View Poll Results: When I shift into 3rd gear
It does not go in on the first try 205 20.18%
It goes in but grinds 258 25.39%
It tries to kick back out of gear 230 22.64%
It does not go in when I down shift 169 16.63%
It grinds only under WOT shifting 66 6.50%
I can't shift into 3rd when I WOT shift 122 12.01%
It makes no noise and works perfectly always 340 33.46%
OTHER... I will explain in my post and will title it OTHER 72 7.09%
Multiple Choice Poll. Voters: 1016. You may not vote on this poll
Old 07-19-2005, 05:32 PM   #1 (permalink)
SLCFast4's Avatar
Member Number: 12831
Default POLL! 2005 Tranny problems..NEW PICS ADDED!
Who is having transmission issues with their 2005's??? Please explain in detail.
Please select all that apply...!!!
I HAVE THE CHUCK MOD, AUTHORIZED BY THE CARE BEARS, WITH DETAILED INFO BY RAINBOW BRITE!!!!!!!!
Race Deck Racing
B-Spec USA
The SRT-4 is a painful, sometimes expensive, and pleasurable journey... a legal drug.
SLCFast4 is offline   Reply With Quote
Old 07-20-2005, 09:22 AM   #2 (permalink)
SLCFast4's Avatar
I'm going to use this info to make stronger parts that will eliminate this problem.. All the input I can get would be great.. Dog Box anyone??? We need to see what fails the most first..
Thanks
Old 07-20-2005, 06:41 PM   #3 (permalink)
SRToc Member
quick4dr's Avatar
Member Number: 18686
Why would 05's have more tranny problems?
04 Black SRT 12.7 @ 116 on Toyo proxies stock turbo R.I.P July 04 - Feb 08
quick4dr is offline   Reply With Quote
Old 07-20-2005, 06:49 PM   #4 (permalink)
shane0008's Avatar
Member Number: 3685
Default other
Occasionally 3rd gear feels blocked when I upshift. Happens a couple times a week, and I only drive about 500 miles a week. If I'm not paying much attention, it will grind when I get off the clutch. I have to push pretty hard to get it in.
shane0008 is offline   Reply With Quote
Old 07-21-2005, 01:06 PM   #5 (permalink)
SLCFast4's Avatar
Come on people.. This will only benifit anyone who has a problem with their tranny in the future..
Old 07-21-2005, 01:14 PM   #6 (permalink)
Stracin's Avatar
Member Number: 25102
My first gear gives me a prob sometimes. I'll have the clutch in and it will make this fast ticking sound when I push forward and then it'll kind of snap in on it's own. rarely happens though.
WHY DO THEY KEEP TAKING MY SIGS?!?!?!!?!
oliver the humanzee song
Stracin is offline   Reply With Quote
Old 07-21-2005, 01:22 PM   #7 (permalink)
Member Number: 17276
Trader Rating: (31)
Default Other
That happens to mine too. My third gear feels ok. then again my car is only 2 weeks old...
Quote: Originally Posted by mo'ssrt4
i am a free slut.
SilverSerfer is offline   Reply With Quote
Old 07-21-2005, 01:29 PM   #8 (permalink)
lnxsrt's Avatar
Member Number: 6702
heh, give it some time to break in... my tranny used to suck balls, but now that i have over 26k on it, its smooth as butter. I am running 2 qts Royal Purple Syncromesh and the rest of the tranny i filled with Royal Purple 5W-30 (less than a quart). This was accidental (didn't buy enough tranny fluid), but it seems to work real nice.
11.5mm wires
greddy full auto tt
JMB catch can and breather
mopar bov
front and rear dc sports strut tower bars
mopar sts w/booger
mpx shift knob
agp motor mounts
jlm tranny mount
bdj's no cat 3" side-exit
jmihalchik's 2nd O2 eliminator mod
MaxxFab 3" O2 Housing
agp wga
needswings MBC 17psi down to 15psi
Denso Iridium ITL20
JMB 3" SR Intake
180 tstat
LFS 60MM TB/ADPTR
lnxsrt is offline   Reply With Quote
Old 07-21-2005, 02:17 PM   #9 (permalink)
Member Number: 22255
when i try shifiting into 3rd gear i need to match my RPM's very closely or else it will grind and kick me out of gear same thing happends when i down shift! also under WOT shifts it does not let me select 3rd gear, no matter what i do, it just won't go in!
oh and lnxsrt.... how do u like gentoo? ive heard good things but haven't gotten around to trying it, i currently run slackware, and have used debian, rock, and various other distros... any of them similar?
Oompa Loompas??
MycelItiva is offline   Reply With Quote
Old 07-21-2005, 02:34 PM   #10 (permalink)
lnxsrt's Avatar
Member Number: 6702
love it, used it for over 2 years now. I would say its a cross between debian and slack, definietly more barebones then the big distros. I like it because of the control I have over the build process of packages. As long as you have a fast computer and don't mind compiling stuff, its really good.
Old 07-21-2005, 09:55 PM   #11 (permalink)
Member Number: 28019
Default other
mine blocks me out of third sometimes. other times, it feels like it clicks in halfway. as long as i keep the clutch depressed and pressure on the shifter it will go the rest of the way in.
i also have a problem with second gear. it feels notchy a majority of the time and grinds occasionally.
mahkis is offline   Reply With Quote
Old 07-21-2005, 10:31 PM   #12 (permalink)
yellowRS's Avatar
Member Number: 4817
Quote: Originally Posted by SLCFast4
I'm going to be giving this INFO to a performance shop who is going to be making some stronger parts to eliminate this problem.. All the input I can get would be great.. Dog Box anyone??? We need to see what fails the most first..
Thanks
Our tannys need a stronger input shaft, I and a few others have already sheared one off.
yellowRS is offline   Reply With Quote
Old 07-22-2005, 10:02 AM   #13 (permalink)
Member Number: 20986
I only have problems with mine when I'm WOT shifting. 1st->2nd is fine, 2nd->3rd it wont go in and i wind up coming off the clutch, going wot, and then just bounch off the rev limiter because it never went into 3rd. If I take that extra second to really make sure its in third though, it goes in fine.
Neothin is offline   Reply With Quote
Old 07-22-2005, 12:03 PM   #14 (permalink)
BoostedNeon04's Avatar
Member Number: 17485
mine grinds third if u dont go slow as hell,it it grinds third during wot shifting,it grinds every single time unless u go slow..and it also wont go in sumtimes and also will pop right back out at u
sold^
BoostedNeon04 is offline   Reply With Quote
Old 07-22-2005, 08:53 PM   #15 (permalink)
Member Number: 25353
Mine worked fine for the first 7k miles or so but now almost every shift into 3rd, WOT or not it grinds. It goes in tight but that is expected with my Maddog STS and Booger bushings. My clutch also squeals when I WOT into any gear.
newSRT-4 is offline   Reply With Quote
