Old 12-29-2007, 01:36 PM   #1 (permalink)
allturbocrx's Avatar
Member Number: 56845
Default Transmission noise (searched)
well i searched thru the forum but couldnt find anything that was just like what i had happen. anyway last night i was driving back home, hadnt really driven the car hard all night long. but i slowed down to go over some bumps and hear a clunk sound and seemed like my engine shook some and car learched a little after i took it out of gear. when i tried to put it back into gear i couldnt get it into any gear. so i let the clutch out and pushed back in and got into 2nd. then went to third and was really hard to get into. drove it about 5 more miles shifting pretty bad and got it home. then when i went to let it cool down in neutral the car was dying and pulling forward like it was stuck in gear. so i left it for the night and went out today and it was still doing it for a little bit then it would idle and was in neutral. my shifter felt fine the whole time no sloppiness or anything just normal. so i took it around the block and drove bad for a bit then started acting normal. shifting pretty good little rough but not bad. it would kind of jerk a little going into some gears like it wasnt fully going into gear, especially reverse. but when i got it back home and went to neutral its making a lot of chatter sound when i let out on the clutch. almost sounds like a piece of something is floating around in the tranny, but goes away when you push the clutch in. so any ideas? i really hope its not the clutch cause i want dodge to warranty the tranny. taking it in monday and if its clutch im doin it myself.
allturbocrx is offline   Reply With Quote
Old 12-29-2007, 04:18 PM   #2 (permalink)
bump!
Old 12-29-2007, 04:39 PM   #3 (permalink)
Member Number: 35913
Trader Rating: (15)
Default more info...
miles on car
stock or not
what does "driving it hard" mean....what were you doing?
when's the last time you changed transmission fluid?
TomC3 is offline   Reply With Quote
Old 12-29-2007, 04:51 PM   #4 (permalink)
DDogsrt461BLK 3.0's Avatar
Member Number: 32500
might be a broken flex plate bolt, here's what mine sounded like, when 2 or the 4 let go!!! Don't reuse flex plate bolts!!!! what's a couple a $$$$
Noise, goes away upon pushing in the clutch, comes - Video
DDogsrt461BLK 3.0 is offline   Reply With Quote
Old 12-29-2007, 05:54 PM   #5 (permalink)
car has 27000 miles on it. driving it hard as in racing it alot. i dont do that much. and for mods, bfmic, agp wastegate, short ram intake and needswings cutout dp. boost at 17. havent changed fluid cause i only had it for 6000 miles. the guy at dodge said changing the fluid wouldnt help when i went to get some tranny fluid, but htought about doing it anyway. the car is driving just fine now but with a loud idle chatter.
and its not as loud as the one on the video but it kind of varies getting louder or softer and just sounds like something kinda gettting stuck then releasing. but does go away with clutch pressed. whats the best way to check the flex plate bolts?
Old 12-29-2007, 11:21 PM   #6 (permalink)
Annihilator's Avatar
Member Number: 42629
The chatter you're talking about sounds a lot like throwout bearing chatter...but flexplate bolts are a possibility too, but considering you've never had the transmission off the car, I wouldn't go in and check that first, since it isn't terribly likely without having pulled the bolts off before.
Annihilator is offline   Reply With Quote
Old 12-30-2007, 05:50 PM   #7 (permalink)
is it ok to drive around on it as long as its still shifting fine? i just dont wanna get stranded. if its the tob what would have happened? is it held in by a pin like hondas? ive never had this car apart but have changed several clutches on my hondas.
Old 12-30-2007, 05:55 PM   #8 (permalink)
Mr. SRT4's Avatar
Member Number: 23704
didnt know SRT's were automatics....
oh you mean flywheel, not flexplate...
Mr. SRT4 is offline   Reply With Quote
Old 12-30-2007, 06:13 PM   #9 (permalink)
NO, modular clutches, bolt to a flexplate, like a conventional automatic torque convertor. 4 bolts, just like my turbo 400, in my chevelle!!
A non modular, has a flywheel, that the clutch bolts to.
there is a difference, but I often called it a flywheel, or flexplate, but in my srt4, and a stock srt4, it's really a flexplate!!
Old 12-31-2007, 10:13 AM   #10 (permalink)
bump again! gonna wait til wednesday to take it to the dealership. dont wanna give them $80 just to say its the clutch and then i have to change it. Does it not seem like its the tranny?
Old 01-01-2008, 01:38 PM   #11 (permalink)
I've been driving mine with the TOB going out on it for about 2 months now...I'm about to go on a 600 mile trip on friday, and I think it's going to hold up fine, but I'm starting to push my luck. I've put ~2500 miles on the car with the TOB making this noise.
Old 01-02-2008, 01:49 AM   #12 (permalink)
ya i think im gonna keep driving it for a while... hopefully it holds up good. clutches are expensive! but what exactly happens to the tob to make all the noise? is the actual bearing coming a part or soemthing else? sounds like its kinda rubbing the pressure plate the whole time
Old 01-03-2008, 02:48 AM   #13 (permalink)
and where is the best place to get a clutch? looked on ebay but not sure which one i want to go with. not wanting full race or anything just a good streetable one that will hold good at 300 hp.
Old 01-03-2008, 03:10 AM   #14 (permalink)
SNOOPALOOP's Avatar
Member Number: 29605
Trader Rating: (23)
Mopar Clutch from Speedandpowerdevelopment.com
SNOOPALOOP is offline   Reply With Quote
Old 01-08-2008, 08:33 PM   #15 (permalink)
Member Number: 59373
mine has 24k miles, and all stock and babied, My tiburon did this too. But i can here a teen tiny bit of chatter when I am in a drive through, since its closed in, And the sound hits the wall, But if I am in the open, I cant hear it.its very minute. I think its normal.
jay04srt4 is offline   Reply With Quote
Page generated in 0.18065 seconds with 13 queries
