Old 06-30-2008, 08:12 PM   #1 (permalink)
Member Number: 60625
upgraded clutch??
I was wondering if there was a way to tell if you have a upgraded clutch without taking the tranny off. Another member on here said if you can hear it engage easily you have one and i can hear it engage over my 3 inch exhaust dump. Is there any other way to tell thanx.
rocko is offline   Reply With Quote
Old 06-30-2008, 09:09 PM   #2 (permalink)
04PAcruz'n's Avatar
Member Number: 8512
pop open the cover/window that is right next to the slave clylinder on the tranny. you will be looking at the TOB and clutch.....you should be able to tell if it is at least aftermarket.
Mods:
S2 w/o, JMB Ported IM+PTP 55mm TB, PTP charge pipe, Mopar TB Exhaust (cat-back+cat-delete), Mopar CAI, Spearco DF-IC, Samco IC hoses.
Mopar Stage 1 suspension (springs+sways), rear tension struts, Mopar front STB, Pwerks rear STB, mm inserts (street)
Mopar STS, Mopar BOV,4306 NGKs, JMB catchcan, Pwerks grounding kit, PTP check valve
04PAcruz'n is offline   Reply With Quote
Page generated in 0.11639 seconds with 11 queries
