16G Big wheel stocker VS E1 Turbo - Page 5 - Dodge SRT Forum
View Poll Results: What set-up do you have?
Bone Stock Turbo 44 14.24%
Mopar Stage 1 Set-up 18 5.83%
Mopar Stage 2 Set-up 28 9.06%
Mopar Stage 3 Set-up 27 8.74%
Stock Turbo DSP with minor mods 69 22.33%
Stock Turbo DSP,Full Bolt ons,Tuned,Meth injection 26 8.41%
E1 Turbo or Big wheel stocker Set-up 49 15.86%
Big Turbo Kit on Stock Motor and internals 33 10.68%
Big Turbo Kit with Built Motor 15 4.85%
Voters: 309. You may not vote on this poll
post #61 of 384 (permalink) Old 07-19-2011, 08:41 PM
ggferris's Avatar
Quoted: 2 Post(s)
Originally Posted by NorthNJSRT4 View Post
Gonna break it in at 8-10psi for 500miles before I ramp it up and get it fully tuned. I'll let ya know...so far it's pretty sexy.
you bought one? so did i, i get it in a fewdays. COME ON DAN JOIN THE CLUB!!
ggferris is offline
post #62 of 384 (permalink) Old 07-19-2011, 09:00 PM
Bake_05's Avatar
Quoted: 0 Post(s)
oops...I broke it in on 20lbs. lol
Stock
Bake_05 is offline
post #63 of 384 (permalink) Old 07-19-2011, 09:18 PM
Fresh Meat Moderator
Quoted: 3 Post(s)
Need da monies.
tunerlover3 is offline
post #64 of 384 (permalink) Old 07-19-2011, 10:11 PM
Merderates da formz
NorthNJSRT4's Avatar
Quoted: 3 Post(s)
More like testing it out. I've had it for a while now but I had to wait until I got in a radiator and fan shroud from another vendor to test so I only had to drain the fluids out of the car once.
Well, if it starts smoking or the bearing goes out you'll know why.
NorthNJSRT4 is offline
post #65 of 384 (permalink) Old 07-20-2011, 06:38 AM
2011 Calendar Car
Double J's Avatar
Quoted: 0 Post(s)
Back when I had an E1. I pushed that thing to 18 psi the first day it was in. Never had a problem.
AGP Zeta 2.8
Tuned by Turbo666 and N2MB
Double J is offline
post #66 of 384 (permalink) Old 07-20-2011, 07:19 AM
SRTotM Moderator
Dragoncustompc's Avatar
Quoted: 0 Post(s)
There is no "breakin period" for the E1 turbos. Just fire up the car wait till it at optimal operating temp and give it hell lol. oh and keep the boost spike below 23/24lbs to the ensure longevity of the turbo.
* parts should be properly heatcycled. please note correction..
Sales assistant for Forward Motion Inc<- Click link
email sales@forwardmotioninc.com
Phone (302)-658-2829
12.8 @108. 312hp/371trq on 93 pump gas. E1 turbo, FM manifold, FM intercooler, FM wastegate.
DynoTuned by Nigel, El Ralfo Racing driver
Dragoncustompc is offline
post #67 of 384 (permalink) Old 07-20-2011, 07:24 AM
Merderates da formz
Quoted: 3 Post(s)
The service manual quotes the break in period as at least 100 miles with minimal engagement of boost (it's also stated in the S3 install guide). Brand new parts that spin at several hundred thousand RPMs need to be heat cycled and allowed to seat to guarantee their proper function and longevity. I'm going to side with the engineers of the turbo on that one.
post #68 of 384 (permalink) Old 07-20-2011, 07:47 AM
sdpbob's Avatar
Quoted: 0 Post(s)
Originally Posted by tunerlover3 View Post
Need da monies.
What are you talking about Dan you have all sorts of money
Project Gossamer
Corn Fed E1
DSP, E1, Turbonetics WG, Ported & Polished Ext Gated Mani, AEM UEGO, 30/30 Boost Gauge, Dogbones, Walbro 255, Perrin FR, AEM CAI, MSD Wires, FP Re-Wire, GReddy BOV w/ EDM pipe, Quickwhips BFMIC, 3" 02 & DP, Boost Box, WOT Box w/2-Step, 3" SEE, Custom Badges By Wiggy, 3bars, Duster360's 1025s, Maddog 80 STS
So Broke I Can't Afford To Pay Attention
sdpbob is offline
post #69 of 384 (permalink) Old 07-20-2011, 07:55 AM
SRTotM Moderator
Quoted: 0 Post(s)
Im going by what Mike@FM told me when mine was installed. but i understand what ur saying and agree
post #70 of 384 (permalink) Old 07-20-2011, 08:09 AM
Merderates da formz
Quoted: 3 Post(s)
After reading their warrenty information it makes sense why, they simply don't care if you blow it or if they assembled it\balanced it incorrectly. It's tough shit either way.
Warranty Information
Products are sold "as is" by Forward Motion and are for performance Off Road Use Only. No Warranties whatsoever, written or oral are provided or implies to the purchaser. We cannot assume responsibility of liability for any product or service failure or for product suitability to your application.
Should parts prove to be defective, the buyer assumes the entire cost of all necessary servicing or repair. Forward Motion reserves the right to repair or replace our products if found defective by FM's technical staff.
Here's AGP's. They're telling you that you don't really have a warranty but if something happens they'll at least try to help you.
Before attempting to start the engine, crank the engine with the fuel/ignition shut off for ten to 15 seconds (three separate times) or until the instruments show an oil pressure buildup. Start the engine and allow running at idle speed for 15 to 20 minutes without accelerating or until engine has reached full operating temperature. Check for oil/water leaks around turbocharger and related installed components. After it has been determined that there are no leaks in the oiling system of the turbo, allow approximately 100 miles driven under normal conditions without going into "boost". This is done to properly wash out all of the assembly lube used when assembling the turbocharger, and to allow carbon to build up along the piston ring areas of the turbine shaft. Immediately running the turbocharger to its full potential without proper break-in procedures will cause premature turbocharger failure.
Limited Warranty
AGP Turbochargers, Inc. is an automotive aftermarket manufacturer of quality USA built and assembled products. The nature of the performance and racing industry defines no warranties on any products of any kind. AGP Turbochargers, Inc. does not warrant any products manufactured or distributed by AGP Turbochargers, Inc. (unless otherwise provided by another manufacturer or distributor). AGP Turbochargers, Inc. understands that mistakes can and will happen, and AGP Turbochargers, Inc. will work with the customer at the discretion of AGP Turbochargers, Inc. to remedy a product failure.
Basically, no matter what you do you may be on your own. Would it not be wise to at least TRY to protect your investment by taking the precaution of breaking the turbo in properly as part of due diligence?
post #71 of 384 (permalink) Old 07-20-2011, 08:11 AM
SRTotM Moderator
Quoted: 0 Post(s)
Limited Warranty
I agree with you.
post #72 of 384 (permalink) Old 07-20-2011, 08:18 AM
Merderates da formz
Quoted: 3 Post(s)
post #73 of 384 (permalink) Old 07-20-2011, 08:20 AM
NeOnDrAgOn's Avatar
Quoted: 0 Post(s)
I would always do some kinda of break in on a new part? Just like you don't (well shouldn't) start you car and go balls out...
05 Black,Full 3inch exhaust, BWS3 47#,Ported and polished, Duster360's injectors and tune
Realtune LCA's Bushing= Best mod since the DSP.
Originally Posted by never2muchboost View Post
hadoukens will be shat
NeOnDrAgOn is offline
post #74 of 384 (permalink) Old 07-20-2011, 08:25 AM
SRTotM Moderator
Quoted: 0 Post(s)
And nothing against FM or anything, everyone knows I like their stuff.
You brought up a good point and i agree and will recommend a proper heatcycling before major use from now on and im sure mike@fm meant for me to at least heatcycle the parts so i corrected that post.
post #75 of 384 (permalink) Old 07-20-2011, 09:26 AM
2011 Calendar Car
Double J's Avatar
Quoted: 0 Post(s)
Even tho I never broke in the E1. I did make sure to do the 100 mile break in period on the 2.8. Cuz the zeta cost a lot more to replace.
1600 zeta > 650 e1
AGP Zeta 2.8
Double J is offline
User Tag List
Linear Mode Linear Mode
