Old 05-30-2007, 10:45 PM   #196 (permalink)
SRToc Member
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
You gotta take the engine damn near out of the bay to do it. It's a 12-hr job.
I didn't go with a performance clutch because I don't plan to add more power and didn't want to deal with the additional cost, lack of warranty and potential drivability issues.
James
READ AND LEARN:
Old 09-11-2007, 01:14 AM   #197 (permalink)
Seat_R's Avatar
Member Number: 44793
Quote: Originally Posted by AWH
I have a 2003 SRT4 and recently replaced my clutch with a SPEC SD-842 Stage II clutch. I am experiencing a strange grinding/vibration when I push the clutch all the way to the floor. It sounds like a mini-jackhammer, or a fan when something is stuck int it.
I can feel the vibration coming from the pedal. There is no grinding or vibration coming from the gearbox, and the gears shift smoothly.
My mechanic, who installed it, was unable to detect the problem and questioned as to whether the new unit is a direct replacement for the stock clutch. He did notice that the fingers on the pressure plate were pitched slightly higher than the stock clutch. I contacted the outfit from which I purchased the clutch, JSC Speed, and they assured me it was correct for my car.
The car seems to shift okay and I can avoid this grinding as long as I dont go all the way to the floor with the clutch pedal. The car is stock otherewise. Any insight on this would be greatly appreciated.
i have the same problem...........
someone tell me that i have to adjust de cltuch pedal but my question is.....
why does the car vibrate only when has be driven by more than 20 minutes???
is the pedal adjusment the right way to fix that problem???
Seat_R is offline   Reply With Quote
Old 09-20-2007, 11:53 AM   #198 (permalink)
Freaky's Avatar
Member Number: 47525
sorry to post whore , however are our clutches adjustable , from a roll i'm good but from a dig i slip like a honeymoon pussy after i hit 2nd. any help would be great .
stage0,cca bfmic, needswings dp no cat, mccord electric opener , agp wga ,dtec fc/bc , front an rear strut bars ,progress front an rear sway bars an springs, tripple pillar pod with auto meter volt an oil pressure guage , turbo xs wideband, turbonetics cold side pipe raptor bov , aem cai,return line ,255 walboro fuel pump, Granatelli wires , 4306 plugs
Freaky is offline   Reply With Quote
Old 09-21-2007, 05:31 PM   #199 (permalink)
SRToc Member
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
The stocker and I believe the MP clutch are self-adjusting.
Old 09-22-2007, 02:18 PM   #200 (permalink)
redneckricebnr's Avatar
Member Number: 51487
I put a centerforce kit in my car, and it is doing the same thing. It doesnt do it if I dont push the pedal in all the way, and it doesnt do it within a certain rpm range. It does it the worst above 5k rpms, and if I am shifting real slow. Sometimes it does it when I crank the car. It almost sounds like something is getting into the pressure plate or something. It is driving me nuts. It has been doing it since I had it put in. Been trying to decide whether I am gonna have pull the damn thing and send it back. Any ideas?
redneckricebnr is offline   Reply With Quote
Old 10-07-2007, 12:59 PM   #201 (permalink)
nittro's Avatar
Member Number: 1527
Default Beware Clutch Masters and Alum flywheel!!!
Clutch Problem Please Help Me Out Clutch Masters!
Stage 3R/HKS SSQ/AEM Full CaI/Sperco Monster Intercooler/Maxxfab 3"02 Housing/MPx Full 3" no-cat/60mm Throttlebody/Dogbone Motormounts/AGP Stage 3 Wastegate/NGK Iridium/Eibach Sportlines/Clutchmasters Stage 4/Alum Flywheel/Coolmist Inj/MSD Coil/8mm Wires/Full Ed Hardpipes/AEM Wideband/18" Black AMP's/Greddy Turbo Timer/Samco Radiator Hoses/Greddy Catch Can/Hurst Short Throw/Balance Shafts Removed
Mustang Dynoed at 419HP / 432TQ
nittro is offline   Reply With Quote
Old 10-09-2007, 02:08 PM   #202 (permalink)
leatherneck55's Avatar
Member Number: 24392
Default Info please
I have installed a mopar stage 3 clutch with throw out bearing. The car will not go into gear unless the car was off. I did some research here and ordered new fork, clips, ball clip.Took the tranny out inspected fork...worn out.Inspected clutch assembly ok.made sure cables were not crossed. Reinstalled clutch,bled system. The car will not go into gear. Used a lift put it up in the air the car will go into all gears, put the vehicle down hard to get the vehicle into first and second gear, and reverse. 90% of the time I have to turn off the vehicle in order to put it in reverse.If I turn off the vehicle it goes into all gears smoothly.when the car is on and I finally put in first it idles rough.I was wondering if I can get some imput.This never happened with the stock clutch.I did also replace the slave cylinder
leatherneck55 is offline   Reply With Quote
Old 10-09-2007, 07:49 PM   #203 (permalink)
cooper232's Avatar
Member Number: 12276
please someone help US! I am having the exact same problem right now. I mean I couldn't have wrote it any better. What is going on? I am totally stumped having this problem and am ready to just set this thing on fire! I just had a new motor and ported turbo installed and now this... I can't even have fun with my new stuff! Rev matching gears I am sometimes even slower than Semi-trucks trying to get going.
need a bumper cover! anyone? anyone? bueler?
cooper232 is offline   Reply With Quote
Old 10-18-2007, 08:00 AM   #204 (permalink)
I just fixed my problem, re adjusted the clutch pedal now the gears are going in smooth. it's been a week n a half and all is good.I guess the pedal was not pushing the fork enough to make the clutch disengage.
Old 10-18-2007, 01:14 PM   #205 (permalink)
cooper232's Avatar
i have adjusted my pedal all the way out and it still wont fix it. help me!
Old 10-20-2007, 09:46 AM   #206 (permalink)
daniel427ss's Avatar
Member Number: 51325
damn man im having the same mofo shiat... installed new clutch, tob, welded up fork(was lil worned), bleeded(pressing clutch 1000Xs right?) n is still hard for reverse.... n 1st somewhat.
even with all this, i thought u wouldnt need to adjust pedal... should i try that?????
daniel427ss is offline   Reply With Quote
Old 10-20-2007, 10:25 AM   #207 (permalink)
so you had to adjust pedal even with a new clutch????
Old 10-20-2007, 04:23 PM   #208 (permalink)
ok this is what I did, new stage 3 mopar clutch, new tob,new slave cylinder,bled system, and made sure cables were not crossed,re filled transmission with fluid because all of the fluid that was lost when removing axles, adjusted clutch pedal, put it up in air first n shifted through all gears, put it down on floor n bingo. I think by putting that welded fork might b the problem. I think if your master cylinder was messed up when you would step on the clutch the pedal should feel weird or spongy.When I was having problems with the clutch at first, the pedal felt really loose, as soon as I adjusted it it felt back to normal again.
Old 10-22-2007, 08:23 AM   #209 (permalink)
how can i check my cables, is this inside at the shifter?
also, i havent checked my slave cylinder, ill try my friends slave cylinder on my car to see if anything changes.
Old 10-30-2007, 01:45 PM   #210 (permalink)
you check your cables from underneath the vehicle, make sure they werent criss crossed when you put them back on.
