Old 06-28-2008, 01:40 PM   #1 (permalink)
Main_Event's Avatar
Member Number: 12790
Default Quick Question on Royal Purp ATF
So i went looking around evrywhere to get some royal purple ATF.
Finally found some at napa auto parts.
So i buy 3 qts and when i get home i realize it says "ATF"
Then remembered we use ATF-4
Does this matter if? Is it the same shit?
am i good to go? im tryna pour this shit in asap
SonyAlpha
Main_Event is offline   Reply With Quote
Old 06-28-2008, 04:51 PM   #2 (permalink)
Member Number: 65076
I did my tranny fluid about 15K ago. I used Royal Purple Synchro Max. I even called RP to be sure I was using the right stuff. I would NOT put that ATF in. Check RP's web site for more info.
HWY* is offline   Reply With Quote
Old 06-28-2008, 11:16 PM   #3 (permalink)
srtras's Avatar
Member Number: 52121
i used the max atf... its good to go
gt30r, AGP SCT tune and all supporting mods
srtras is offline   Reply With Quote
Old 06-29-2008, 12:19 PM   #4 (permalink)
SynchroMax is specially made for manual transaxels
Old 06-29-2008, 04:12 PM   #5 (permalink)
Main_Event's Avatar
how did that work out?
if napa dosen't let me return this i might just have to try it out
i do realize now that they have a separate fluid for manuel tho [syncromax]
Old 06-29-2008, 07:08 PM   #6 (permalink)
Edgehold's Avatar
Member Number: 55411
don't be stupid. If you put the atf in your tranny good luck when you have to buy a new one. If you change from the mopar atf+4, which every srt should do, you better be putting in synthetic manual tranny fluid. Syncromax.
Edgehold is online now   Reply With Quote
Old 06-30-2008, 09:22 AM   #7 (permalink)
srtras's Avatar
Main_Event - only have had mine in for about 500 miles... shifts much smoother tho. one of my buddies has been running it for 1 1/2 years now with no issues and loves it.
Edgehold - go to royal purples website it says you can use max atf
Old 06-30-2008, 10:23 AM   #8 (permalink)
stageII's Avatar
Member Number: 32588
Trader Rating: (34)
i due believe there is a reason why they make different types use your brain people and if you dont know ask there is someone on here every second of everyday they can tell you or help you find out use synthetic manual tranny fluid. Syncromax i due believe it is 75w - 90 sae 11.00 to 15.00 dollars a quart.
IF YOU GOT THE MONEY I WILL PLAY
SOME BEAT THERE CAR TO HIT 11'S I DRIVE NORMAL
All DCR:motor,Head,oil system,intake mani,throttle body/spacer,Water injection,Battery kit,Greddy boost control,Crower stage 2 cams,fidenza cam gears
Turbonetics DBB 50trim, lots more
GRANNY SHIFTING
New Best1/411.60 at 124.75 mph UNTUNED24.0psi
Best1/8 7.69 at 94.38 mph UNTUNED22psi
stageII is offline   Reply With Quote
Old 06-30-2008, 11:53 AM   #9 (permalink)
Main_Event's Avatar
yeah thats why i asked here first before i did anything
so i went back to NAPA today and tried to get a refund but apparently in MD you cant return "chemical fluids" so i was like umm ok wtf am i suppt to do with this. then he said he can do an exchange. so i was like ok can you guys plz order the synchromax and he was like
"no i cant do that" i was like umm why? and he jsut said he cant, which i thought was BS, i mean why the hell can't you?
eventually they let me exhange the royal purple with soem valvoline ATF-4 full syn
so im just going to use that = /
thanks for the help tho guys
Page generated in 0.22747 seconds with 11 queries
