Old 03-26-2009, 03:58 AM   #196 (permalink)
SNOOPALOOP's Avatar
Member Number: 29605
Trader Rating: (23)
1000 miles now.. no problems Break in period is over
SNOOPALOOP is offline   Reply With Quote
Old 03-26-2009, 03:59 AM   #197 (permalink)
SNOOPALOOP's Avatar
Trader Rating: (23)
Quote: Originally Posted by goats srt View Post
I'm guessing u don't have all 3 solid mounts
No.. I don't..
Old 03-26-2009, 06:19 AM   #198 (permalink)
Good Enough's Avatar
Member Number: 55733
Trader Rating: (41)
Quote: Originally Posted by XXxx_Totmacher_xxXX View Post
NAN Converter > All
Some people wanna shift...
lazy ass...
You Check Your Blood Sugar. You Check It Often.
Good Enough is offline   Reply With Quote
Old 03-26-2009, 07:46 AM   #199 (permalink)
goats srt's Avatar
Member Number: 47689
Quote: Originally Posted by SNOOPALOOP View Post
No.. I don't..
Than u will never know if u have a problem cause the stock mounts hide alot of vibration
Old 07-03-2009, 05:28 PM   #200 (permalink)
srT4URBO's Avatar
Member Number: 37484
Trader Rating: (20)
is the clutch suppose to feel light? ihave the sbc stage 3 and just installed it...its the modular and feel really light when disengaging.....
Its modded
srT4URBO is offline   Reply With Quote
Old 07-03-2009, 05:36 PM   #201 (permalink)
goats srt's Avatar
It should almost feel like stock or the same
look in my for sale thread
selling good stuff check it out
Old 07-03-2009, 05:43 PM   #202 (permalink)
srT4URBO's Avatar
Trader Rating: (20)
mine feels really light....im not sure how anything can be changed.....i didnt do a clutch pedal adjustment and i didint bleed the clutch either.....maybe its the slave cylinder?......how do i check if it disengages properly....just make surre it doesnt roll in first willl im reving it with the clutch pressed in?
Old 07-03-2009, 05:46 PM   #203 (permalink)
goats srt's Avatar
U can try that and if it's easy to get in first and rev where is the pedal at when it starts to disingeuge at
Old 07-03-2009, 09:20 PM   #204 (permalink)
srT4URBO's Avatar
Trader Rating: (20)
i think i have a problem with my clutch slave anyways.....my reverse grinds as it did before the install...a little less now but ill try bleeding it before i replace it first.......when im in 1st or reverse it catches about half way up off of the floor........
Old 07-03-2009, 09:30 PM   #205 (permalink)
goats srt's Avatar
Yea thats where my stage 5 was when I had it and u really can't bleed the system all u can do it pump the clutch a hundred times and readjust the shifter cables on the shifter
Old 07-04-2009, 02:43 AM   #206 (permalink)
srT4URBO's Avatar
Trader Rating: (20)
actually driving around on it a little more it doesnt grind into reverse anymore....maybe it still will who knows...anyways yeah when i get a chance i will re-adjust the crossover cables bolt.....
Page generated in 0.15834 seconds with 13 queries
