Transmission Overfill? - Dodge SRT Forum
post #1 of 14 (permalink) Old 07-22-2011, 09:44 PM Thread Starter
RiotMaker's Avatar
Quoted: 0 Post(s)
I put 3 quarts of atf fluid in the transmission and no problem at first... Today I see it leaking from somewhere on top of the transmission running down my the drain plug... Can this be an overfill... What do I do.. Help... Is it safe to drive.
RiotMaker is offline
post #2 of 14 (permalink) Old 07-22-2011, 11:58 PM
Hi N Mity's Avatar
Quoted: 1 Post(s)
3 quarts is over full. you need to have the car sitting on level ground, the front not jacked up off the ground, or on ramps when you fill it. The trans holds 2.4-2.6 quarts. I would start by parking on level ground and removing the Fill Hole Plug to let the excess drain out to the proper level. When the fluid stops coming out of the fill hole, you are at the proper level. You are approximately 17% over full. thats like adding 6 quarts of oil to your engine, when it only should have 5 quarts in the sump.
Hi N Mity is offline
post #3 of 14 (permalink) Old 07-23-2011, 12:12 AM
SRTFORUM Moderator
Advans's Avatar
Quoted: 71 Post(s)
Fill it up till it comes out the fill hole, wait for it to stop, then put the plug back in.
Edit, what Hi N Mity said.
Advans is offline
post #4 of 14 (permalink) Old 07-23-2011, 01:45 PM Thread Starter
RiotMaker's Avatar
Quoted: 0 Post(s)
Will it ruin anything.... Last night I was driving it with overfill... Today I drained out all the excess....
post #5 of 14 (permalink) Old 07-23-2011, 01:55 PM
Hi N Mity's Avatar
Quoted: 1 Post(s)
probably not for the short amount of time you had it overfilled
post #6 of 14 (permalink) Old 07-23-2011, 02:12 PM
Mopar McNeer's Avatar
Quoted: 1 Post(s)
You'll be fine.
AGP 50 Trim .82 A/R, Turbo666 DSP Tuned, Fully Built JP Pistons/BC Rods, DW 750 Injectors, Ported Intake w/ LFS 60mm, AGP Big FMIC, Crane #14 Cams & Cam Gears, Ravenworks CNC Ported w/ Indy Values, ED 3" Exhaust w/ Ported Exhaust Housing/Manifold, Walbro 255 & AGP Returnline w/ Bottleneck fix & Fuel Pump Rewire, HKS SSQV, Tial 38mm WG, ACT 6 Puck, Pwerks Billet Input Shaft.
Click to See my SRT
Click to see my old Avenger- RIP
Mopar McNeer is offline
post #7 of 14 (permalink) Old 07-23-2011, 02:30 PM
blackbird_R/T's Avatar
Quoted: 84 Post(s)
The transaxle uses splash lubrication where the gear set spinning splashes fluid up into the case and into the feeder assembly that supplies the shafts. In an engine if you overfill it the spinning lower end rotating assembly can aerate the oil, which could then be drawn into the oil pump and the pressurized lubrication system. Aerated engine oil can cause a false pressure reading on a pressure gauge and doesn't protect bearings. This isn't as much an issue with ATF in the trans as it is designed for the gears to splash the fluid.
What could potentially be an issue due to overfilling both the engine crankcase and the transaxle would be leaks from seals due to the fluid level being too high. In the engine this can sometimes lead to rear main seal leaks and in the trans it could potential lead to a leaking axle seal. That's probably the biggest risk you run from overfilling but to be safe I'd still get the car on level ground and pull the fill plug so any excess fluid can drain out.
Eric H. - '04 Neon SRT-4 (eBlue/S2) - '04 SRT-4 (blk/stock & now sold)
'92 Dodge Daytona IROC R/T --- -- '91 Dodge Spirit R/T
plus a couple other turbo Dodges, a Cobalt, a couple Focus, big S/C wagon, and some other stuff...
blackbird_R/T is offline
post #8 of 14 (permalink) Old 07-23-2011, 04:03 PM
2013 FF Pizza League Champion
ps2srt4's Avatar
Quoted: 0 Post(s)
Check this out too.
HOW-TO: Transmission Fluid Change
Originally Posted by JPG View Post
lol @ when he finds out someone else is slaying the poon!
ps2srt4 is offline
post #9 of 14 (permalink) Old 07-25-2011, 02:39 PM
srT4URBO's Avatar
Quoted: 6 Post(s)
You will be ok. Unplug the rubber plug and let it drain out by itself, shouldnt be much at all.
Its modded
srT4URBO is offline
post #10 of 14 (permalink) Old 07-25-2011, 03:07 PM
KALVIN97GAGT's Avatar
Quoted: 1 Post(s)
Every response I have seen from you was perfect. Wish more posts were like this.
401whp/407tq AGP dbb 50t .63AR with all supporting mods
Sold after 7+ years of ownership
duster360=STILL the worst tuner on the site
New daily: 05 C55 AMG
KALVIN97GAGT is offline
post #11 of 14 (permalink) Old 07-25-2011, 07:42 PM
ps2srt4's Avatar
Quoted: 0 Post(s)
Ha, that was a short response for him.
ps2srt4 is offline
post #12 of 14 (permalink) Old 08-16-2012, 10:21 PM
bryan9097's Avatar
Quoted: 0 Post(s)
Garage
alright, I filled mine up on jack stands and overfilled it. I have since drained it out. But what made me think about it was I found a leak on the bottom side of engine/tranny where they bolt together. Since I run motor oil in both I cant tell if it is engine oil or tranny. I have a new built engine from realtune (less than 50 miles) so the oil pan and rear main SHOULD be good. So my question is could it leak from around the input shaft? It didnt seem to be a bunch but enough to catch my attention.
bryan9097 is offline
post #13 of 14 (permalink) Old 08-17-2012, 02:03 AM
Quoted: 84 Post(s)
It could, but you'd really, really have to overfill that case to get the fluid level that high (I'd guesstimate in the 3-4 quart range). You might be able to pull the lower structural collar off which will expose the backside of the flex plate/flywheel assembly. It probably isn't going to give you much room to look around but you might be able to see if the leak is coming from the pan, the rear main, or up front and draining down the interior bell housing of the transaxle from the input shaft.
Also pay close attention to your turbo oil feed and drain lines as well as the valve cover gasket. The valve cover gasket especially can be notorious for leaking small amounts that run down the head and block and look like it may be coming from somewhere else.
post #14 of 14 (permalink) Old 08-18-2012, 12:44 PM
Shadow's Avatar
Quoted: 1 Post(s)
x2. Every post he makes is extremely informative.
blackbird_R/T, FTW!
2005 PVK w/ GWA
Shadow is offline
User Tag List
Linear Mode Linear Mode
