Old 09-16-2007, 02:21 PM   #181 (permalink)
Member Number: 46152
take them to court,small claims
Mods: Stage 1,Perrin Cai,Agp wga,Agp Motor mounts,needswing V5 dp,ebay BFMIC,$ 20 catch can,Koyo rad,Dtec Fc,Aem wideband.
petemac is offline   Reply With Quote
Old 10-18-2007, 08:33 AM   #182 (permalink)
srtsofgadsden's Avatar
Member Number: 49842
What year is your car? 05
How many miles? 36k
What suspension mods do you have? meagan racing lowering springs... two sets were with stock suspensoin
How many times have they failed? 4 times.. fixing to be 5
Replaced by Dodge? every time... but over warrenty now
Driving style? Somewhat agressive but not abusive!
standard 50 trim, intake, 3in dp, rc 750's, ngk wideband, fmic, msd wires, safc ii, cooling mist w/m injection, ptp stage 3 clutch,cp pistons, eagle rods, arp head studs,and dcr head gasket... best time is 11.8 118 on 24psi
srtsofgadsden is offline   Reply With Quote
Old 10-19-2007, 02:47 AM   #183 (permalink)
Member Number: 42189
How many miles? 36k
Holy Crap...That seems like a fair number of times to be breaking those things, what exactly are you doing to them?
13.9 @ 101.2mph...We'll get faster yet.
www.moparmen.ca
SilverBeast is offline   Reply With Quote
Old 10-25-2007, 08:15 AM   #184 (permalink)
lol nothing really... just the track about every other weekend and the street races every now and then... nothin to bad i am pretty easy on my car
Old 10-26-2007, 03:25 PM   #185 (permalink)
05BlackSRT's Avatar
Member Number: 31129
I just had to change my axle for the 5th time..Dealer put the first one in after my accident. Then, the next day I hit it in first and the car jerked to the right side almost off the road. Come to find out, the dealer put the axle in wrong and when I hit it, the axle came out of the tranny. And the dealer changed them up to this last one that I had to buy for $86 from the dealer.
-Tein S-Tech Springs
-AGP WGA
-Turbo XS MBC
-3" Cat-delete Downpipe
-K&N CAI
-Apexi Turbo Timer
-Greddy Type RS Blow off Valve and Charge Pipe
-5% Tint
-Xenon Visions 8000k HID's
05BlackSRT is offline   Reply With Quote
Old 03-04-2008, 09:24 PM   #186 (permalink)
stealth2669's Avatar
Member Number: 41725
I build c/v axles at work and am wondering where the srt axles break typically? I have yet to break one and I have 52k miles, an easy 50 passes at the track and who knows how much wheel hop abuse on the street.
stealth2669 is offline   Reply With Quote
Old 03-05-2008, 03:00 AM   #187 (permalink)
I'm in the Same boat as you but I back off when i get the wheel hopping...I've got 65 passes down the track and 45k miles. Don't want to break one though...
Old 03-15-2008, 11:35 PM   #188 (permalink)
Member Number: 51815
my axles failed and had already been on their way out when i left the dealership with the car a couple weeks ago. i wasnt sure what the problem was but there was an intense vibration and wobble while accelerating. the dealership decided to order both axles from modern performance (oem). after the install the vibration is gone and i can finally floor it every once in a while without fearing an axle breaking or something. im not sure which side was the problem but i think it might have been both sides because when i did the tire spin check both sides made clunking noise when i spun them.
by the way i have an 04 srt-4.
moparx12 is offline   Reply With Quote
Old 03-19-2008, 02:32 PM   #189 (permalink)
shiby3041's Avatar
Member Number: 43864
What year is your car? 2004
How many miles? 32k
What suspension mods do you have? Tein Springs
How many times have they failed? Once
Replaced by Dodge? Did it myself, not a hard job
Driving style? I daily drive it to work, and have only tracked it two or three times on stock tires. 1/4 mile and Autocross but mostly im good to her
I was mad when they started clicking, this has never happend at such low miles on any of my cars. I thought it might have just been me
shiby3041 is offline   Reply With Quote
Old 05-08-2008, 10:57 PM   #190 (permalink)
mooseman0's Avatar
Member Number: 45861
Trader Rating: (10)
What year is your car? 2005
How many miles? 32k
What suspension mods do you have? mopar stage 1 springs
How many times have they failed? twice
Driving style? pretty aggressive driver... 1st time snapped launchin at the track on slicks and 2nd snapped pullin out of gas station normal driving
05 srt4
SC61 ..je pistons eagle rods,dcr oil pump kit windage tray and crank scraper,tk motorsports timing belt and head gasket,fpr and return,rc750s,crane 14s,crane valve springs,fidanza cam gears,stage 1 pcm,max fabb exhaust, rpm tb,agp race fmic,mopar cai,screamin demon coil and plug wires,agp ic pipe,hks bov,perrin fuel rail,agp mm's,ss brake lines,18's..
mooseman0 is offline   Reply With Quote
Old 06-05-2008, 01:45 PM   #191 (permalink)
Member Number: 64079
How many miles? 54k
What suspension mods do you have? None!
How many times have they failed? failing now (clicking and clunking during turns)
Replaced by Dodge? Nope
Driving style? Raced when needed babied otherwise except on very few occasions
WBCSRT is offline   Reply With Quote
Old 06-06-2008, 03:31 AM   #192 (permalink)
How many miles? 54k
you sure it is the axles? Could be a busted sway bar bolt or some other suspension piece....
Old 06-28-2008, 06:56 AM   #193 (permalink)
RSchyns's Avatar
Member Number: 2019
Trader Rating: (17)
What year is your car? 04 - Build date 9/03 - had the '03 axles
How many miles? 56k
What suspension mods do you have? None except ES LCA bushings.
How many times have they failed? 1 time
Replaced by Dodge? No. Did them myself
Driving style? Somewhat aggressive but not abusive!
Symptoms were side to side wobble when accelerating, Driver side axle was bad. Replaced them both.
Also replace the lower control arm ball joint boot/seal, cracked due to dry rot.
Car was running on S1 for two years, just went back to stock pcm.
RSchyns is offline   Reply With Quote
Page generated in 0.22043 seconds with 12 queries
