Old 08-31-2005, 11:14 AM   #1 (permalink)
SRTforums Nazi Admin
NIVO88T's Avatar
Member Number: 1109
Clutch Problems - Come in here
Ok, so recently after my tranny tear down thread, i've been swamped with PMs about tranny issues and clutches.
Now I want to start a thread in where guys can put in their .2 cents about their issue and possibly we can come to an understanding on whats going on here with the SRT-4 clutch/hydraulic system design.
The most popular going around is the disengagement issue/Hard shifting.
The most valuable thing you can own is the PL/SRT FSM, go out and get one.
Now according to the book this is what is says:
HARD SHIFTING
Hard shifting may be caused by a misadjusted crossover cable. If hard shifting is accompanied by gear clash, synchronizer clutch and stop rings or gear teeth may be worn or damaged.
Hard shifting may also be caused by a binding or broken shift cover mechanism.
Remove shift cover and verify smooth operation. Replace as necessary.
Misassembled synchronizer components also cause shifting problems.
Incorrectly installed synchronizer sleeves, keys, balls, or springs can cause shift problems.
SLIPS OUT OF GEAR
Transaxle disengagement may be caused by misaligned or damaged shift components, or worn teeth on the drive gears or synchronizer components. Incorrect assembly also causes gear disengagement. Check for missing snap rings.
CLUTCH PROBLEMS
Worn, damaged, or misaligned clutch components can cause difficult shifting, gear clash, and noise. A worn or damaged clutch disc, pressure plate, or release bearing can cause hard shifting and gear clash.
Old 08-31-2005, 11:28 AM   #2 (permalink)
FullyBuiltCory's Avatar
Member Number: 21013
Trader Rating: (10)
Good FYI, thanks a lot Nivo
FullyBuiltCory is offline   Reply With Quote
Old 09-05-2005, 11:00 AM   #3 (permalink)
Member Number: 10426
since we're talking about clutches here, I got a story and a question as well. 3 months ago i was driving and the transmission was acting up really bad. With a couple of guys on the forums i was able to come to the conclusion that the clutch was burned. I gave it to the dealer to fix it and the guy calls me up and tells me that i have to spend 4 grand for a new tranny!!! The thing is, my car has 19 thousand miles and never modified once. Whos right here!?!?! Even if it were to be the transmission, am I really suppose to pay 4 grand? This is bullshit.
Velocissimo is offline   Reply With Quote
Old 09-05-2005, 11:05 AM   #4 (permalink)
SRToc Member
04srt4black's Avatar
Member Number: 22206
Trader Rating: (157)
Another Quick Question Then, HOW DO YOU Bleed the clutch ? I Put in my spec satge 3 and the slave cylinder handle snapped , i had to replace it , now i have no clutch . Does anyone know how to bleed it? Help , i have no car now until i figure this out.
04srt4black is offline   Reply With Quote
Old 09-05-2005, 12:58 PM   #5 (permalink)
BOOOST ALMIGHTY's Avatar
Member Number: 31142
Trader Rating: (12)
When i installed my new clutch there was no pedal untill I pumped it a bunch. Its been fine ever since.
Supercharged Viper
Stage 3 SRT-4 (FOR SALE)
BOOOST ALMIGHTY is offline   Reply With Quote
Old 09-05-2005, 12:59 PM   #6 (permalink)
Trader Rating: (12)
Hey NIVO, where do you get that BOOK?
Old 09-05-2005, 02:09 PM   #7 (permalink)
SRToc Member
So i need to just pump it for a while ? it was real loose like it had nothing at first , then i pumped it a few seconds and took the lid off the thing you put the fluid in and air came out , and it gave me a little clutch but still wouldnt go in gear.
Old 09-05-2005, 02:50 PM   #8 (permalink)
Trader Rating: (12)
Keep doing it. You may also have to adjust your Pedal.
Theres a How To in the "HOW TO" Forum
Old 09-06-2005, 06:29 AM   #9 (permalink)
SRToc Member
I figured it out , now i got a clutch , but my throw out bearing had one of the two clips broken on it and i put it in anyway, and it fell off , so i have to pul it back off and put a new one in ! Oh well , ANyone got a good throw out bearing?
Old 09-06-2005, 07:33 PM   #10 (permalink)
RUDEF2's Avatar
Member Number: 24170
^^^ The same thing happened to mine yesterday upon installation. Clippy/Guide/Snap thing on throwout bearing broke right off... The design sucks on the throwout bearings for our cars.
I just installed my CM S4 today. I had no resistance at all after hoping in my srt and pushing the clutch to the floor. I pumped it a few times and it was ok. My brakes were the same way. Right now 1st gear is real touchy, you go or you dont, but it seems like its slipping at 2500rpms and up. I guess its not broke in yet??? I do not know...
60/48mm Garrett turbo, PowerPaq, Wideband, Profec B Spec II boost controller, Stage 1 ECU, Ingen Intake, 3" full custom exhaust, AIS intercooler, RFL BOV, 52mm TB, Fuel kit (regulator, stainless return fuel lines), 255 walbro fuel pump, 750cc RC injectors and injector clips, Clutchmasters Stage 4 clutch, 18" hyperblack wheels with Goodyear Eagle F1s, Eibach springs
RUDEF2 is offline   Reply With Quote
Old 09-15-2005, 07:03 PM   #11 (permalink)
Member Number: 31742
Has anyone had the "PING" sound at engagement...sorry to whore thread!
Current mods on 04': Mopar STS w/booger bushings, Mopar BOV conversion, MSD Plug Wires, $20 Catch Can, Borla Catback, Mopar Stage 1, K&N CAI, AGP WGA...(18 spike 16 hold)....= One Fast 4banger!
13.6@104.14
2.18 60ft
Street Tires
SRT2NV is offline   Reply With Quote
Old 09-25-2005, 10:00 PM   #12 (permalink)
Member Number: 19287
yes i hear it now and then.
S2 no toys+devilsOWN +AGP 50trim
294whp no tune
boosty is offline   Reply With Quote
Old 10-10-2005, 05:19 PM   #13 (permalink)
jmcmil6's Avatar
Member Number: 32188
can anyone get me info or names of people who have had problems with their clutches exploding or coming apart from the flywheel?
hipsiracing.com -- forum up and running!
'05 srt-4 stone white - custom trans/clutch placement
'03 G35 Ivory Pearl(for now)- leather, so mo leather, tint, Beat in the trunk, and $150 worth of Silverstars
jmcmil6 is offline   Reply With Quote
Old 11-08-2005, 08:01 PM   #14 (permalink)
Member Number: 32792
did the cannonball this year. prepping my car out. put in the mopar clutch (along with every other mopar part including stage 3). after 200 easy miles (really), first lap, first turn at IRP, it sheared some rivets, and spun. nice. p.o.s. so we put the stocker back in an overnight thrash (luckily it was a 100 flatbed ride back to our shop) and put up with like 3000 road miles and a weeks worth of track time.
stump is offline   Reply With Quote
Old 11-08-2005, 08:21 PM   #15 (permalink)
SRT4kidd's Avatar
Member Number: 14612
I bought my car in May 05 and i now have 11k miles on it, since i bought my car i have noticed the hard shifting problem. I brought it to the dealer and they said everything was all good and that i was imagining the problem . Well about 2 months later for some weird unknown reason all my gears locked up so i couldnt get into any gear. Ever since then things have gone downhill, it still shifts hard and every time i go to put it in reverse it grinds or makes a big clunkin' sound. After bringing it to the dealer to get it checked out they tell me it was my clutch and they wont fix it cause i have an AGP WGA and about have treadwear life left!! Arent the KDWs supposed to last about 20k?! I already reported them to the BBB, this is bullshit!
SRT4kidd is offline   Reply With Quote
