Old 04-08-2008, 05:27 PM   #1 (permalink)
Wheels & Tires Moderator
evo77's Avatar
Member Number: 1346
Default How to properly torque axle nut?
My torque wrench only goes up to 150 ft lbs. My impact gun goes to 220 ft lbs.
The axle nut needs to be torqued to 180 ft lbs. I used the gun to torque the nut but I have no way of knowing how much torque it actually applied.
Is there a easy way of knowing or checking with the tools I have without having to buy another torque wrench?
My biggest fear right now is that I slaved over changing out these damn wheel bearings and I'm afraid they'll go bad again if these axle nuts are not properly torqued.
Old 04-08-2008, 05:30 PM   #2 (permalink)
95neonman's Avatar
Member Number: 37749
I usually just snug them tight with an impact. Never had a problem.
12.04@119 agp dbb 50trim w/sct
95neonman is offline   Reply With Quote
Old 04-08-2008, 05:30 PM   #3 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (24)
Unfortunately, I don't see a way you can properly check without a torque wrench. It sucks, but if you want it done right, its what you have to do.
Old 04-08-2008, 05:44 PM   #4 (permalink)
evo77's Avatar
Member Number: 1346
I wasn't sure if there was some calculative method for torquing based on turns.
Like if I did 150 ft lbs, would another quarter turn or half turn equal another 35 ft lbs?
Old 04-08-2008, 05:54 PM   #5 (permalink)
Philth's Avatar
Trader Rating: (24)
Honestly, I dont think it would turn from 150 -180... if it did very very little.
Old 04-08-2008, 05:55 PM   #6 (permalink)
Discussion/Performance Mod
NoisufnoC's Avatar
Member Number: 136
yeah, find a wrench that'll go to 180.
omgz!! i haz mods!!
NoisufnoC is online now   Reply With Quote
Old 04-08-2008, 05:58 PM   #7 (permalink)
JdM2UsDm's Avatar
Member Number: 47984
Trader Rating: (18)
Rft..
New project
2003 Lexus IS300 pearl white
5-speed manual W/ LSD
Boost coming soon!!!
2005 Stone White (traded )
266WHP 320TQ
Stock turbo 19psi spike 16psi redline S1, 650cc, afc neo, cai, 3" tbe, slipping clutch everything else stock.
JdM2UsDm is offline   Reply With Quote
Old 04-08-2008, 05:59 PM   #8 (permalink)
SRToc Member
Pit Viper's Avatar
Member Number: 339
Trader Rating: (66)
set the impact gun on "kill", and don't worry about it.
Old 04-08-2008, 06:39 PM   #9 (permalink)
SpeedEuphoria's Avatar
Member Number: 30870
agree
Project log pics
SpeedEuphoria is online now   Reply With Quote
Old 04-08-2008, 08:02 PM   #10 (permalink)
2Spools's Avatar
Member Number: 18960
Trader Rating: (17)
150 and give it a little snug and don't worry about it.
Stage3 turbo/Stock pcm 11.58@124 JANNETTY RACING SCT TUNED
www.turboaddictionparts.com
2Spools is offline   Reply With Quote
Old 04-08-2008, 09:42 PM   #11 (permalink)
Pimpazzberetta's Avatar
Member Number: 29361
Trader Rating: (40)
I've asked the same question before. Everyone told me give it hell. The bearing design will stop it from getting over tightened.
Mopar Stage 3R w Toys 388.8 WHP 425.5 WTQ
Mopar CAI,Mopar BOV,S3 C/O's,AGP S3 WGA
SBC 5X,TC BFMIC / t bolt clamps, 55 mm TB, Maxxfab 3" o2,3" catless DP,Injen 3" catback, FBM intake mani
NGK 4306 @ .033, Devils Own W/I w controller
UEGO, Greddy TT, Ultra Lite II 30/30,Scan Gauge
DC Sports STB, MM inserts, Boomba trans mount
LCA, strut tension, Booger bushings,CV,18" Konig's,TCS, D/S Rotors
Pimpazzberetta is offline   Reply With Quote
Old 04-09-2008, 12:30 PM   #12 (permalink)
evo77's Avatar
Member Number: 1346
Thanks guys.
Oh and thanks Pimpazz. I saw a post you made a few weeks ago about a clunking noise and you suggested the ball joint pinch bolt. After putting everything back together after the wheel bearing install, I had that knock. I made sure both pinch bolts were torqured to the specified 70 ft lbs but I still had the knock. Torqued them to 90 ft lbs and knock was gone.
Old 04-09-2008, 12:44 PM   #13 (permalink)
Member Number: 2096
Blast that shit with an impact while holding the axle to keep it from turning. You'll be fine if the it's a decent impact. You still have a cotter pin there as extra safety in the event that it comes loose to keep it from spinning off the axle. You won't be able to over-tighten that nut without knowing something isn't right though.
xmdfmk7x is offline   Reply With Quote
Old 04-09-2008, 02:59 PM   #14 (permalink)
NoisufnoC's Avatar
Member Number: 136
great advise
there are torque specs for certain things for a reason
Old 04-09-2008, 04:46 PM   #15 (permalink)
Quote: Originally Posted by NoisufnoC View Post
great advise
yeah but on many things torque specs are for dummys, like a couple of people that snaped VC bolts. I dont torque things like waterpumps,VC's,accessory mounting brackets,Axle nuts, strut bolts, motor mounts, ect.. Most of them just get snug, not super human tight(except for the axle nut which I hit with the impact)
