Old 06-03-2008, 06:08 AM   #1 (permalink)
Boosted_SRT's Avatar
Member Number: 60014
Default Having problems getting in to all gears!!!
Hey guys, i have had my maddog 60% reduction short shifter for 4 months now. I have never really had any problems with it. It used to go in to every gear quiet smoothly. I went to the track 2 weeks ago or so and had a few runs. I took it pretty easy though all my shifts were nice and smooth apart from one time where i did not get it in to 2nd succesfully and there was some grinding. Over the past few days i been noticing it goes harder in to every gear while driving. Sometimes its hard to get it OUT of a gear, and other times its hard to get it IN to gear. It has been getting worse and worse. Now here is the thing. While the car is off it goes in to every gear as smooth as a whistle. However if the car is running it gets much harder to go in to gears. What could the problem be? Im guessing its not even the shifter its self but something beyond that?
Thanks for the help!!!
Boosted_SRT is offline   Reply With Quote
Old 06-03-2008, 07:20 AM   #2 (permalink)
Member Number: 58344
Default happened to me too
Kind of the same thing happened to me and it got fixed by regulating the clutch pedal a lil up...there a lot of threads all over this forums talking about that some of them say that wat I did is bad to the car but I'm very happy that I'm getting in all my gears like butter again....anyways I'm getting ready to buy a new clutch since I'm still with the stock one....good luck man I hope this helps and I really hope is not ur tranny .
albesrt is offline   Reply With Quote
Old 06-03-2008, 07:43 AM   #3 (permalink)
Marc's Avatar
Member Number: 12688
Hmm, I know i have a similar issue. I have a maddog 80% shifter and when I was doing the install of the maddog, messed up my shifter cable and had to install a new set. During the install, I noticed the shifter cable was twisted and just simply twisted it so the bushing could be attached. Didn't think much of it until I started getting on it with the srt and noticed I was missing 2nd a lot. I would shift for 2nd and it felt like it wasn't even there. Issue got worse the harder I got on it in 1st. So now I am convinced it's just my shifter cable and I am going to take it off the tranny side and inside the car and twist the one cable.
Marc is offline   Reply With Quote
Old 06-03-2008, 07:51 AM   #4 (permalink)
Supporting Vendor
Maddog's Avatar
Member Number: 5932
Trader Rating: (540)
It sounds as if your synchros are beginning to let go. This is fairly common with these transmissions due to DCx being cheap and putting in fluid(s) that can eventually cause the breakdown of the fibroid synchros.
I will be changing over to Mobil1 10W40 High Mileage engine oil this weekend (this formula still has the SL additive) to get the ATF and friction modifier out of the trans.
Maddog STS Great Decals -->House of Grafx
Complete Short Throw Shifters sold here! 50% to 80% overall throw reduction! Custom work available!
PM or email Chuck@maddogsts.com for more information.
'05 Stone White - a few mods...
Maddog is offline   Reply With Quote
Old 06-03-2008, 08:21 AM   #5 (permalink)
wiggyx's Avatar
Member Number: 58107
Trader Rating: (28)
Huh? Are saying you're going to be putting 10w40 in the transaxle?
To the OP, try changing the trans fluid. The ATF+4 with modifier breaks down over time because of the modifier. I run Mobil1 75w90 synth gear lube, no modifiers. Works beautifully.
Click the pic to buy a Shifty!
Old 06-03-2008, 08:55 AM   #6 (permalink)
i put in the atf+4 with modifier only 5 months ago or so...
and where can i get the mobil1 75w90...is it available most places with an automotive dept?
Old 06-03-2008, 09:01 AM   #7 (permalink)
I just looked this stuff up and found 2 key points.
- Not recommended for automatic, manual or semiautomatic transmissions for which engine oil or automatic transmission fluids are recommended.
- Mobil 1 Synthetic Gear Lubricant LS 75W-90 is recommended for use in modern high performance automobiles like SUV's, Vans and Light duty trucks requiring API GL-5 and MT-1 level performance
are you using this on your SRT-4?
Old 06-03-2008, 12:02 PM   #8 (permalink)
wiggyx's Avatar
Trader Rating: (28)
Yep, and I use/used it in all 3 DSM's that I own/owned over the years. If you do a search you'll see plenty of people use and swear by it. And yes, you can get it at any auto parts store like Advanced or Auto Zone.
Old 06-03-2008, 12:24 PM   #9 (permalink)
so i top it up on its own, no additive, nothing else? How much is needed anyways so i know how much to buy?
thanks!
Old 06-03-2008, 02:33 PM   #10 (permalink)
wiggyx's Avatar
Trader Rating: (28)
thanks!
I believe it's 2.6 quarts. I'll check the service manual when I get home to make sure. So you'd need 3 bottles.
Old 06-09-2008, 04:39 PM   #11 (permalink)
ok this is really weird, some days it feels better than other days, sometimes nice and smooth other days very hard to get between gears. i notice the higher the rpms are the harder it is to shift, especially after driving a while. however when i start off in the morning its pretty smooth...weird
Old 06-09-2008, 06:38 PM   #12 (permalink)
alphaoneoak's Avatar
Member Number: 35970
Trader Rating: (12)
I having the same symptoms here. Tried to change my tranny fluid, but that didnt seem to help.
Im probably going to take it to dealer to see if they check if its my synchros or tob... just need a nice da(its raining of course here in the northwest) to try and reproduce the problem for them.
Mods: Stage 2, PTP SST, PTP Exhaust Manifold, PTP WGA, PTP Fuel Rewire, PTP Check Valve, PTP 3" O2 Housing, ED 3" Race Pipes, NGK Wideband, AEM TruBoost, SAFC II, Injen SRI, NGK Plugs, Taylor Wires, PTP Heat Shield, AeroForce Pro Scan Gauge, Apexi TT
Bwoody Motor Mounts, CCA FMIC, HKS BOV
alphaoneoak is offline   Reply With Quote
Old 06-09-2008, 08:07 PM   #13 (permalink)
what tranny fluids have you tried so far?
Old 06-10-2008, 04:31 AM   #14 (permalink)
G-rex's Avatar
Member Number: 64620
im havin the same prob guys some days its easy some its harder. usually pretty hard goin in second after ive revved it pretty high. also reverse is a biotch to get into sometimes im a big guy and i still have to literally two hand it.
G-rex is offline   Reply With Quote
Old 06-10-2008, 05:36 AM   #15 (permalink)
Member Number: 64709
Hey guys i also have the same problem. But i have noticed that i only have a really hard time getting into any gear once the car gets hot. Most of the time when i have the a\c on. It's almost as if the clutch isn't lettin go.
Italianracing05 is offline   Reply With Quote
