Just picked up a srt today, mine is doing the exact same thing, it like rattles when you turn it off, and it does not rattle as much with your foot on the clutch when you turn it off. it also makes noise when running until you press the clutch.
Quote: Originally Posted by
wisetechscott
hey guys, so i just put in an ACT clutch with the lightweight flywheel and an act TOB and i noticed that when the car is sitting at idle you can hear a rattle coming from the trans and it stops when you push the clutch in... so is it just the TOB like when the car turns off and makes noise so should i be more concerned and take the bell housing cover off and investigate?... and the car runs great plenty of power.. has 4 passes on new clutch and probably over 300 miles of road use.. and nothing else is of any problem .. just that it makes this noise
thanks guys, i appreciate the thought
