#1 (permalink) |
![]() Join Date: Oct 2011
Member Number: 86725
Here are the parts I have replaced to remedy and/or counteract the problem, alas the problem still exists.
ACT HDSS clutch Mopar pivot ball Rage-Tek shifter bushings Rage-Tek billet pedal pivot Maddog solid shifter base bushings DCR modified TOB fork DCR billet pushrod Mopar slave and master cylinder When the car gets hot, it is a bitch to get into gears at times, 1st and Reverse are virtually impossible. I usually have to shut the car off to put it in Reverse. When the vehicle is cold, it goes in all gears no problem at all. This tells me the problem is heat related. I have flushed my transmission multiple times to find absolutely NOTHING unusual - No particles, or material at all what-so-ever. I am at a loss and sick of throwing money at the car. A point I wanted to make since Ive driven his car and noticed the issue too:
When you try to go into reverse you get locked out and you can feel the car bump itself back a little bit.
2005 PVK w/ GWA
Forward Motion E1, LCR ported & polished manifold, Tial 38mm wastegate. Powered by: E-85 Tuned by Dave, aka Duster360 ![]() Last edited by Shadow; 12-07-2012 at 11:22 PM. |
| Sponsored Links | |||
Advertisement | |||
#3 (permalink) |
Funny you say that.. I was going to purchase the materials and do it, but I figured - My master and slave are less than 2 months old. How soft could a plastic line really get?
I'll observe it after my drive to work tomorrow. Thanks for the reply!
2005 PVK w/ GWA
Forward Motion E1, LCR ported & polished manifold, Tial 38mm wastegate. Powered by: E-85 Tuned by Dave, aka Duster360 ![]() |
#4 (permalink) |
![]() Join Date: Mar 2012
Member Number: 88421
I don't know, I'm sure that clutch makes it more sensitive to heat though.
The previous owner put a heavy duty clutch in my cousins jeep cherokee and it did the same thing, it would get good and hot and the clutch wouldn't disengage at all. New master/slave/and line (looks like the same material as the SRT4 line). He gave up put a stock replacement pressure plate back in and its normal now. The stock line really didn't like that heavy duty clutch.
#6 (permalink) |
^Mine too, I assumed it was from the oil being thick as it clears up when the engine gets good and warm. Its sort of a bitch to drive like that, I'm glad I don't have to drive it in the winter
#7 (permalink) |
I may just try that then. Like I said, the car shifts perfect when it's cold. I can go into all of the gears no problem. I don't mean cold outside, I mean the components on the vehicle are not up to operating temperature.
As soon as I take a nice drive, (to work for example), and everything gets up to temperature, it's a lost cause trying to get into gears - Especially those with a higher ratio like 1st and Reverse.
2005 PVK w/ GWA
#8 (permalink) |
![]() Join Date: Mar 2008
Member Number: 62675
When my car got hot it wouldnt go into 1st and grind in 3rd. I bought the AGP 3rd gear extender from modern performance and that solved my issue. oh and i replced the pivot assembly with the rage one also bought from modern.
This too shall pass
#9 (permalink) |
I'm not grinding at all, and that extender doesn't with help reverse. Different issues here. If you read, I have the pivot already.
2005 PVK w/ GWA
#10 (permalink) |
![]() Join Date: Jul 2009
Member Number: 73847
Like they said, stainless clutch line and be sure to run some good DOT4+ fluid.
Also if you have not done it try adjusting the crossover adjustment when everything is at opporating temperature... I know it sounds stupid but just try it. |
#11 (permalink) |
Also if you have not done it try adjusting the crossover adjustment when everything is at opporating temperature... I know it sounds stupid but just try it. Yep, I was almost a non-believer in the stainless clutch line, but at this point I can't think of anything else it could be, given the circumstances of when the problem occurs. I have adjusted the crossover while at operating temperature a few times, not a stupid suggestion at all. Thanks for the reply!
2005 PVK w/ GWA
#12 (permalink) |
I have adjusted the crossover while at operating temperature a few times, not a stupid suggestion at all. Thanks for the reply! I meant stupid as in alot of people adjust it when its cold, not realizing that when metal and oil for that matter heats up it swells and could slightly throw off the crossover. 90% of the time adjusting it cold works fine but that other 1 out of 10 cars... lol And no problem man |
#13 (permalink) |
Fresh Meat Moderator
![]() Join Date: Dec 2009
Member Number: 76568
![]() Diablo CMR tuner ~Dan~ 2004 Black Neon SRT4: E85 stock turbo SOLD ![]() 310HP 436TQ 2004 Eblue Neon SRT4: E85 5558 ![]() XXXHP XXXTQ |
#14 (permalink) |
![]() Join Date: Apr 2008
Member Number: 63272
Did u get a new pressure plate along with the clutch? This might sound stupid but I seen it on a locals car with an act Hdss clutch. Shifted like butter when cold but impossible when hot. I had tried many basics before that such as cable and pedal adjustments ect. His tob fork was also new prior. New pressure plate sealed the deal.
2004 Black SRT-4-
Mopar Stage 3 with the works 2003 Silver SRT-4- BW s200sx-rs-56 .63ar ![]() 1997 Black 1G, 2.4 built and turboed-project ![]() Any1 local in need of PCM flash...hit me up Last edited by badboydneon; 12-07-2012 at 08:05 PM. |
#15 (permalink) |
When you try to go into reverse you get locked out and you can feel the car bump itself back a little bit. Added that to the first post! You can certainly feel that it wants to go into gear. Did u get a new pressure plate along with the clutch? This might sound stupid but I seen it on a locals car with an act Hdss clutch. Shifted like butter when cold but impossible when hot. I had tried many basics before that such as cable and pedal adjustments ect. His tob fork was also new prior. New pressure plate sealed the deal.
![]() Yep, brand spanking new kit from ACT.
2005 PVK w/ GWA
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
