Wheel bearing...and the HUB? - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 05-20-2008, 09:36 AM   #1 (permalink)
Member Number: 31038
Default Wheel bearing...and the HUB?
Does the hub need to be replaced with the wheel bearing? Is it a good idea to do so and make the job easier? I say this because I noticed wheel bearing play in my drivers side. It hasn't made any noises yet but it will eventually come to that point and I want to get it fixed here in a bit.
Just for reference....
Front wheel bearing at the dealership is $75. Part number 5272448AA
S&P sells them for $55.57
Front wheel hub is $60 at the dealership. Part number 4670292AF
S&P sells them for $43.86
04 Neon SRT-4
Mopar S3, DSP, 888cc injectors, Dusters tune, Walbro 255 w/ S3 fuel system. NO rewire. e70 397whp/398tq 128k miles
99 Neon Highline Coupe
MPG Daily
2.0 DOHC, 5spd
s3*ps2 is offline   Reply With Quote
Old 05-20-2008, 09:56 AM   #2 (permalink)
NogaBlitz's Avatar
Member Number: 6194
Also would like to know the answer to this.
-Stand tall and shake the heavens.
NogaBlitz is offline   Reply With Quote
Old 05-20-2008, 10:19 AM   #3 (permalink)
Fischy's Avatar
Member Number: 20133
The hub won't need to be replaced, unless it was damaged during the bearing pull process.
I just had some autozone timkin ($31 each) bearings installed in my knuckles / hubs for $35 per side. The hubs feel nice and slightly snug when rotated.
FYI my front left bearing went at 95,000 miles, which includes a lot of mountain driving.
Steve
LCR GreenSpec S3, Everything Ported, DSP & CM W/M injection.
Fischy is offline   Reply With Quote
Old 05-20-2008, 10:41 AM   #4 (permalink)
boost_SRT4's Avatar
Member Number: 3514
i would go ahead an replace both i just ran into 1000 dollars worth of suspension repair because of these issues. my exhaust was too loud to hear the noise, then it was too late
04 E Blue SRT4
BDJ's 3in dump(no cat) / AGP wastegate spike 19hold 17 / MM inserts / magnacore 8.5mm wires / gunmetal 18x8 Exel Ennios w/235/40/18 / K&N CAI / CCA FMIC / d-tec / aeroforce scan guage / AEM UGEO / Stg.2 inj.
boost_SRT4 is offline   Reply With Quote
Old 05-20-2008, 10:51 AM   #5 (permalink)
Monster's Avatar
Member Number: 48761
Care to elaborate? Ive needed bearings for awhile i suspect some play and Im a little lost as to how that can happen
Quote: Originally Posted by Turbolag87 View Post
ur all idiots and noobs.
Stop giving out retarded information
Old 05-20-2008, 10:51 AM   #6 (permalink)
SRT of the Month
2011 Calendar Car
1LAPSRT's Avatar
Member Number: 38267
I would go ahead and spend the extra $90 and get two new front hubs as well. If you are doing all the work and then something goes wrong with the old hub, you have to do all the work again and buy another bearing. And don't forget you get all new wheel studs already installed in the hubs when you buy them!
I replace all four hubs/bearings at least twice a year, but my car is mostly just for track use.
Modern Performance SRT4 - Dominating the road race community for over 5 years!
2012 MPx SRT4 Racing and Event schedule:
http://www.srtforums.com/forums/f77/...2012-a-627265/
Old 05-20-2008, 10:52 AM   #7 (permalink)
SRT of the Month
2011 Calendar Car
1LAPSRT's Avatar
I suppose that if the rear's were bad, he could have chewed up the spindle assembly(s)? Other than that, I can't imagine what would cause $1,000 damage due to a worn bearing.
Old 05-20-2008, 10:56 AM   #8 (permalink)
Member Number: 58416
when you press the hub out of the bearing the outter bearing race is going to still be pressed to the hub.you need a special tool to catch the edge of the race and press it off the hub.or you can cut most the way through the race and crack it with a chisel.it can pose to be a pain in the ass if you dont have the right tools.so if this is a driveway job id just save yourself the agrivation and buy new hubs also.
dodgetech81 is offline   Reply With Quote
Old 05-20-2008, 11:07 AM   #9 (permalink)
SRT of the Month
2011 Calendar Car
1LAPSRT's Avatar
I wouldn't even attempt the bearing removal without a press. If you don't have one (and some bearing press tools) I would take the whole knuckle to a machine shop and have them do the work for you. Just bring the new hub and bearing and it should take them about 15 minutes, assuming they know what they are doing.
Old 05-20-2008, 02:07 PM   #10 (permalink)
I don't plan on doing it. I plan on having a local shop do it. So would it be more in labor for them to replace the hub with the bearing? And No I don't want to replace something that doesn't need to be replaced. (The right side) Once it starts getting play I will replace that side.
I also read they upgraded from a tappered roller bearing to a ball bearing. Could be the other way around.
My buddy only had 28k on his and both of them went out! FYI.
My car is a daily driver too BTW, not a track car.
They only charged you $35 to install a bearing!@?!?!?
04 Neon SRT-4
MPG Daily
2.0 DOHC, 5spd
Old 05-20-2008, 02:45 PM   #11 (permalink)
SRT of the Month
2011 Calendar Car
1LAPSRT's Avatar
You have to remove the hub from the spindle and press off the bearing (or at least half) to replace the bearing, so in all reality, it is less labor if you replace the hub as well, since they don't have to worry about removing the bearing from the hub, just the spindle housing.
I paid $30 to install both bearing and both hubs in my knuckles. Of course I carried the spindle to a machine shop after I removed them from the car and reinstalled them later myself as well. It took the machine shop 10, maybe 15 minutes to do all the work.
Old 05-20-2008, 04:37 PM   #12 (permalink)
fivetoez's Avatar
Member Number: 9691
I just changed my L.F. wheel bearing, & YES! i HAD to replace the hub...... because the inner section of the hub,where the inner bearing race sits,was worn badly.
_____5TOEZ______ 1967 Cadillac Calais 429 2dr., 1967 Chevelle 4sp. Conv. ,1978 Dodge 318 "Factory Custom"van., 2004 Dodge Srt-4,Stage1.5(E-Blue) & a couple motorcycles.
Old 05-20-2008, 04:59 PM   #13 (permalink)
Fischy's Avatar
Yes, I brought in two stock knuckle assemblies and two new timkin bearings. One hour later my knuckles / hubs have the fresh bearings installed for $70 total cost.
Just a local automotive machine shop.
Steve
Old 05-20-2008, 10:52 PM   #14 (permalink)
Ahhh okay! I thought you brought your car in there and they took it apart and put it back together for $35 a side. I shall order the hub too.
04 Neon SRT-4
MPG Daily
2.0 DOHC, 5spd
Old 02-26-2010, 11:55 AM   #15 (permalink)
Member Number: 60726
where are you ordering the bearing and hub from i need one aswell. thanks
stranacksrt4 is offline   Reply With Quote
