jtm0n3y's tranny rebuild thread/how-to - Page 4 - Dodge SRT Forum
 6Likes
post #46 of 241 (permalink) Old 04-28-2010, 10:07 PM
srt4nathan's Avatar
Quoted: 0 Post(s)
dam how much to have you assembl this for me but seriously lol, looking to get my trans fixed
srt4nathan is offline
post #47 of 241 (permalink) Old 04-29-2010, 07:43 AM Thread Starter
SRT of the Month
jtm0n3y's Avatar
Quoted: 2 Post(s)
PM'ed
jtm0n3y is offline
post #48 of 241 (permalink) Old 04-29-2010, 02:20 PM Thread Starter
SRT of the Month
jtm0n3y's Avatar
Quoted: 2 Post(s)
Input shaft assembly continued
Fifth gear can now be installed. Take note of the circle below, this is the direction that the gear gets installed onto the shaft.
This gear has to be pressed on so you will only be able to push it on so far. When installed as far as it can go by hand this is what it will look like.
Place the entire assembly into a shop press as shown CAREFULLY.
MAKE SURE that the blocker rings line up with the notches in the synchro as circled.
Slowly begin applying pressure to press the gear all the way on until it stops. When pressed on it will look as pictured below.
Now you can thread the 5th gear nut on snug by hand.
Place the entire input shaft assembly in the V-Clamps of the vise the same way as described in the very first steps. Place an adjustable wrench on the nut and torque it tightly.
Now get a mini sledge and a punch as pictured.
Place the punch on any section on the collar of the nut between the teeth of the gear and hit it hard and firm with the sledge to place a dimple in it.
Do this in three different spots around the nut.
The input shaft is now complete.
jtm0n3y is offline
post #49 of 241 (permalink) Old 04-29-2010, 08:50 PM
BOOSTINSRT04's Avatar
Quoted: 0 Post(s)
Good info JT! Keep the pics and writeup coming!
BOOSTINSRT04 is offline
post #50 of 241 (permalink) Old 04-30-2010, 02:44 PM Thread Starter
SRT of the Month
jtm0n3y's Avatar
Quoted: 2 Post(s)
3/4 shift fork assembly
This is fairly simple, you only need to pound out one roll pin. The punch in the picture below works best for doing this, however, you can use anything that will basically fit in the hole and pound the pin out.
Place the fork rail assembly in a vise as shown. Tap out the pin circled below.
Once the pin is tapped out the end piece can be slid off from the rail as well as the old 3/4 fork. Slide the new one on in the same orientation.
Once the pin is tapped back in this is what it will look like.
jtm0n3y is offline
post #51 of 241 (permalink) Old 04-30-2010, 02:48 PM Thread Starter
SRT of the Month
jtm0n3y's Avatar
Quoted: 2 Post(s)
Shift extender installation
I didn't get many pictures of this process. The picture below shows what two pins need to be tapped out. The bigger pin is in there tight so don't be afraid to hit it pretty good with a mini sledge. Once the two pins are tapped out the entire rail can be slid out that goes through the shift extender as well as the shift selector. Place the new extender in place of the old one. You can also install the selector at this time if you have a new one needing to go in.
This is what it looks like completed and put back together.
jtm0n3y is offline
post #52 of 241 (permalink) Old 04-30-2010, 02:52 PM
2011 Calendar Car
NoisufnoC's Avatar
Quoted: 4 Post(s)
great write up.
I remember the days of...
...most of you weren't born yet.
|| Mod List || RIP Mod List || (Re)Build Thread ||
|| Blog || Mr. November #3 ||
NoisufnoC is offline
post #53 of 241 (permalink) Old 04-30-2010, 02:54 PM Thread Starter
SRT of the Month
jtm0n3y's Avatar
Quoted: 2 Post(s)
Thanks dude!
jtm0n3y is offline
post #54 of 241 (permalink) Old 05-02-2010, 02:48 PM
Linez01's Avatar
Quoted: 0 Post(s)
are u able 2 replace the tob fork without taking out the tranny case?
Linez01 is offline
post #55 of 241 (permalink) Old 05-02-2010, 03:37 PM Thread Starter
SRT of the Month
jtm0n3y's Avatar
Quoted: 2 Post(s)
Yes you can, the video on the first page shows you how to take the internals out without taking the tranny out of the car.
jtm0n3y is offline
post #56 of 241 (permalink) Old 05-03-2010, 05:51 AM
SRT4nier's Avatar
Quoted: 0 Post(s)
ahhh... You have to take the case off to get to the TOB fork.
2004 Black SRT-4
160K +
SRT4nier is offline
post #57 of 241 (permalink) Old 05-03-2010, 06:49 AM
Linez01's Avatar
Quoted: 0 Post(s)
so i can or cant ..lol!!
Linez01 is offline
post #58 of 241 (permalink) Old 05-03-2010, 09:58 AM
2011 Calendar Car
CONROY's Avatar
Quoted: 0 Post(s)
you have to remove the tran case to remove the TOB fork.
CONROY is offline
post #59 of 241 (permalink) Old 05-03-2010, 12:08 PM Thread Starter
SRT of the Month
jtm0n3y's Avatar
Quoted: 2 Post(s)
the transmission does not have to be removed from the car...the video on page two explains how to get the internals out without removing the trans.
jtm0n3y is offline
post #60 of 241 (permalink) Old 05-03-2010, 12:30 PM
BoostingSnail's Avatar
Quoted: 2 Post(s)
He wants to remove the Throw Out Bearing fork.....you arent going to pull that through the case since it is inside the bellhousing.
AGP & DCR hardware & driver energized by VEGASFUEL Energy Drink
564hp & 504ft/lb trq
11.23 @ 127.89
"Never Underestimate The Power Of Stupid People In Large Groups"
BoostingSnail is offline
User Tag List
Linear Mode Linear Mode
