Old 09-10-2005, 12:53 PM   #1 (permalink)
Member Number: 18640
Default flywheel bolts/loctite ?
Ok, so I'm installing my CM s4 6-puck today....I got 4 new bolts from the dodge dealership for the flywheel (or drivewheel as its called in the manual). they already seem to have a blue threadlocking compound on them...my question is this: will i be fine just using this, or should i use red loctite? and if i just use the stuff that came on there, should i let it sit for any period of time before using it?
'05 Black SRT-4
AGP WGA : Forge BOV : Home Depot MBC
Custom 3" dump exhaust : Psi-Fi Motorsports CAI
Mopar STS w/ Boogers : GReddy Full Auto TT
MPx Strut Tower Bar : MSD 8.5 mm wires w/ NKG Iridiums
17x7 Motegi DP6 w/ 235/45/17 Sumitomo rubber
Clutchmasters Stage 4 Clutch
srtpwnzy0f4c3 is offline   Reply With Quote
Old 09-10-2005, 01:22 PM   #2 (permalink)
Member Number: 31372
Well, I would use red and put it on yourself. Reason I say this is because my SRT-4 and several others(some I read about, 1 was at same dealer mine was serviced at) have had the flywheel bolts actually come loose, and cause a horrendous noise, and damage the clutch. This happened to me on my '05 at about 3400 miles, mine were so loose the mechanic who serviced it said he was able to remove all of them with his fingers.
I'd hate to se you trust the stock stuff, and have a problem like that.
NurSRT4 is offline   Reply With Quote
Old 09-10-2005, 01:27 PM   #3 (permalink)
this would actually be my 2nd clutch install, because they backed out the first time. and yeah, it caused some horrendous noise and screwed over the clutch. my 05s stock clutch died at 17,500
Old 09-10-2005, 01:42 PM   #4 (permalink)
I find it amazing that Dodge, only has a TSB for this, not a recall. When I called DOdge to ask about this, and complained at the damage this could have caused, I was told it was not a recall because it's a "minor" problem...yes, the flywheel really has little to do with the operation of the vehicle.
Another funny thing, they will void your warranty for an underdrive pulley for the harmonics it could induce and possibly cause oil pump or bearing failure. I'm sure the rattling of a loose flywheel at the end of our crankshafts doesn't affect anything though.
Page generated in 0.18041 seconds with 13 queries
