View Poll Results: When I shift into 3rd gear
It does not go in on the first try 209 20.21%
It goes in but grinds 267 25.82%
It tries to kick back out of gear 235 22.73%
It does not go in when I down shift 174 16.83%
It grinds only under WOT shifting 71 6.87%
I can't shift into 3rd when I WOT shift 127 12.28%
It makes no noise and works perfectly always 341 32.98%
OTHER... I will explain in my post and will title it OTHER 74 7.16%
Multiple Choice Poll. Voters: 1034. You may not vote on this poll
Old 04-05-2007, 07:53 AM   #451 (permalink)
05BlackSRT's Avatar
Member Number: 31129
will be going to court soon...really need a part number if somebody can get it..
-Tein S-Tech Springs
-AGP WGA
-Turbo XS MBC
-3" Cat-delete Downpipe
-K&N CAI
-Apexi Turbo Timer
-Greddy Type RS Blow off Valve and Charge Pipe
-5% Tint
-Xenon Visions 8000k HID's
05BlackSRT is offline   Reply With Quote
Old 04-06-2007, 07:52 AM   #452 (permalink)
inteleric1983's Avatar
Member Number: 46527
yeah, I have been trying to get this info as well, the dealer keeps trying to stiff me. What is your case in court? I am starting to get really irritated with DCX over this.
ALL GONE
inteleric1983 is offline   Reply With Quote
Old 04-22-2007, 12:44 PM   #453 (permalink)
Member Number: 6145
Trader Rating: (13)
Default Third gear
My car is sittin in my driveway trans blew up last night Its stuck in fifth and wont come out had problems before that
2005 Stone White ACR
SCT STAGE 3
Nuffice is offline   Reply With Quote
Old 04-23-2007, 08:54 PM   #454 (permalink)
Member Number: 44390
Is the problem with "popping" back out of third gear a syncro problem, shift fork problem, or a shift selector problem?
BWoody Performance FTMFW
Quote: Originally Posted by 05SRTFOUR
sheet son ah no dawg ah b too much fa sho so mah azz aint gat none gorgewashintinz left to bah a stg1 ya heard....so ah hadda ghetto rig mah shit.
04'E-blue is offline   Reply With Quote
Old 04-23-2007, 10:51 PM   #455 (permalink)
srt4power1's Avatar
Member Number: 40470
syncro problem.....first my shift fork broke for 3rd and 4th.....then my shift selector broke a week after i fixed the first problem...now my 3rd gear syncros are gone....my car has had so many f***ing tranny problems...its at the dealer right now getting a new one put in.
mods: s0, greddy profec b spec II 20\15, agp wga, prothane mm inserts, 180 deg thermostat, champion 570 at .034, greddy tt, ptp 3" downpipe w/o cat, custom side exit exhaust, ptp upgrade surge valve spring, ptp map clamp, ptp fpr mod, progress sport springs.
8.5 @ 90 MPH 1\8 1.9 60' on street tires....
srt4power1 is offline   Reply With Quote
Old 04-24-2007, 03:04 AM   #456 (permalink)
Member Number: 6145
Trader Rating: (13)
after taking it apart i found that my my shift selector exploded inside the transmission
Ah I love my car
Old 04-30-2007, 01:19 PM   #457 (permalink)
mex-rt4's Avatar
Member Number: 49286
sorry guys i dont have any answers but a problem myself. well i hope there is still someone monotoring this thread to help me out. I have a 2005 SRT4 with about 20,000 miles on it now. When i first got the car it grinded from time to time going into 3rd. It never popped out or did anything different just grinded from time to time. Well it stopped grinding for a few months and just a few days ago without notice my 3rd gear went out. It goes into place where 3rd gear should be at but there is nothing there. It does not grind or anything. Every other gear is perfectly fine. oh and the shift lever has alot of play now too. Any suggestions on what could have happened or how to fix it?
mex-rt4 is offline   Reply With Quote
Old 04-30-2007, 01:26 PM   #458 (permalink)
srt4power1's Avatar
you might have broken part of the shift fork off or your 3rd gear broke the welds on the shaft(only seen one case of this but it can happen) i dont think that would be a syncro problem but its possible if they desinegrated. But more than likely you broke off part of you shift fork that is used to push the fork forward to go into third....take it to the dealer they will fix it under warranty.
Old 04-30-2007, 01:29 PM   #459 (permalink)
Super Moderator
Masssilversrt4's Avatar
Member Number: 3905
welds of the shaft know another person that did this.. 3rd gear is spinning on the shaft. He got his replaced under warranty..
Hell bent on building fast cars!!!
Masssilversrt4 is offline   Reply With Quote
Old 04-30-2007, 01:30 PM   #460 (permalink)
srt4power1's Avatar
just said that
Old 05-01-2007, 12:21 PM   #461 (permalink)
mex-rt4's Avatar
hahaha thanks for the laugh and the advice fellas! i feel alot better about the whole situation now. Now i just have to spend a day in the garage taking off a few things and hopefully all will work out! I guess its just crappy luck but oh well i still love my baby
Old 05-01-2007, 01:04 PM   #462 (permalink)
srt4power1's Avatar
let us know what you find out.
Old 05-16-2007, 04:55 PM   #463 (permalink)
PimpShitKreationz's Avatar
Member Number: 41129
I have an 05' with about 45,000 and 3rd is the only gear giving me problems, if it doesnt grind going in it'll pop out. It was giving me problems way before my warranty was over just not this bad. Now im out of a warranty and these people wont fix it. I have extended warranty but I guess it didnt cover drivetrain. Am I pretty much screwed?
R.I.P Victor Valenzuela 5/16/06
"See you at the finish line cuzz!"
PimpShitKreationz is offline   Reply With Quote
Old 05-17-2007, 06:21 AM   #464 (permalink)
smokedu2's Avatar
Member Number: 35709
I had pretty much the same situation as you. My 3rd gear was doing the same thing. I had the trans rebuilt 2 months ago and now it doesnt grind under normal driving but. It falls out of gear now instead. I would start looking around at 3speed applications imo.
Mods list currently exceeds 455 characters.
smokedu2 is offline   Reply With Quote
Old 05-17-2007, 01:25 PM   #465 (permalink)
mex-rt4's Avatar
i got my car back today from Dodge and it ended up being that my 3rd gear and synchro completely broke inside the tranny and managed to not interfere with any other gear...... really weird but my car is back in business and i spent 0 dollars thanks for the info guys and good luck to everyone else having problems
