Old 07-08-2008, 09:40 AM   #1 (permalink)
uncutfourplay's Avatar
Member Number: 47331
Default Tranny Rebuild
Ok so im having the well known 3rd gear popping out and EVERY gear grinds when shifting into it...it also very hard to get into reverse and 1st gear..and well im tired of this crap so im thinking bout getting a PWERKS stage 2 tranny....anyone here have one? How do you like it? Will it fix my problems and be a reliable tranny for my mods in my sig and is there a warrenty on it if so what is the stipulations?
spendin money that I don't have to buy parts that I don't need to impress people that I don't know
Agp Stage 3D-44lb/min wheel, AGP SCT custom tune, exhaust depot beast bfmic, south bend stage 3 clutch, bdj's ported tb and gasket matched intake mani, DeatschWerks 650 injectors, AEM short ram intake, bdj's 3" dump, Tial wastegate 19-22, Hallman MBC w/Incabin control, hks bov w/ agp pipe, return line, walbro 255 pump
uncutfourplay is offline   Reply With Quote
Old 07-08-2008, 09:46 AM   #2 (permalink)
STUDLEE1A's Avatar
Member Number: 54852
before you do that... just to make sure cause i saved a local from going your route... did you check the clutch pedal adjustment on your car? i seen this exact same thing with ppl whos clutch pedal adjustment has slipped... takes a nut driver and 20 seconds... and you dont even need to pop the hood! its worth a shot...
Factory Freak
STUDLEE1A is offline   Reply With Quote
Old 07-08-2008, 09:57 AM   #3 (permalink)
gonna try this i think i have already done this and it seems that my problem would be more severe than just the pedal moving but ill try it wont hurt
Old 07-08-2008, 10:06 AM   #4 (permalink)
STUDLEE1A's Avatar
when you do it, pull the pedal out so it sticks out past the brake pedal... go extreme at first and if it helps, you can fine tune it back later
Old 07-09-2008, 09:19 PM   #5 (permalink)
that didnt help still does it
ANYONE have a PWERKS stage 2 tranny out there??
Page generated in 0.14247 seconds with 11 queries
