Old 03-05-2006, 06:41 PM   #1 (permalink)
Member Number: 9312
Default hard to get into 2nd gear
Went to the track today, and I was tryin 2 shift into second..... it wouldnt go.... I was giving it everything I had and it wouldnt go in.
Then if finally did. On the street I have no problems shifting into second gear under normal driving conditions, or even driving hard. So I dont believe it would be my syncros....
I just bought the 72% reduction MadDog Shifter. Someone said maybe adjusting the shift cables would fix my prob... would this work?
2005 Dodge SRT-4 - SOLD
2003 Chevy Silverado SS - SOLD
2008 Mazdaspeed 3 - New Ride
fastflagsrt4 is offline   Reply With Quote
Old 03-05-2006, 07:21 PM   #2 (permalink)
Member Number: 9312
jus took my girlfriend home, and had a hard time again... i heard it this time tho, no gear grinding... just sounds like a clunk. every time i try and pull it into 2nd and 4th.
could it be the shift selector?
Old 03-05-2006, 07:29 PM   #3 (permalink)
COY
COY's Avatar
Member Number: 35663
Trader Rating: (42)
Could be a shift selector.
Flame= Ignored
PTP = Ignored
Bring back Ekool
COY is offline   Reply With Quote
Old 03-05-2006, 07:37 PM   #4 (permalink)
Supporting Vendor
Maddog's Avatar
Member Number: 5932
Trader Rating: (579)
Try adjusting your neutral position.
Maddog STS Great Decals -->House of Grafx
Complete Short Throw Shifters sold here! 50% to 80% overall throw reduction! Custom work available!
PM or email Chuck@maddogsts.com for more information.
'05 Stone White - a few mods...
Maddog is offline   Reply With Quote
Old 03-05-2006, 07:44 PM   #5 (permalink)
Member Number: 9312
If this isnt adjusted correctly..... what are the signs??
What does adjusting this do?
Maddog... can you send me the document on how to do this? I misplaced it. All I have are: Rod Brake Set Kit Installation and Adjustment, and your return address sheet.
Old 03-05-2006, 08:53 PM   #6 (permalink)
Supporting Vendor
Maddog's Avatar
Member Number: 5932
Your rod brake my be out of adjustment, too. Make sure the front plate is not too far back.
Here are the instructions:
To adjust your neutral position:
1) You will need to remove the center console.
2) Set the brake; put trans in 3rd or 4th ONLY.
3) Using an 8mm wrench or socket, loosen the small bolt (about 3 turns) located on the driver's side cable where it attatches to the gate arm. Make sure that the connection is loose, and that you are in 3rd/4th gear.
4) Retighten the bolt.
Old 03-06-2006, 08:16 PM   #7 (permalink)
Member Number: 9312
Did this tonight.....
Still hard 2 get into 2nd and 4th?
The rod brakes are set correctly.
Any one else had this prob with or without maddog shifter?
Old 03-07-2006, 04:26 AM   #8 (permalink)
Member Number: 9312
what does it feel like when the shift selector is going bad?
is it hard to get in to certain gears, or all of them?
Old 03-07-2006, 05:43 AM   #9 (permalink)
srt4mebaby's Avatar
Member Number: 35265
try changing ur trans oil....i changed mine and it made all the gears easier to shift into.
AGP 50 trim
Dtec FCBC
Lots of other goodies
srt4mebaby is offline   Reply With Quote
Old 03-07-2006, 05:47 AM   #10 (permalink)
NeonDan's Avatar
Member Number: 138
Trader Rating: (82)
stock bushings perhaps?
i cannot stress to you guys upgrading to the maddog that over time the stock bushings will literally be destroyed by the reduction in throw/pressure....leaving you with cable ends on the rods or on the tranny forks.....GET BOOGERS
Old 03-07-2006, 07:09 AM   #11 (permalink)
Member Number: 9312
I have booger bushings.... I have had a mopar sts since i bought the car last Jan. I just recently bought the Maddog
Old 03-07-2006, 07:13 AM   #12 (permalink)
NeonDan's Avatar
Member Number: 138
Trader Rating: (82)
hmmm might wanna pop the hood and take a look at the two cable ends on the tranny forks...
see over time the cables slide down towards the base of the forks and because the boogers are a tad short. When they slide down it gives the driver a hard time engaging certain gears cause its like the cables arent quite on but they are visually. Look at them both before touching them...hell if you have a cam snap a few shots....then try sliding both cables upward WITHOUT popping bushing/cables off fork
Old 03-07-2006, 09:57 AM   #13 (permalink)
Member Number: 9312
I just put the boogers on. How do I make sure the cables are infact all the way on? They looked like they are visually.
When i have a hard time pulling it into 2nd or 4th, I can hear a knock cause im pulling it so hard. I wouldnt think it would be the shift selector only in 2 gears.... and its only in 2nd and 4th.
Old 03-08-2006, 10:33 AM   #14 (permalink)
Member Number: 9312
So... i just read that DCX says 2 change your tranny oil every 18000 miles.....
My car has 33000 miles, and has stock oil in tranny.
I am going to give this a try 2nite,
Do I need to get the friction modifier?
My one buddy is running synthetic gear oil in his, having no probs..... would it be safe going that way other than the mopar oil?
Old 03-08-2006, 12:15 PM   #15 (permalink)
Mike V.'s Avatar
Member Number: 9234
No.
Mike
BSME
1995 Plymouth ACR Coupe
1997 Dodge Neon Sport Coupe
Mike V. is offline   Reply With Quote
