What suspension mods do you have? meagan racing lowering springs... two sets were with stock suspensoin
How many times have they failed? 4 times.. fixing to be 5
Replaced by Dodge? every time... but over warrenty now
Driving style? Somewhat agressive but not abusive!
standard 50 trim, intake, 3in dp, rc 750's, ngk wideband, fmic, msd wires, safc ii, cooling mist w/m injection, ptp stage 3 clutch,cp pistons, eagle rods, arp head studs,and dcr head gasket... best time is 11.8 118 on 24psi
I just had to change my axle for the 5th time..Dealer put the first one in after my accident. Then, the next day I hit it in first and the car jerked to the right side almost off the road. Come to find out, the dealer put the axle in wrong and when I hit it, the axle came out of the tranny. And the dealer changed them up to this last one that I had to buy for $86 from the dealer.
-Tein S-Tech Springs
-AGP WGA
-Turbo XS MBC
-3" Cat-delete Downpipe
-K&N CAI
-Apexi Turbo Timer
-Greddy Type RS Blow off Valve and Charge Pipe
-5% Tint
-Xenon Visions 8000k HID's
I build c/v axles at work and am wondering where the srt axles break typically? I have yet to break one and I have 52k miles, an easy 50 passes at the track and who knows how much wheel hop abuse on the street.
I'm in the Same boat as you but I back off when i get the wheel hopping...I've got 65 passes down the track and 45k miles. Don't want to break one though...
my axles failed and had already been on their way out when i left the dealership with the car a couple weeks ago. i wasnt sure what the problem was but there was an intense vibration and wobble while accelerating. the dealership decided to order both axles from modern performance (oem). after the install the vibration is gone and i can finally floor it every once in a while without fearing an axle breaking or something. im not sure which side was the problem but i think it might have been both sides because when i did the tire spin check both sides made clunking noise when i spun them.
by the way i have an 04 srt-4.
What suspension mods do you have? BC Racing coilovers, Hotchkis sway bars, Werks STB's
How many times have they failed? Once
Replaced by Dodge? Negative
Driving style? Mostly cruising but aggressive when needed
The car was bought new in June 2005. S3 w/toys was put in November 2005. So far it has racked up 117,000 miles. I have 250+ time slips (mainly on slicks) plus countless pulls on the streets. My first broken axle happened this past weekend when I did a second gear pull from 40 mph. Two seconds after I got on the gas, the driver side axle broke at the bearings near the transmission.
-Fastest, quickest, and most powerful SRT-4 in the universe
8.43M whp, ∞ wtq
1.01 @ 1546.23 mph (2.4 60 ft stock BFG KDW's & boost leak )
100% bone stock factory freak
