Number: 32888
Yes he has it wired to cut spark only.
Old 12-04-2012, 06:36 PM   #3 (permalink)
I might do this to mine.. What wire would I have to cut?
Old 12-04-2012, 06:37 PM   #4 (permalink)
Fresh Meat Moderator
tunerlover3's Avatar
Member Number: 76568
Thats not the N2MB wot box. He has the NDE traction control system.
Diablo CMR tuner ~Dan~
310HP 436TQ
XXXHP XXXTQ
Old 12-04-2012, 06:38 PM   #5 (permalink)
SRT of the Month
Not 100% but I think u cut the green wire going to the coil.
Old 12-04-2012, 06:43 PM   #6 (permalink)
benspilk09's Avatar
Member Number: 88421
I wasn't aware the N2MB box did either, I wired mine up and didn't think any of the wires went to the fuel system. It still blows loads of black smoke out too so its definitely still getting fuel. I was under impression that the green wire to the coil wires were to cut ignition, the cam sensor wire to sense RPMs, and the TPS sensor wire to sense WOT, and of course the power/ground/clutch sensor wires are obvious.
benspilk09 is offline   Reply With Quote
Old 12-04-2012, 06:45 PM   #7 (permalink)
To wire the N2MB wot box to just cut spark, the wires you use for the C101 connector need to go to the coil pack instead.
310HP 436TQ
XXXHP XXXTQ
Old 12-04-2012, 06:48 PM   #8 (permalink)
benspilk09's Avatar
I guess I assumed wrong, what does the wire on the C101 connector go to then? Does it cut fuel and spark when its grounded/disconnected?
Old 12-04-2012, 06:54 PM   #9 (permalink)
There is a black and red wire on the N2MB that gets wired into the C101 connector. It controls coil power and the fuel injectors.
310HP 436TQ
XXXHP XXXTQ
Old 12-04-2012, 07:22 PM   #10 (permalink)
*ALEX*'s Avatar
Member Number: 79647
their you go you ricer
Quote: Originally Posted by lVlemphizStylez View Post
When I open my hood people think the car is on all kinds of steroids
*ALEX* is online now   Reply With Quote
Old 12-04-2012, 07:28 PM   #11 (permalink)
all blacked out's Avatar
Member Number: 83410
Is it bad to just cut the spark? What would be the difference in cutting just spark and cutting both?
all blacked out is offline   Reply With Quote
Old 12-04-2012, 07:30 PM   #12 (permalink)
SRT of the Month
Cutting just spark u get alot of unburned fuel. Hence the pop bang pop pop bang.
The fuel injectors and the coil pack are controlled by the neg.(-). With ignition on there is a pos (+) supply on them as all times. The green/orange wire.
Old 12-04-2012, 07:31 PM   #13 (permalink)
*ALEX*'s Avatar
no damage if you dont do them for extended periods of time (from N2MB ) ...... the only difference is Ricer and not Ricer
Old 12-04-2012, 07:33 PM   #14 (permalink)
There is damage.
N2MB doesnt recommend it for people running E85.
Even if you wire it the normal way you will still get flames.
310HP 436TQ
XXXHP XXXTQ
Old 12-04-2012, 07:38 PM   #15 (permalink)
*ALEX*'s Avatar
we do recommend the fuel and ignition cut on the srt.
However, we do ignition cut only on all other vehicles, with thousands of wot boxes installed and no problems to report.
