Old 02-24-2006, 08:48 AM   #1 (permalink)
Member Number: 30423
Default how long does it take to change a clutch
i'm getting my clutch replaced tomorrow in my neon and was wondering how long it usually takes for it be be completed
i need an srt-4
reduceallpain is offline   Reply With Quote
Old 02-24-2006, 10:35 AM   #2 (permalink)
mike@revitup's Avatar
Member Number: 23192
Depends on the shop. It takes me about 4 - 5 straight hours, but thats working straight through with no complications and taking my time making sure everything is right and rotating correctly. I also can't help but clean up some of the random problems I see wether it be bad vacum lines, bad wiring, etc.
mike@revitup is offline   Reply With Quote
Old 02-24-2006, 10:35 AM   #3 (permalink)
MrCleanSRt4's Avatar
Member Number: 5785
Trader Rating: (29)
Default Super easy as far as FWD clutches go
Super easy as far as FWD clutches go.
I would sat 3 hrs max with a lift at a properly equipped shop...
3-6 hours in a driveway......depending on your skill.. and how many people are helping.
A good friend of mine is a mechanic...he can knock it out in 1.5 hours....no really.
Remeber your going to lose youtrans fluid, and your going to need to get new fluid + friction modifier from the dealer.
DO NOT USE ANYTHING BUT MOPAR ATF+4 & MOPAR FRICTION MODIFIER...PERIOD.
MrCleanSRt4 is offline   Reply With Quote
Old 02-24-2006, 10:37 AM   #4 (permalink)
SRToc Member
Pit Viper's Avatar
Member Number: 339
Trader Rating: (66)
If you're doing it yourself, and it's the first time you've done one, expect it to take the whole day. with friends. And 2 good jacks.
Old 02-24-2006, 02:50 PM   #5 (permalink)
RUDEF2's Avatar
Member Number: 24170
x2
yep yep
60/48mm Garrett turbo, PowerPaq, Wideband, Profec B Spec II boost controller, Stage 1 ECU, Ingen Intake, 3" full custom exhaust, AIS intercooler, RFL BOV, 52mm TB, Fuel kit (regulator, stainless return fuel lines), 255 walbro fuel pump, 750cc RC injectors and injector clips, Clutchmasters Stage 4 clutch, 18" hyperblack wheels with Goodyear Eagle F1s, Eibach springs
RUDEF2 is offline   Reply With Quote
Old 02-24-2006, 02:53 PM   #6 (permalink)
Member Number: 11681
Trader Rating: (96)
first time lift or jack stands plan on 6+ hours....
Fastest stock turbo no n2o in the country.
Best 60 1.662
Best 1/8 7.55/93
Best 1/4 11.865/116
Best MPG 28.1 city/33 highway
Old 02-27-2006, 01:18 PM   #7 (permalink)
Member Number: 19937
Trader Rating: (37)
It took me 4 days.......working 2 hours a day.
dubgunit is offline   Reply With Quote
Old 02-28-2006, 02:14 AM   #8 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (554)
4 hours and that included tearing down the tranny to see what was wrong with i(complete tear down). I would say for your first time it should take all day and take your time.
Page generated in 0.20960 seconds with 13 queries
