Push Rod Issue quick fix!!! - Dodge SRT Forum
post #1 of 112 (permalink) Old 01-19-2011, 02:24 AM Thread Starter
Quoted: 0 Post(s)
For those of you out there that broke ur push rod and are running into issues getting a stronger one or getting the clutch pivot arm upgrade I have found a cheap solution.
I bent and snapped my push rod, so i decided i was going to go with the dcr billet push rod since only one company makes the clutch pivot upgrade (Rage-Tek) and you to have wait for it. Well I wanted my car fixed over the weekend and the DCR push rod wasnt going to be in till tuesday, so I went to advanced auto and purchased a clutch master cylinder for a 1988 Ford F350 Diesel. I took it home and pulled it apart so that I had just the push rod (its about 1.5 inches too long). I measured the F350 push rod to the srt push rod assembly and marked it on the push rod. Then I cut the F350 push rod so it matched the stock push rod. I then installed the F350 push rod with 2 washer and a E clip.
The F350 push rod is waaasssyyy thicker then the srt4 push rod, I have had it in my car so far for 2 weeks without any issues. I ran it at the track on sunday and again no issues. Seems to be holding up great. Whenever I get a chance I will post pictures so you know what im talking about.
Mods: SECRET
Low 11's maybe high 10's soon!!
jthomas123 is offline
post #2 of 112 (permalink) Old 01-19-2011, 09:27 AM
n9inety9problemz's Avatar
Quoted: 0 Post(s)
hmmm..might use this for future reference...the DCR still didnt arrive yet?? please post pics though...
n9inety9problemz is offline
post #3 of 112 (permalink) Old 01-19-2011, 02:47 PM Thread Starter
Quoted: 0 Post(s)
it got here yesterday, I will post pics up tomorrow.
Mods: SECRET
post #4 of 112 (permalink) Old 01-19-2011, 07:05 PM
illstate's Avatar
Quoted: 0 Post(s)
in for pics, ive already broken 2 pushrods
illstate is offline
post #5 of 112 (permalink) Old 01-20-2011, 01:22 AM Thread Starter
Quoted: 0 Post(s)
just got home its 3am, I will post pics when i wake up in the morning. I dont have pics of the install but i can post pics of it installed.
Mods: SECRET
post #6 of 112 (permalink) Old 01-20-2011, 07:12 AM
SRTForums Member
2011 Calendar Car
LowNSlowNeon's Avatar
Quoted: 0 Post(s)
How much was the F350 assembly though?
I ordered the DCR push rod and paid for 2 day shipping.... (got a tracking # same day) so it should be here tomorrow.
I was just about to make my own thread on it and ask if it's as simple as pulling what is left of my broken one out and pushing the new one in.
-John
LowNSlowNeon is offline
post #7 of 112 (permalink) Old 01-20-2011, 12:08 PM
LiFeGuArDrOb's Avatar
Quoted: 0 Post(s)
Please let us know. my srt has been sitting for 2 days now. I am done with this car. Going up for sale as soon as this is fixxed
I work at a golf course
LiFeGuArDrOb is offline
post #8 of 112 (permalink) Old 01-20-2011, 12:13 PM Thread Starter
Quoted: 0 Post(s)
The F350 assembly is $51 at advance auto and they carry the assembly, as for installing the DCR part its not as simple as just pulling ur old one out and pushing the dcr one in.
Here is the how to from DCR:
Remove the screw retaining the stock O.E. pushrod to clutch pedal. Take a small pick or screw driver to remove dust seal for pushrod at the master cylinder. Once the dust seal is removed, take small internal snap ring pliers and remove snap ring from master cylinder. Gently pull on O.E. push rod to slightly expose master cylinder plunger, be careful not to pull out any more than a from master cylinder to retain the fluid in the master cylinder. You just want enough exposed to gain access to metal retaining clip that attaches O.E. pushrod into plastic master cylinder piston. Once the retaining clip is slightly exposed, take 2 small screw drivers and wedge between plastic piston and metal retaining clip to remove metal retaining clip, Which removes the O.E. pushrod from piston. Push piston back into the slave cylinder to the point where you can reinstall the snap ring. Place the O.E. dust seal back into master cylinder and it can be pressed in by fingers. Now install DCR Clutch Pedal Pushrod right through dust seal into piston and attach to clutch pedal and adjust as necessary. Due to the size of the DCR Clutch Pedal Pushrod there is no room and no need for the retaining clip as the clutch pedal will keep it in place. The O.E. retaining clip is just for assembly line simplicity to keep pushrod into place.
Mods: SECRET
post #9 of 112 (permalink) Old 01-20-2011, 12:49 PM
Quoted: 0 Post(s)
Thank-you sir! Running to auto-parts store to just take the rod lol perks of buddies being managers there =]
You said washer and e-clips though, where at?
post #10 of 112 (permalink) Old 01-20-2011, 12:52 PM
Gringo3825's Avatar
Quoted: 6 Post(s)
Hit up the junk yard screw paying $51 for it. Any year ford is guaranteed to be in the junk yard. LOL!
GT35R Fully Modded:
Old numbers
On untuned base map
381hp 336tq @ 14psi
Gringo3825 is offline
post #11 of 112 (permalink) Old 01-20-2011, 01:47 PM
Maeda Path Champion
stage3matt's Avatar
Quoted: 1 Post(s)
pics?
Stage 3+
New England SRT Owners Club Association
www.nesrtoc.com
100,000 mile club
Originally Posted by turbo666 View Post
I would still rather have AIDS then a LT1. I wouldn't care if your car went low 6's on pump in the 1/4 bone stock with a Tornado.
stage3matt is offline
post #12 of 112 (permalink) Old 01-20-2011, 01:55 PM
Quoted: 0 Post(s)
Are You high? This car has made me hate chrysler more than ever. Chrysler newer cars > Ford all years in junk yard around here.
But foreal, back on topic, any pictures of your fix or even crude drawwings would be awesome. Thanks again for the idea and info
post #13 of 112 (permalink) Old 01-20-2011, 02:31 PM
rector07's Avatar
Quoted: 0 Post(s)
Hey man do you have a part number for this! I need it asap!
Look what i did today!!!
rector07 is offline
post #14 of 112 (permalink) Old 01-20-2011, 02:47 PM
SRT of the Month
2011 Calendar Car
1LAPSRT's Avatar
Quoted: 56 Post(s)
Part No. 39894
Advance Auto Parts: TECHnovation Clutch Master Cylinder by Perfection Clutch - Part 39894
Modern Performance SRT4 - Dominating the road race community for almost 10 years!
2015 MPx SRT4 Racing and Event schedule:
1LAPSRT is offline
post #15 of 112 (permalink) Old 01-20-2011, 02:48 PM
rector07's Avatar
Quoted: 0 Post(s)
Thank you man!!!
rector07 is offline
User Tag List
Linear Mode Linear Mode
