Old 10-19-2009, 03:53 PM   #16 (permalink)
SRT of the Month
1LAPSRT's Avatar
Member Number: 38267
Trader Rating: (25)
Quote: Originally Posted by DJFahr11 View Post
Picture of the Mobil stuff going into one of the Factory Rally cars...
And WAY TOO MUCH mayo going onto the sandwich in the trailer.....
Old 10-19-2009, 03:59 PM   #17 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (29)
LOL!!!
So anybody succesfully try the 10W-30 oil? I'd be game to try it out. Though I don't think one single soul on this board drives harder than 1LAP. lulz
Old 10-19-2009, 04:01 PM   #18 (permalink)
Philth's Avatar
Trader Rating: (29)
Also, I'd be curious to hear the authenticity of the statement on Modern's website about using high mileage oil in the trans.
Old 10-19-2009, 04:03 PM   #19 (permalink)
scox1026's Avatar
Member Number: 61138
Glad i found this useful information.. i might switch over to the mobil 1 as long as it works well, ive been changing my tranny fluid every 10k (I drive hard too) and this would cost half as much! unless someone can prove otherwise, mobil 1 makes perfect sense.
Coming Soon.... D44
scox1026 is offline   Reply With Quote
Old 10-19-2009, 04:05 PM   #20 (permalink)
NoisufnoC's Avatar
Member Number: 136
for sure. I dont know if i'm brave enough to try it
Keeping the tire companies in business...
...one WOT shift at a time™
|| Mod List Coming Soon ||
***Forum Rules***
Old 10-19-2009, 04:07 PM   #21 (permalink)
scox1026's Avatar
I was thinkin the same thing!!
Old 10-19-2009, 06:00 PM   #22 (permalink)
dodgezdad's Avatar
Member Number: 12950
Most modern syn. transmission fluids like RP,Gm, amsoil has the friction modifiers in it because of the newer type syncros in our transmissions.
Use motor oil for the older transmissions with syncros without friction pads or some racing transmissions.
If you have trouble with shifting, then you have worn parts or the cable adjustments are out and motor oil will not help it. [Change it often because the FM breaks the fluid down]
I have over 500 trips down the strip, most with WOT shifting with Mopar atf+4 and friction modifiers and after 75,000 miles have never had a shifting problem. It's cheap and is very good fluid and others have to be licensed to use the ATF+4 label.
dodgezdad is offline   Reply With Quote
Old 10-19-2009, 09:56 PM   #23 (permalink)
Hi N Mity's Avatar
Member Number: 33036
Trader Rating: (40)
looks like Mobil Clean 5000 High Mileage oil, not Mobil synthetic..........the red cap
<-----Haz 1 Infraction for too large of a Signature.
Old 10-19-2009, 10:28 PM   #24 (permalink)
DJFahr11's Avatar
Member Number: 25197
Trader Rating: (29)
It is, I think that's what they meant. I'm sure you've noticed some people tagging 1 onto anything that starts with Mobil
I'm not seeing the ZDDP in the MSDS for the Mobil 1 High Mileage, but it's there in both the Mobil Clean High Mileage and Mobil Clean 5000.
DJFahr11 is offline   Reply With Quote
Old 10-19-2009, 11:10 PM   #25 (permalink)
Member Number: 31038
Trader Rating: (50)
Win.
www.neons.org &bull; View topic - Little Dragon Racing Trans(MTX)Pics,Updates,Open spots now!
You will need to use either mobil 1 high mileage 10w30 or w40(the only non racing only with all the correct additives and modifiers), redline, royal purple or another quality racing oil. If you have to use amsoil or pennzoil make sure it has a SL rating and contains ZDP at least at 16000ppm. I STRONGLY urge you to use the Mobil 1 high mileage, A Chrysler tech had it tested and it was within 99% of the original Mopar Lube’s formulation with a slight increase in ZDP and a slight drop in sulfur. Sulfur was only used for brass synchro’d trannies as an anti tarnish agent.
NEVER use atf+4 or gear oil as neither should be used in a performance NVT/G 350 tranny. ATF+4 was a swap for cost and time while building the neon and should never be used except for mild driving in unmodified cars. Serious.
Gear oil is too thick and unable to sling up onto the passive oiling system or make it through the shafts, synchro damage is the most common result.
Maddog uses it in his SRT-4, 1st gen ACR and his sons 03 R/T Neon. No issues and his cars shift great. I let him know about this thread.
raul-01 is offline   Reply With Quote
Old 10-20-2009, 10:52 PM   #26 (permalink)
Trader Rating: (50)
Yes its in there.
Easy version:
API Motor Oil Service Classifications
Or direct from API here with Engineer speak, this is the entire OIl classidfication requirements by the API.:
http://www.api.org/certifications/en...forprint-2.pdf
SL oils Page 59-60 under sequence VE, compare to page 60-61, ZDDP level is set between .06-.08% on SM, SL must have at least .08%.
So, All SL oils are required to have ZDDP, by federaly mandated API and SAE certification.
As you can see it has the SL rating.
Old 10-20-2009, 11:32 PM   #27 (permalink)
Philth's Avatar
Trader Rating: (29)
So....anybody try it yet?
Old 10-21-2009, 10:37 AM   #28 (permalink)
Trader Rating: (50)
Waiting on axle. Once it gets here and I put it in, off to the store to pick up the oil and the flush.
Old 10-21-2009, 11:14 AM   #29 (permalink)
DJFahr11's Avatar
Trader Rating: (29)
Quote: Originally Posted by raul-01 View Post
Yes its in there.
Easy version:
Thanks, I see now.
What I originally actually said still holds true though , it's not listed by name in the provided MSDS, but only because SL makes it a given at that 0.08% level. So now what I'm thinking is it's specifically listed in the Clean MSDS sheets because there's more of it, being listed with a maximum 2.5%.
Old 10-21-2009, 11:17 AM   #30 (permalink)
DJFahr11's Avatar
Trader Rating: (29)
I heard some crazy rumor somewhere that it was good enough for the Mopar Rally teams.
Page generated in 0.17695 seconds with 13 queries
