Clutchmaster Stage 3 clutch kit - Dodge SRT Forum
post #1 of 4 (permalink) Old 06-15-2012, 08:33 PM Thread Starter
Quoted: 1 Post(s)
Just had the kit installed with new flywheel and when I get on the throttle the rpms jump between 5-6000 rpms until I shift again. I took it back and threy rebled the slave cylinder and rechecked the torque on the bolts of the flywheel and clutch and everything was fine with no adjustments needed. I also recently installed the stage 3 upgrade kit before this and I was hitting anywhere between 22-24 lbs of boost and with this problem hours I only max out at 16lbs bc of no f riction with the clutch.....any ideas?
HoseltonSRT4 is offline
post #2 of 4 (permalink) Old 06-15-2012, 10:40 PM
strokedracer05's Avatar
Quoted: 0 Post(s)
Did you properly break in the clutch?
And "proper friction with clutch" has nothing to do with boost levels first fix the clutch and propery break it in you will have to see how clutchmaster wants it broke in then after its fixed do a boost leak test a line probably got loose during install or disassembly
strokedracer05 is offline
post #3 of 4 (permalink) Old 06-16-2012, 04:14 PM
Quoted: 0 Post(s)
actually its very possible to not build as much boost or any boost if the clutch is slipping
homie3186 is offline
post #4 of 4 (permalink) Old 06-21-2012, 01:09 PM
intshadeofblue's Avatar
Quoted: 0 Post(s)
x2 on breaking in your clutch. I recommend a minimum of 650 miles of mixed city/highway driving at half throttle or less.
'05 Silver - DD - 110xxx miles
E85 stock turbo - who needs traction in 3rd?
Mods list: [very long list of bolt-ons goes here]
Looks like stock, goes like stink
I GOT 99 PROBLEMS BUT LOW TEMPS AIN'T ONE
Hopefully getting 1/4 times before finishing grad school, but after getting slicks...
intshadeofblue is offline
User Tag List
Linear Mode Linear Mode
