Old 12-22-2005, 11:00 AM   #1 (permalink)
hydrohopper's Avatar
Member Number: 11900
Trader Rating: (37)
INFO: The SRT-4 T850 5-Speed Manual Transmission
The manual transmission that is in the SRT-4 is the NV T850 5-speed transmission. It is a constant-mesh manual transmission that is synchronized in all gear ranges, including reverse unlike the T350 transmission, that is in all 1.6L 2.0L and 2.0 R/T cars, that isn’t synchronized in reverse. The T850 transmission consists of three major sub-assemblies; the input shaft, intermediate shaft, and differential assembly. The transmission shift system consists of a mechanical shift cover, rail, forks, and cables. The unique design of the transmission verses the others provides a higher mechanical advantage, resulting in less friction and lower shift cable loads for smoother, more positive operation. Lubrication throughout the transmission is from splashed oil collected in case passage and oil trough and distributed to mainshafts via gravity. You should ONLY use ATF+4 (Automatic Transmiision Fluid – Type 9602) and if completely empty also use 4 oz of Mopar Limited Slip Additive/Frisction Modifier. The 5 speeds of the transmission are determinded by each speed’s gear ratio. Here are the gear ratios for the T850:
Also with the 04 & 05 year models you have the Quaife Automatic Torque Biasing Limited Slip Differential (LSD). The LSD is a performance oriented unit which is designed to provide traction to both wheels during all driving condtions. Our LSD is a design that behaves like an open differential during normal driving situations. During aggressive driving maneuvers (straight line hard acceleration, hard cornering) it senses which wheel has better grip, and switches power to that wheel smoothly and consistently, without removing power from the other wheel. In technical terms, torque bias is generated by the axial and radial thrusts of the pinions in the pockets. The resultant friction force enables the driving road wheel and sun gear to transmit a greater proportion of the torque. This is a progressive action, yet at no stage will the differential ever lock. This differential also controls loss off traction when the drive wheels are on slippery surfaces, providing the appropriate traction needed to overcome these conditions of wheel slip
Removal –
1. Begin under the hood by removing the turbocharger solenoid pack from the air cleaner assembly. These are the 3 solenoids.
2. Disconnect the IAT sensor and remove the air cleaner assembly. For those of you with aftermarket intake you know what to do.
3. Remove the cold side pipe (from the intercooler to the TB)
4. Disconnect the IAC and TPS connectors.
5. Disconnect accelerator cable from the throttle body linkage.
6. Remove throttle body adapter
7. Remove the battery
8. Remove the battery tray
9. Disconnect shift cable from the transmission shift levers and bracket
It will be necessary to drain transmission fluid. Remember that you will need to add fluid.
10. Remove both front tires
11. Disconnect and remove both ABS front wheel speed sensors
-- You will now have to remove the driveline half shaft--
Some info: The SRT-4 has an equal length half-shaft system that incorporates two halfshafts assemblies that (in expert terms) consists of an inner and outer constant velocity (CV) goint and a solid interconnecting shaft, and an intermediate shaft/bearing assembly or (in simple terms) the axels. The halfshaft assemblies, or axles, are designed to transmit power from the transmission to the front wheels.
Halfshaft System:
1. You should already have both front tires removed at this time.
2. Remove the cotter pin, nut lock, and spring washer, and hub nut from the end of the outer CV joint stub axle. See Fig. 13
3. Now remove the nut and bolt retaining the ball joint stud into steering knuckle. See Fig. 14 **Note: Be careful when separating ball joint stud from the steering knuckle, so ball joint seal doesn’t get damaged.
4. Separate ball joint stud from steering knuckle by prying down on lower control arm. See Fig 15
5. Remove the halfshaft from the steering knuckle by pulling outward on knuckle while pressing in on halfshaft. Support outer end of halfshaft assembly. See Fig 16
Some transmission fluid may leak when you pull the axles out.
6. Support outer end of the halfshaft assembly. **Note: Removal of the inner joints is make easier if you apply outward pressure on the joint as you strike the punch with a hamper. DO NOT PULL ON INTERCONNECTING SHAFT TO REMOVE, AS THE INNER JOINT WILL BECOME SEPARATED.
7. Removing halfshaft(s). Left halfshaft: While applying outward pressure on joint by hand, dislodge inner tripod joint from differential side gear by striking outward with a punch. When removing tripod joint and shlfshaf, do not let spline or snap ring drag across axle seal. Right halfshaft: Slide inner tripod joint off of intermediate shaft. If difficulty is encountered, dislodge join from intermediate shaft using punch. If intermediate shaft is to be removed, remove two intermediate shaft bearing to bracket bolts. See fig 17.
You now resume the process of removing the transmission
13. Disconnect the clutch hydraulic circuit “quick-connect” fitting. See fig13
14. Disconnect back-up lamp switch connector. See fig. 14
15. Remove the starter. See fig 15
16. Remove the lateral bending brace. See fig 16
17. Disconnect the hot side pipe that bolts to the power steering lines and remove the two bolts that are hold the power steering lines.
18. Remove the structural collar. See Fig 19
19. Now be prepared, this is when the transmission will come loose from the engine. Another jack will be necessary to support the weight of the transmission.
20. Remove the four clutch-to-engine bolts. While removing the bolts, one tight-tolerance hole will be encountered. When the bolt is removed, mark driveplate (flywheel) and modular clutch assembly at this location, and be sure to align marks upon reassembly. See Fig 20
21. Now secure the transmission jack
22. Remove let mount through bolt
23. Lower engine/transmission assembly enough to gain access to left mount and bellhousing bolts.
24. Remove left mount-to-transmission bolts. Remove mount. See Fig 21
25. Now you should install another jack to support the weight of the engine after the removal of the transmission.
26. Remove transmission bell housing bolts; remove transmission and modular clutch assembly.
Mopar Stage 3R with Toys
2004 Flame Red SRT-4
Turbocharged 2.4L DOHC I4 HO
hydrohopper is offline   Reply With Quote
Old 12-22-2005, 11:01 AM   #2 (permalink)
Trader Rating: (37)
Default The SRT-4 T850 5-Speed Manual Transmission Part 2
Installation -
1. Install the clutch to the input shaft.
2. Side the transmission into place and install the transmission-to-block bolts. Torque = 80 ft.lbs
3. Install the upper mount bracket to the transmission. Torque = 50 ft. lbs.
4. Raise the engine/transmission assembly into position and install and torque through-bolt. Torque = 90 ft. lbs.
5. Now install the four modular clutch-to-driveplate bolts. Align driveplate and modular clutch alignment marks placed on from disassembly. Start with the tight-tolerance (slotted) hole. Torque = 65 ft. lbs. See Fig. 77
6. Install the structural collar and lateral bending brace. Torque for structural collar (horizontal bolts) = 80 ft. lbs. Torque for structural collar (vertical bolts) = 80 ft.lbs. Torque for lateral bending brace bolts = 45 ft.lbs.
7. Install the hotside intercooler pipe and power steering hoses into position and secure with the nuts.
8. Connect clutch hydraulic plumbing to slave cylinder quick-connect. You should hear a click.
--Now you will install the Halfshaft System—
1. If removed, install intermediate shaft/bearing assembly. Install bearing-to-bracket bolts. Torque = 40 ft.lbs See Fig. 17
2. Install halfshafts. Left halfshaft: Make sure to clean the spline and oil seal sealing surface on left tripod join. Lightly lubricate oil seal sealing surface on tripod joint with fresh clean transmission lubricant. While holding the halfshaft assembly by tripod joint and interconnecting shaft, install tripod joint into transmission as far as possible. Then carefully align tripod joint with transmission side gears. Then hold the halfshaft interconnecting shaft and push tripod joint into transmission side gear until fully seated. Make sure that the snap ring is fully engaged with side gear. Right halfshaft: Again clean the joint spline, as well as the intermediate shaft spline. While holding halfshaft assembly by tripod joint and interconnecting shaft, install tripod joint onto intermediate shaft as far as possible by hand.
3. Clean all debris and moisture out of the steering knuckle.
4. Slide halfshaft back into front hub. Install steering knuckle onto the ball joint stud. See Fig 25
**Note: At this point, the outer joint will not seat completely into the front hub. The outer joint will be pulled into hub and seated when the hub nut is installed and torqued.
5. Install a NEW steering knuckle to ball joint stud bolt and nut. Torque = 70 ftlbs. See Fig 70
6. Clean all dirt from threads of halfshaft outer stub axle. Install washer and hub nut onto the threads of the stub axle and tighten nut. Torque = 180 ftlbs. See Fig. 26
9. Install spring washer, nut lock, and cotter pin
10. Put the front wheels and tires back on
11. At this time you are going to check all fluid levels in the transmission. If you completely emptied that transmission casing of fluid use the following; Add 4 oz of Mopar Limited Slip Additive/Friction Modifier and up to 2.4-2.6 qts or Mopar ATF+4 until fluid is with barley below fill hole.
12. Now install gearshift cable to transmission bracket.
13. Install battery tray.
14. Install battery.
15. Install throttle body adapter housing
16. Connect accelerator cable while installing throttle body into position. 17. Install the two throttle body-to-manifold bolts. Torque = 250 inlbs
18. Connect IAT & TPS Sensors
19. Install the cold side intercooler pipe.
20. Install all remaining items that are left.
If anyone sees any changes that need to be make or added let me know and I'll edit.
Old 12-22-2005, 11:07 AM   #3 (permalink)
shawn_40312's Avatar
Member Number: 27290
Trader Rating: (15)
awsome info, definately a sticky/how to
Autometer Pro-Comp 35psi boost gauge
Perrin 3in.Turbo back exhaust
Rolled bumper mod
Denso Iridium Plugs
MSD 8.5mm Plug Wires
17x7 ASA AR1's
Tein S Tech 1.8F/2.0R
$20 Oil Catch Can
Quote: Originally Posted by Zer0
i got pwned by a turbo geo metro so i sold my lebaron!
shawn_40312 is offline   Reply With Quote
Old 12-22-2005, 11:09 AM   #4 (permalink)
Wheels & Tires Moderator
evo77's Avatar
Member Number: 1346
So you just basically copied and pasted this out of the service manual?
revival of the 50? we'll see...
Old 12-22-2005, 11:54 AM   #5 (permalink)
warman's Avatar
Member Number: 27317
Its good info for those of us who dont have service manuals.. so thanks for the copying and pasting if thats all it was.
warman is offline   Reply With Quote
Old 12-22-2005, 11:57 AM   #6 (permalink)
Trader Rating: (37)
The exact how to, yes. Other information is from personal experience and gathered information from others. I also wanted to have some pictures added to be able to give others something to look at.
Old 01-15-2006, 06:49 AM   #7 (permalink)
darcside's Avatar
Member Number: 26402
Thank you very much for posting this info.
I just saved a ton of money on car insurance by fleeing the scene of the accident...
darcside is offline   Reply With Quote
Old 01-15-2006, 08:05 AM   #8 (permalink)
SRToc Member
kadishack63's Avatar
Member Number: 381
that looks like it is right out of the dcx techconnect software we use. i was just using that stuff a few weeks ago when i did my clutch at work. very helpful info
2008 Dodge Ram 2500 Megacab 4x4 Cummins Turbo Diesel. Edge Juice w/ Attitude, TS Performance MP8, 5 inch turboback, AFE Megacannon intake, Carli Starter Sytem Suspension Lift and custom H.I.D. Projector Headlamps
kadishack63 is offline   Reply With Quote
Old 01-15-2006, 09:10 AM   #9 (permalink)
thispainisourz's Avatar
Member Number: 21668
Trader Rating: (23)
same software i have.. anyone with a srt4 should invest in this .. saves the trouble of posting threads asking for help...
thispainisourz is offline   Reply With Quote
Old 01-15-2006, 09:24 AM   #10 (permalink)
Sota227990's Avatar
Member Number: 31159
Trader Rating: (10)
The manuals were available online not too long ago. I woulda thought everyone had snatched a copy of them by now.
. . . . the Kid . . . . . . . . . . . the Car . . . . . . . . . . . the Bike . . . . . . . . . . the Toy . . . . . .
And my real name is George Carlin.
First to use the phrase Suicide by Toll Booth
sig limits SUCK!
Sota227990 is online now   Reply With Quote
Old 03-08-2006, 09:28 PM   #11 (permalink)
ACR MAN's Avatar
Member Number: 23252
This part was basically copied from the DaimlerChrysler Technical Training book used in the FWD manual trans class. Whoever copied it made a couple of minor modifications to the wording, though.
ACR MAN is offline   Reply With Quote
Old 03-26-2006, 01:29 PM   #12 (permalink)
ayoungblood's Avatar
Member Number: 7132
subscribing
2k4 Srt-4 -- Stock
ayoungblood is online now   Reply With Quote
Old 03-26-2006, 04:32 PM   #13 (permalink)
Trader Rating: (37)
This info was directly from the manual. I put this info together for the forum so others could view this. Not everyone has the manual. I figured that it would be good info to anyone wanting more information.
Old 04-05-2006, 11:18 AM   #14 (permalink)
Jattsrt4's Avatar
Member Number: 36263
Is this manual free and where can you get it. Thanks.
Jattsrt4 is offline   Reply With Quote
Old 04-24-2006, 09:12 PM   #15 (permalink)
Member Number: 29336
Trader Rating: (50)
T-850= piece of shit.
the end.
phucough is offline   Reply With Quote
