Old 01-17-2008, 08:17 PM   #31 (permalink)
chingo_boost_05's Avatar
Member Number: 58452
one of my friends told me to get the AGP shift selector, that way you wont rip the shit out of your gears....
chingo_boost_05 is offline   Reply With Quote
Old 01-24-2008, 05:15 PM   #32 (permalink)
Member Number: 9221
Trader Rating: (19)
how about if you get locked out of a gear?
GO FAST PARTS
Stock PCM
AGP 44# delta
Diablo predator
Dtec FC
FIC 625cc injectors
AGP returnline
PTP 55mm TB
PTP check valve
ED hardpipes w/ HKS BOV
Maddog STS 72%
AGP motor mounts
Zeitronix ZT2 wideband
Needswings DP (no cat)
180 thermostat
Bwoody H-brace combo
Bwoody Trans mount
AnotherNeon is offline   Reply With Quote
Old 02-14-2008, 03:55 PM   #33 (permalink)
Tony35's Avatar
Member Number: 61633
Trader Rating: (23)
Yeah i had the same problem its the syncros and after a while the gears go bad. i went to the dealership and got it fixed. my cars there now and they orded 18 parts including syncros and gears so they do cover it.
AGP .50 Trim w/ Supporting mods.
Tony35 is offline   Reply With Quote
Old 02-14-2008, 08:20 PM   #34 (permalink)
SRT of the Month
Darksyde's Avatar
Member Number: 37254
Trader Rating: (195)
New stage 2 pwerks transmission with agp shift selector.
New south bend stage 3 clutch.
New clutch master cylinder.
New slave.
New tob fork.
New pivot and clip.
New axle seals.
Its all in and Ill be installing it saturday woot woot!!!
Im done screwing around with this old trani
476whp/466tq
Darksyde is offline   Reply With Quote
Old 02-15-2008, 12:34 PM   #35 (permalink)
Tony35's Avatar
Trader Rating: (23)
Quote: Originally Posted by DublinCheesehead View Post
I must say I'm a bit disappointed if that's what my issue turns out to be. I suspected as much, but I'm still surprised given my driving habits. Anyone have any luck getting this problem covered under warranty?
Yeah i just had 18 parts covered in my tranny from syncros to gears and the forks. they had my car for about a week and i got the clutch done too but the clutch is the only thing i paid for.
Old 02-15-2008, 06:44 PM   #36 (permalink)
YoNkErZsRt4's Avatar
Member Number: 43878
i had my tranny rebuilt....still no luck....still notchy in second gear....they replaced the slave/master cylinder.....its notchy in reverse also....i checked the adjustment on the clutch pedal i'm not sure if i'm checking for the crossover right?....i loosen the the lil nut moved the shifter....only thing that helped a lil was taking out the mopar sts....i put the old one in goes into 3rd like butter....still funky in those two gears......when they had the tranny out i should of just changed the clutch...but they said it was fine...and the tob fork was fine.....only thing it could be is the clutch or a stupid lil adjustment? any info on checking the crossover let me know
YoNkErZsRt4 is offline   Reply With Quote
Old 03-20-2008, 11:49 AM   #37 (permalink)
andre81400's Avatar
Member Number: 27232
Default clutch
my problems are when im wot i can't get into third and forth and when the car's hot i have trouble getting into 1st and reverse but when the car's cold gears shift perfect
mods:
injen intake
stage 1
agp dog bones
greddy oil catch
apexi turbo timer
apexi neo
rippmods returnline
boomba fuel rail
rc 750 injectors
3" turbo back exhaust (ssautocrome)
kenetic wastgate
286 whp 350 tq
andre81400 is offline   Reply With Quote
Old 03-20-2008, 12:44 PM   #38 (permalink)
andre81400's Avatar
Default ok
i did the forth gear thing and my rpm's shot up and the car bearly moved so is that a sign of a slipping clutch and if so what else should i get done when replacing the clutch
Old 10-15-2009, 12:34 AM   #39 (permalink)
Member Number: 74989
what if the while the clutch pedal is released and the car is in neutral u hear a grinding noise and it feels like it is trying to grab a gear anyway??? but if u press down the clutch pedal the noise stops??
tpierce is offline   Reply With Quote
Old 10-15-2009, 09:09 PM   #40 (permalink)
m_dunnie's Avatar
Member Number: 593
Trader Rating: (32)
Sounds like the engagement of your clutch is the culprit, hence your clutch system needs investigating.
Gummybear One Lap Of Atlanta - 2008
Cannonball One Lap Of America - 2004/2005
SRT Nationals - 2004/2005/2006/2007/2008
m_dunnie is offline   Reply With Quote
Old 11-02-2009, 05:31 PM   #41 (permalink)
evo77's Avatar
Member Number: 1346
How often do TOB forks go bad?
I've already replaced TWO in the past 2 years and from the grinding noise I heard this morning from my clutch pedal after shifting, it appears I have ANOTHER fork issue. What is going on???
S2 no toys, Mopar bov, AGP bfmic, 3" turboback
Old 11-04-2009, 06:42 PM   #42 (permalink)
godlikehatch's Avatar
Member Number: 74521
i actually just bought the cryo treated fork from ptp hoping it will hold up longer than the stock one
godlikehatch is offline   Reply With Quote
Old 11-04-2009, 10:21 PM   #43 (permalink)
Member Number: 53240
yea i rebuilt my tranny 5k ago..new:
-3/4 gears/sycros/shift forks
-act clutch
-new oem tob/clutch fork/pivot ball
-royal purple max atf
second gear has been real notchy lately i dunno whats up,i remeber the rp fluid it real thin like oil compared to the oem fulid that is real thick
60ft.2.1 (street tires)
mph:101.54
sri,s2kit,tbe,fm.wga,sts,act clutch,wb,scangauge,30/30 boost gauge,hks bov,ed charge pipe,solid mounts.
Killasrt444 is offline   Reply With Quote
Page generated in 0.15653 seconds with 13 queries
