First adjust the clutch pedal, do the cable crossover adjustment, check the two bushings on top of the tranny.
I had a problem shifting and it was the springs in the clutch
The smaller springs had fallen out from inside the larger springs on the disc.
So at first the clutch looked fine
look close in this pic at the top two springs
you can see they are missing the smaller ones
