CV boot problem
Ok I tried to do a fair bit of research before I posted this up but here it goes.
I track my car often. The problem I have is keeping my CV joint boots on. The band they use keeps flying off. I have two axles that are perfectly fine but have loose CV boot bands. I think I may have to start doing the repair myself, as the shop I went to the last two times to repair this same problem I believe did not have them tight enough.
So is there a heavy duty band out there or am I stuck using the ones the axles come with, I guess there is a tool I have to buy as well. Also what about using glue to seal the boot to the metal portion of the CV joint?
any input is appreciated
the legend of the teeth will live again vvv
11.030 @ 125.80 MPH
