Quote: Originally Posted by
UpShiftSRT4
I Have looked over the transmission pretty good, especailly during the solid trans mount install and have yet to see a nipple to bleed the fluid out. It's not on the slave cylinder like I expected...
Can anyone point me to it?
There is no nipple. If you can get a service manual then it will explain to you how to do it, but if you do not have access to it then here's what you do, and I say this is because I just did this recently.
1.) Disconnect the battery.
2.) Remove Lower IC Pipe. I say this because it was in the way when I did it so I took it off.
3.) Remove the slave cylinder.
4.) Take off the cap to the clutch resovior.
5.) Pump the slave cylinder.
6.) Watch for bubbles coming up from the clutch fluid resovior. If you have another person to look at it for you then please do so.
7.) Replace everything, then pump your clutch and see if you can feel a difference.
That's just basically a down and skinny of it. You have to pump the clutch 50 - 100 times and memorize the way it feels. This is said in the service manual so i'm not making that up, lol. I'm pretty sure somewhere there is a how to, or someone is gonna correct me I'm sure, but like I said this is just a down and skinny. If you need more info than this let me know. I'll look for a link for the service manual and post it if I find it.
