Old 06-09-2008, 02:10 AM   #1 (permalink)
AWH
AWH's Avatar
Member Number: 45591
Default Need Part Number - Clutch Pedal Problem!
I wonder if this has happened to anyone else:
I was driving my car the other day and all of the sudden I heard this snapping sound every time I pressed the clutch pedal and I could barely get the car into gear. I sync-shifted my way home and immediately checked it out. I noticed that a black plastic "clip" connected to the pin protruding sideways (to the left) from the upper part of the clutch pedal had become partially detached. It appears that the bushing on the clip wore out and won't stay on the pin. The other end of this clip connects (with a small nut & bolt) to a rod that pushes the clutch when you step on the pedal.
I put it back into place and it popped off again. It won't seem to "click" into place. I temporarily strapped it in with wire ties until I can fix it properly and it works fine.
My question: Does anyone know the part number for this clip? I would like to replace it myself if possible.
- 2003 SILVER SRT4
- MOPAR CAI, MOPAR EXHAUST, MOPAR STS, MOPAR PERFORMANCE CLUTCH
- GRANATELLI MS 0-OHM WIRES, BOSCH PLATINUM +4 pLUGS
- MODS COMING SOON: MOPAR STAGE 1, MPx THROTTLE BODY, AGP WGA.
AWH is offline   Reply With Quote
Old 06-13-2008, 08:59 PM   #2 (permalink)
BigMac's Avatar
Member Number: 18060
I believe it's 06035334. IIRC someone on here sells a billet replacement too.
2004... ..ARL ~ CGS ~ GWA
BigMac is offline   Reply With Quote
Old 06-17-2008, 08:49 PM   #3 (permalink)
Member Number: 37284
I have the same problem. Im on my 4th clip. They are like 8-10 bucks here for that damn clip.
Big Mac... you have any more info on that ??
SRT4chris2005 is offline   Reply With Quote
Old 06-17-2008, 08:53 PM   #4 (permalink)
Ghowie's Avatar
Member Number: 33090
Trader Rating: (55)
rage sells them
Originally Posted by dansrt4
For a shop thats so behind maybe you should catch up on orders before you catch up to me.
Ghowie is offline   Reply With Quote
Old 06-18-2008, 05:55 AM   #5 (permalink)
AWH
AWH's Avatar
Quote: Originally Posted by Ghowie View Post
rage sells them
Can you give us a link to that site?
Old 06-18-2008, 12:24 PM   #6 (permalink)
dodge2004srt4's Avatar
Member Number: 18024
Trader Rating: (37)
You can get it from Advance Auto Parts in the help section, it costs $5.98 for a set of 5 and only one will work. Its labeled as clutch pivot bushings and has 5 white bushing inside with the one being identical. Im looking into seeing if mine is breaking for some other reason but I just put one in last week and this one broke the same way. The new one wasnt doing a good job staying in place so Im thinking they are breaking because maybe the eyelet is cracked or worn.
Chris.
11.59 @ 121.29 MPH 1.84 60ft
Stage 3 Methanized....coming soon
My mods require a DCR security clearance!
dodge2004srt4 is offline   Reply With Quote
Old 06-19-2008, 09:51 PM   #7 (permalink)
BigMac's Avatar
I guess this is it:
RAGE-TEK :: Drivetrain/Shifter :: Rage-tek Clutch pedal pivot upgrade
Page generated in 0.14587 seconds with 13 queries
