Old 11-17-2009, 10:14 AM   #1 (permalink)
Zero_psi's Avatar
Member Number: 71591
Default 03 rail shrader valve replacement
So I got a 03 rail and don't have the money to do a return line and it dident come with the shrader valve on it and I'd Like to install it with my s 2 injectors any one kno where I cam get one dealer wants me to get a new rail and no where else seems to have one ?
stage 1 with some other goodies
Zero_psi is offline   Reply With Quote
Old 11-17-2009, 11:01 AM   #2 (permalink)
kevin2004's Avatar
Member Number: 66925
Trader Rating: (38)
Are you talking about just the little pin valve that goes inside?
kevin2004 is offline   Reply With Quote
Old 11-17-2009, 11:56 AM   #3 (permalink)
scottw03's Avatar
Member Number: 23435
Trader Rating: (41)
does your fuel rail have something like this on the end?
If so that is the shrader valve. Get a tool from pepboys or advanced autoparts to take the little valve with the spring in the middle of it out (If it is out already don't worry about it). Then hook your FRL return to it and that is it. My setup runs from the fuel tank, to the fuel rail, out the shrader valve to the FPR back to the fuel tank.
scottw03 is offline   Reply With Quote
Old 11-17-2009, 12:05 PM   #4 (permalink)
duster360's Avatar
Member Number: 45182
pay attention ,,,,he's not installing a return line
Go to the local parts store and get a shrader valve for an A/C hose. They're usually stocked behind the counter. It will screw right in and hold up to the gasoline. Regular tire valves will degrade over time from the fuel and leak.
The tool use to screw it in is the same used for tire valve stems. If you're carefull you could just use needle nose pliars.
Old 11-17-2009, 12:15 PM   #5 (permalink)
scottw03's Avatar
Trader Rating: (41)
How is he supposed to screw it in if there is nothing to screw it into on the fuel rail????
He said he had an 03 fuel rail. '03 rails had shrader valves. They didn't do away with them until sometime in '04 when they switched to the same rail that the '05 comes standard with. So if his doesn't have a shrader valve on it then it is not an '03 rail.
I mean correct me if I am wrong but that is the info that I have concerning the fuel rail. That is why I switch from my stock 05 rail to a 03 rail that I got off an SRT-4 in a junk yard. cheapest mod I have I have put on the car.
Old 11-17-2009, 12:16 PM   #6 (permalink)
Zero_psi's Avatar
awsome thank u yahh no parts store hd any idea what to do lol
Old 11-17-2009, 12:19 PM   #7 (permalink)
Zero_psi's Avatar
lol no my cars a 05 dosent have the valve or anything so i bought a 03 rail but the guy befor me had a return line aka he took the valve out. Im broke so i needed to find a valve i could put in there so that it i could use the 03 rail with out the return line!
Old 11-17-2009, 12:25 PM   #8 (permalink)
duster360's Avatar
The key is not to tell them what you're doing. Just ask for an A/C hose shrader valve.
R12 NOT R134A(they're different thread sizes)
Old 11-17-2009, 12:27 PM   #9 (permalink)
16Boosted's Avatar
Member Number: 65234
Can you just attach the valve to the rail on the right side??^^^^^^
16Boosted is offline   Reply With Quote
Old 11-17-2009, 12:36 PM   #10 (permalink)
duster360's Avatar
If you are a competent welder and get the right parts, probably.
Some factory rails have an internal secondary "rail" inside that the damper connects to.It used just to eliminate noise. I haven't had a stock rail apart to tell you for sure, but you might have to remove this secondary tube also.
Old 11-17-2009, 12:42 PM   #11 (permalink)
16Boosted's Avatar
Oh I see. thanks
Old 11-17-2009, 12:47 PM   #12 (permalink)
Zero_psi's Avatar
awsome im gonna go to napa zone and get one lol
Old 11-17-2009, 12:49 PM   #13 (permalink)
duster360's Avatar
Old 11-17-2009, 12:52 PM   #14 (permalink)
16Boosted's Avatar
Can you post a pic of the 03 rail just to see what it looks like?
Thanks
Old 11-17-2009, 01:16 PM   #15 (permalink)
Zero_psi's Avatar
I'm at auto Zone there clue less lol I even showed them the pic
