Old 07-20-2006, 01:05 PM   #1 (permalink)
Member Number: 8887
Default fluid change?????? just read?
today i was going to change my tranny fluid again, so i started to losen the drain plug and while i was doing that, i started to hear a hissing noise, which was coming from the drain plug.
no i'm not on drugs it had air pressure behind it.
what the hell is that caused by?
stage 1 11.73@ 117.07 60ft 1.64 on mtslicks on koesi wheels 24.5 8 15 60 hp direct port
396 hp
458ft lbs of torque
2003 GNCC 2 stroke champ
2006 yfz480
highpsi is offline   Reply With Quote
Old 07-20-2006, 02:34 PM   #2 (permalink)
Member Number: 27517
Was the transmission hot? Did you just get done driving your car? If so there will be some pressure built up but not much. Heres a tip, remove the fill plug before the drain plug to release the pressure and help drain the trans.
jeremy6 is offline   Reply With Quote
Old 07-20-2006, 03:13 PM   #3 (permalink)
vegasDSM's Avatar
Member Number: 726
i did mine last night and got some gurgle noises and a lil hissin....
dont worry
F this forum and it's bullshit ads......ekool has jumped the shark
www.myspace.com/vegasdsmr<--vids....................
http://www.WebPeople.us
http://www.WebPeopleVideos.com
vegasDSM is offline   Reply With Quote
Old 07-21-2006, 02:20 PM   #4 (permalink)
Member Number: 8887
Default fluid
thanks for the input.
Old 07-21-2006, 03:18 PM   #5 (permalink)
jaylakejr's Avatar
Member Number: 41920
Just out of shear curiosity, changing your transmission fluid would help what? I know this is kinda a newb question but really....
HAMMER! Cause you can't touch this
04 E Blue, Stage 2 with Toys, Solid MM, Mopar/Borla/Magnaflow 2.5" Custom Catback, 3" DP with HiFlo Cat, AEM SRI, MSD Wires, Mopar STS, Mopar Stage 3 Coilovers, 18" Konig Holes wrapped in Toyo Proxes.
jaylakejr is offline   Reply With Quote
Old 07-21-2006, 04:03 PM   #6 (permalink)
04bluesmithjuice's Avatar
Member Number: 10189
Trader Rating: (18)
Really it doesn't unless *unless* you upgrade the fluid to like Royal Purple or RedLine. It will help out on the shifts alot, I put redline in mine and I noticed a big difference over the mopar fluid that comes in it.
Its more expensive but well worth it in the end. I am working on a write up on the difference between red line and mopar, so look for it soon.
Brian
Mountain Section's Resident Asshole
04 E-Blue SRT-4 <-Under construction, built bottom end, ported and built head, big turbo, standalone, auto trans, its going to be nasty!!
Ask yourself one question:
"When you turn your car on, does it return the favor?"
04bluesmithjuice is offline   Reply With Quote
Old 07-21-2006, 04:16 PM   #7 (permalink)
vegasDSM's Avatar
Member Number: 726
royal purple 75w90 was only $1.11 more per quart than atf+4......
for an extra $3.33 i'm much happier..
p.s. change your tranny fluid every 18,000 miles... i never had done it and i was @ 43k.....
cheers
Old 07-22-2006, 11:44 AM   #8 (permalink)
sqcomp's Avatar
Member Number: 33803
I was going to use Amsoil ATF or Synchromesh. Are either of these a problem? I'm seeing 6 pints to fill, is this correct?
sqcomp is offline   Reply With Quote
Old 07-22-2006, 02:04 PM   #9 (permalink)
srTFrazier's Avatar
Member Number: 27284
Trader Rating: (18)
you do know that 04/05s require the transmission fluid changed every 18,000mi right? dont forget to add the friction modifier for the LSD too.
srTFrazier is offline   Reply With Quote
Old 07-22-2006, 02:07 PM   #10 (permalink)
srTFrazier's Avatar
Trader Rating: (18)
^ works in the depatrment of redundancy department.
Old 07-23-2006, 12:10 PM   #11 (permalink)
Member Number: 8887
Default fluid
what ever you do DON'T use lucas it is shit!
ROYAL PURPLE helped out alot.
Old 07-24-2006, 09:25 AM   #12 (permalink)
jaylakejr's Avatar
O Shit.... Have no idea..... Ok now help me out. I am ordering Royal Purple 75W90 what is this friction modifier you speak of?
Old 07-24-2006, 03:14 PM   #13 (permalink)
Member Number: 8887
Default fluid
no not 75w90..
i think it was called schromax or something like that it is an atf(automatic transaxle fluid) yes you use atf in our trannies.
Old 07-24-2006, 03:30 PM   #14 (permalink)
jaylakejr's Avatar
Ok.... what about Amsoil ATF? Is that stuff good? Do I need a FM for it?
Old 07-24-2006, 08:47 PM   #15 (permalink)
Amsoil ATF is the best in my book. You do not need the FM for this fluid but if you really want some Amsoil sells LSD FM.
Page generated in 0.27299 seconds with 13 queries
