Slicks=Broken Shift Selector... - Dodge SRT Forum
post #1 of 23 (permalink) Old 07-03-2011, 06:46 PM Thread Starter
Quoted: 0 Post(s)
Ok, just got my slicks mounted up, went out racing, I have never had any issues with this car. Anyways, was racing a built Ls1 camaro went to bang into 3rd gear and thats where it stayed....
Took the shift selector off and sure enough it broke, bout to buy an agp one next week (im broke now)
I was worried though, I missed a gear do to it breaking and it revved HIGH HIGH HIGH and ran like shit til the end of the track, (seemed like it was missing, sounded like a subaru). I shut it off and it seems to run fine, I drove it all the way home (5 miles) in 3rd gear. Dont know what it was...
Do I need to do anything/is there any tips I should know before instal?
shainesboostin is offline
post #2 of 23 (permalink) Old 07-03-2011, 06:55 PM
rector07's Avatar
Quoted: 0 Post(s)
You need to find the piece that broke. Hopefully it made it to the bottom of the tranny without damaging anything. The slicks are not the reason it broke. Just be sure to use the correct sealant to seal the shift selector tray.
rector07 is offline
post #3 of 23 (permalink) Old 07-03-2011, 07:22 PM
_Nick_'s Avatar
Quoted: 1 Post(s)
Yeah, you might wanna pull the internals out the side of the trans case and clean out any debris. Better than breaking an input shaft though.
20G Stage 3 on E85: New data:384 hp 411 tq
"Maybe I should just stick to bolt-ons." -Hitler
I don't really want to wrench anymore. I'd rather detail.
_Nick_ is offline
post #4 of 23 (permalink) Old 07-03-2011, 07:44 PM
BoostinBen's Avatar
Quoted: 1 Post(s)
Drain the trans oil first before pulling the gearset. You may get lucky and it may come out of the drain tube. If not, yes, definitely find the piece in the transmission, even if that means removing the gearset through the driver's side wheel-well. If that piece is picked up by the gears, it will destroy gear teeth and a bunch of other shit and then you're looking at gear replacement and God knows what else which will be costly. Most of the time the piece is sitting at the bottom of the trans case but not always.
BoostinBen is offline
post #5 of 23 (permalink) Old 07-03-2011, 11:58 PM Thread Starter
Quoted: 0 Post(s)
Actually, the piece was on top, like above the gearset. I pulled it out, so I think I am good there. However, I dont know what selant to use? I was just gonna use Black RTV, or "the right stuff", but I here theres a special mopar kind
post #6 of 23 (permalink) Old 07-04-2011, 12:40 AM
SRTotM Moderator
Bad98rt's Avatar
Quoted: 1 Post(s)
DO NOT USE RTV get the sealent fron a stealership
and to prevent this QUIT SHIFTING LIKE THE HULK
Huge thanks to Chris, Bill, And Bob @MAPerformane for 95% of all my parts
Huge Thanks to Kevin Warren For.. Many many things
MAP EF4 stock block, stock head
452whp on EMS at 26 psi
100&92 octane mix
Fully built long block and big numbers coming!
Bad98rt is offline
post #7 of 23 (permalink) Old 07-04-2011, 09:20 AM Thread Starter
Quoted: 0 Post(s)
OK! Stealership it is!
Side note: Do you know what it could of been when I over reved it it ran all shitty (missing it felt like) Then, I pulled over turned it off, and it appears to be fine??
O and I have a WOT box and I may shift a wee bit to hard
post #8 of 23 (permalink) Old 07-04-2011, 10:24 AM
SRTotM Moderator
Bad98rt's Avatar
Quoted: 1 Post(s)
yeah its from shifting hard i have hundreds of WOT shifts in my car with no issues.. its not about how hard you shift its about how fast you shift
100&92 octane mix
Bad98rt is offline
post #9 of 23 (permalink) Old 07-04-2011, 10:37 AM
93stang434's Avatar
Quoted: 0 Post(s)
I could have loaded up with fuel from being on the rev limiter.
Strapped block,ion crank,JE pistons,MAP rods,cncport.com head,HVF tubular top mount.PTE dbb 6266 .82 ar,JMFab intake manifold and some other stuff=Aiming for the 10s on E85
BC co's,Hotchkiss sways,Prothane bushings,Pwerks strut bars,Mopar tension struts
93stang434 is offline
post #10 of 23 (permalink) Old 07-04-2011, 10:55 AM
_Nick_'s Avatar
Quoted: 1 Post(s)
Originally Posted by jtm0n3y View Post
"anaerobic sealant"
That's the stuff you need.
_Nick_ is offline
post #11 of 23 (permalink) Old 07-04-2011, 11:05 AM
Only1Balto's Avatar
Quoted: 0 Post(s)
Mopar Gasket Maker- red in color.
Only1Balto is offline
post #12 of 23 (permalink) Old 07-04-2011, 12:54 PM
BoostinBen's Avatar
Quoted: 1 Post(s)
Honestly I've never had a problem with high-temp RTV and I've removed that plate a ton of times. I agree with doing it right, though, because if you put too much RTV on the plate (some people cake it on), it can go into the transmission and lodge itself in oiling holes.
post #13 of 23 (permalink) Old 07-04-2011, 01:31 PM
Only1Balto's Avatar
Quoted: 0 Post(s)
^ That was my main fear~ I wasn't too sure how much or how little to put on, but as the saying normally goes- better too much than not enough, probably not so in this case though. So I dropped the cash to buy the Mopar Gasket maker just to "do it right" but also because it'll only form when compressed inbetween two metallic surfaces, other than that it remains in its thick liquid form.
<woot woot 5,015 posts!> thats funny.
post #14 of 23 (permalink) Old 10-05-2011, 01:30 PM
Boosted 254's Avatar
Quoted: 0 Post(s)
so what did it end up being?
05' ACR AGP Delta 44
e85 fed
Boosted 254 is offline
post #15 of 23 (permalink) Old 10-05-2011, 03:00 PM
Gizmodo's Avatar
Quoted: 75 Post(s)
Horsepower doesn't break shift selectors. It is in no way, shape or form related to power. It is from people not knowing how to shift as if they are reasonable human beings.
Gizmodo is offline
User Tag List
Linear Mode Linear Mode
