jtm0n3y's tranny rebuild thread/how-to - Page 3 - Dodge SRT Forum
 6Likes
post #31 of 241 (permalink) Old 03-29-2010, 04:32 PM Thread Starter
SRT of the Month
jtm0n3y's Avatar
Quoted: 2 Post(s)
ALL PARTS FINALLY HERE!
Got the input shaft together on saturday along with 49 high quality pics!
Complete how-to coming soon!!!
Pics of the PWerks 3/4 shift fork and 3rd gear shift extender added to post #2.
jtm0n3y is offline
post #32 of 241 (permalink) Old 03-29-2010, 06:10 PM
BoostingSnail's Avatar
Quoted: 2 Post(s)
I gotta feeling this how-to is going to persuade more people to tackle their own tranny jobs rather than outsource the work.
AGP & DCR hardware & driver energized by VEGASFUEL Energy Drink
564hp & 504ft/lb trq
11.23 @ 127.89
"Never Underestimate The Power Of Stupid People In Large Groups"
BoostingSnail is offline
post #33 of 241 (permalink) Old 03-29-2010, 06:55 PM Thread Starter
SRT of the Month
jtm0n3y's Avatar
Quoted: 2 Post(s)
Vendors are going to hate me
jtm0n3y is offline
post #34 of 241 (permalink) Old 04-02-2010, 05:18 PM Thread Starter
SRT of the Month
jtm0n3y's Avatar
Quoted: 2 Post(s)
everything will be done this weekend guys
here's a little preview...
jtm0n3y is offline
post #35 of 241 (permalink) Old 04-03-2010, 01:15 AM
Tweaked05's Avatar
Quoted: 0 Post(s)
How much did it cost for all the parts minus the PC? I am thinking about rebuilding, but have a limited budget.
AEM Wideband, Scan Gauge, CAI, Injen 3" TB Exhaust, Godspeed FMIC, Hard Pipes, Ebay BOV, DS Intune,
the SRT-4 is a lot more fun and makes much better happy noises
Tweaked05 is offline
post #36 of 241 (permalink) Old 04-03-2010, 08:05 AM Thread Starter
SRT of the Month
jtm0n3y's Avatar
Quoted: 2 Post(s)
I have quite a bit into it...i did the PC myself. roughly 2300
jtm0n3y is offline
post #37 of 241 (permalink) Old 04-03-2010, 09:36 AM
rebellionyst's Avatar
Quoted: 0 Post(s)
Subscribed. I have a feeling I might need to rebuild here soon...
rebellionyst is offline
post #38 of 241 (permalink) Old 04-11-2010, 07:22 PM
Quoted: 2 Post(s)
bump for an update on progress...how's it goin?
11.23 @ 127.89
post #39 of 241 (permalink) Old 04-11-2010, 10:11 PM Thread Starter
SRT of the Month
jtm0n3y's Avatar
Quoted: 2 Post(s)
Been super busy with work. Everything is pretty much done all the pictures are taken i just have a little more typing to do. I'm really happy with how everything came out and I hope this helps all of you!
jtm0n3y is offline
post #40 of 241 (permalink) Old 04-11-2010, 10:15 PM
Quoted: 0 Post(s)
the pc looks badass dude.
SRT4sum is offline
post #41 of 241 (permalink) Old 04-11-2010, 10:59 PM Thread Starter
SRT of the Month
jtm0n3y's Avatar
Quoted: 2 Post(s)
Thanks dude! It was well worth all the time i put into it!!
jtm0n3y is offline
post #42 of 241 (permalink) Old 04-13-2010, 10:04 PM
jross1038's Avatar
Quoted: 0 Post(s)
this is going good i cant wait for the end turn out. its going to be sweet
jross1038 is offline
post #43 of 241 (permalink) Old 04-28-2010, 09:00 PM Thread Starter
SRT of the Month
jtm0n3y's Avatar
Quoted: 2 Post(s)
Input shaft assembly
First I'm going to explain how to get the 5th gear nut off. People seem to have problems with this step and not a lot of people have a spare junk clutch hub lying around they can use. This method is very easy and totally safe.
Before you can take the nut off you need to grind the pinch points off that lock it into place on the gear. I used a dremel (9901 Tungsten Carbide Cutter) to do this. Don't be worried if you knick the gear when you're grinding back on the nut. Any knicks will be covered by the new nut.
Find access to a vise the has the V-Clamp setup (circled) like the one pictured below.
Place the shaft into the V-Clamp so that both "V's" are going to be applying pressure to only the splined part on the end of the shaft. Apply enough force that the shaft stays straight out and doesn't spin back and forth. As you're tightening the vise turn the shaft in a circular motion so that the teeth on the V's lock into the grooves of the splines on the end of the input shaft. Don't be afraid to apply a moderate amount of force when tightening...you're not going to damage anything or gouge the splines. The following couple of pics are self explanatory for visual reference.
Next get an adjustable wrench and place it on the nut. Use a long piece of scrap wood or a baseball bat and hit the handle of
the wrench hard and fast to break the nut loose QUICKLY. You can then thread the nut the rest of the way off with ease.
Now onto assembly of the input shaft
The first thing that gets installed onto the shaft is the thrust washer.
Slide the washer down the shaft and take a pair of vise clamps and work your way around the washer until it's seated all the way around tight against the gear. To get the washer to initially go over it's place on the shaft you may have to clamp down on one side of the washer and gear and use a punch to tap the other side of the washer over the shaft. You can then proceed to work your way around to seat the washer.
Once installed correctly this is what it will look like.
Next is the third gear needle bearing. Just slip it over the shaft until it sits on the thrust washer as pictured.
Onto third gear. Slip in onto the input shaft oriented as shown and slide it over the needle bearing you just installed.
When installed it will look like the pictures below. I took them from different angles so you can be sure you have everything right.
The third (or fourth...they're the same/reversible) gear blocker ring comes next which is part of your synchronizer assembly. It only goes on one way really...teeth facing down towards third gear so that it fits over the taper of the gear.
When installed it will look like this. Disregard the circle for now.
Onto the 3/4 synchro itself. Look at the picture below and take note of the two valleys that the arrows are pointing to where there are no splines. These two areas line up and go over the oiling holes on the input shaft that are circled in the picture above. It is CRUCIAL that you line these two grooves up with the holes or you'll burn your new synchro up real fast.
Slide the synchro down over the splines on the input shaft being sure everything lines up then you can install the 3/4 synchro snap ring. To install the snap ring (easily anyways...) you're going to need to tool below.
Use this tool to pry open the snap ring and slide it down the input shaft. Snap the ring into place.
When installed everything will look as pictured below.
Next is the fourth gear blocker ring. This gets installed teeth facing up so that when you install fourth gear it fits over the taper.
Take note of the pictures below because they apply to third gear as well as now. The blocker rings need to line up with the grooves in the synchro itself. This is also crucial further along in this tutorial when you press 5th gear on the shaft.
Next slide the fourth gear needle bearing onto the shaft until it hits the 3/4 synchro snap ring.
It will look like this when done.
Fourth gear comes next. Slide it on and down over the needle bearing that you just installed.
Input shaft assembly continued on next page
jtm0n3y is offline
post #44 of 241 (permalink) Old 04-28-2010, 10:07 PM
SRT-Diesel's Avatar
Quoted: 0 Post(s)
If you dont mind me asking, how much did all this run you?
SRT-Diesel is offline
post #45 of 241 (permalink) Old 04-28-2010, 10:20 PM Thread Starter
SRT of the Month
jtm0n3y's Avatar
Quoted: 2 Post(s)
Little over 2,300 dollars for everything.
jtm0n3y is offline
User Tag List
Linear Mode Linear Mode
