Old 06-14-2006, 02:56 PM   #1 (permalink)
Supporting Vendor (Bronze)
SRT4_Night_Rider's Avatar
Member Number: 28848
Default Help think somethings wrong with Axles or Tranny!!
Well lately when i start off in first gear and ease into the gas i here a little klunk, i thought maybe it was one of my motor mounts that was loose so i checked them and nothing. So then i started to spin the passenger side wheel back and forth and you hear klunk klunk klunk. I dont know what it could be. Anyone got any input? I really want to know what it is.
STAY TUNED TO SEE WHAT HAPPENS TO THE LOOK MY CAR
Garret 60-1
XtremeBoost Manifold
STS 60mm TB
Ported TB Spacer
RC 750 Injectors
PTP 80psi FPR Mod
180 T-stat
Walbro 255 Fuel Pump
Mopar STS
Mopar Stage 1
8.5 Plug Wires
3" Downpipe
Fighters Grarage Hardpipes W/Greddy typeS
ARP Head Bolts
QuickWhips Intercooler
Dogbone Motor Mounts
SAFC & AEM Wideband
SRT4_Night_Rider is offline   Reply With Quote
Old 06-14-2006, 03:22 PM   #2 (permalink)
Anyone??
Old 06-14-2006, 05:52 PM   #3 (permalink)
Member Number: 24942
axles can be shot so something in the suspension is shot
it would not be the tranny...
~ Nitrous Oxide is like a hot girl with STDs,
you wanna hit it so bad, but your afraid of the consequences. ~
Ravadud338 is offline   Reply With Quote
Old 06-14-2006, 06:01 PM   #4 (permalink)
SRTGallardo's Avatar
Member Number: 39792
Mine has a click when I reverse or take off in first at times. I'm thinking clutch cuz if I really feather the clutch I hear nothing.
Any Car > WRX's > Ford's
Basic Stage 1
SRTGallardo is offline   Reply With Quote
Old 06-14-2006, 06:26 PM   #5 (permalink)
That is the same as me if i really feather it i dont hear the noise, but if i just kinda drop it out it klunks.
Old 06-15-2006, 09:39 AM   #6 (permalink)
ayoungblood's Avatar
Member Number: 7132
Trader Rating: (15)
I kinda have the same thing... 10 posts down titled "Weird clunk...."
2k4 Srt-4 -- Stock
ayoungblood is offline   Reply With Quote
Old 06-15-2006, 09:49 AM   #7 (permalink)
Mopar Event Specialist
Dale Seeley's Avatar
Member Number: 150
If it only does it after changing directions, or starting out for the first time, the safe money is bet on the passenger side upper motor mount, the vertical bolt through the rear of the mount.
Remove the front (horizontal) bolt if the rear bolt is tight, the front bolt could be broken.
For the orginal poster, if you hear a noise when turning the wheel by hand (rotating, not steering) the safe money is on the axle, outer CV to be more specific.
If it is heard when steering, or going over speed bumps, it's the control arm bushings.
If it is heard at random times, usually at initial acceleration and braking, retorque the lugnuts.
Street Ricers Unite! We've been persecuted too long.
Dale Seeley is offline   Reply With Quote
Old 06-15-2006, 10:10 AM   #8 (permalink)
My bet was on the control arm bushings. Polyurethene here I'm coming back for ya.
Old 06-15-2006, 10:54 AM   #9 (permalink)
Member Number: 7132
Trader Rating: (15)
ty! Will check them... again
Old 06-16-2006, 11:48 PM   #10 (permalink)
bryant's Avatar
Member Number: 6232
there is also a little play in the lsd so when you wiggle the wheels back and forth there is a little clunk.
Bryant
2004 e-blue nsrt4 stage 3
2008 silver csrt4 stage 0
bryant is offline   Reply With Quote
Old 06-17-2006, 11:29 AM   #11 (permalink)
Member Number: 27745
I am having the exact same problem....Does it do it if you jack the car up and while it's in gear you move the wheel back and forth it clunks... on mine it's on the driver's side... I notice also when you let off you can feel the clunk in the steering wheel too. Wasn't lug nuts, wasnt wheel bearing, so either tranny or control arm bushings I guess. If I find out what it is I will let you know.
MODS// aem 3" sri, 180 t-stat, greddy RS bov, 3" turbo back exhaust w/dowpipe, RC 750cc injectors, safc2, AGP 3147 turbo, walbro 255lph fuel pump, catchcan, perrin fmic, agp dogbone motor mounts, aem uego wideband No more n20 for me. Best et to date 11.62@125.6 slicks and 110
N20_srt is offline   Reply With Quote
Old 06-17-2006, 08:01 PM   #12 (permalink)
tazdevilxxi's Avatar
Member Number: 24282
Trader Rating: (25)
You know i have the same problem friday night i went out to the strip and i made about 11 runs on my beet up street tires and didnt do to bad but my problem was that i just got new mm inserts not use to that much stiffness so i had to adapt intead of an 1800rpm launch i feathered the clutch till i was in second and still had alot os wheel hop but by the last run i noticed i had a klunk every time i would accel boost/no boost i felt it in the floorboard i got it home today and looked for anything loose nothing then i thought could the motor mounts have something to do with it after about 4hrs of hopeing it wasnt the tranny and looking around and thought check them it coulnd hurt. I have to tell you they werent loose as hell but i gave the top and bottom a good crank and the sound is gone ill be going to do the tranny bolt and the center mm tommorrow they must have vibrated themselves out i hope my info helps
tazdevilxxi is offline   Reply With Quote
Old 06-18-2006, 12:39 PM   #13 (permalink)
Member Number: 150
Punctuation is your friend, well it's our friend anyway. Perhaps someone should introduce you to him...
Old 06-18-2006, 05:42 PM   #14 (permalink)
Trader Rating: (25)
Punctuation is your friend, well it's our friend anyway. Perhaps someone should introduce you to him...[/quote]
It alright just showing what the cause and effects are if it helps then it was good info tell you whai it the last time i post issues on the forums Th anx
Old 06-18-2006, 06:14 PM   #15 (permalink)
I'm still scared it's the tranny, I checked the side motor mount's and they are good checking the tranny mount under the battery today, but what is this center mount you speak of???
