Clutch amateur
Well a few weeks ago I went to do a 4th gear dyno pull and the RPMs shot up and the MPH barely moved. Yes, classic signs of a slipping clutch I know.
Now on to my question - I take it clutches only slip under high loads unless they're totally shot? I ask this because if I'm in 3rd gear and give the car maybe 50% throttle, the car pulls amazingly well with no slipping. I go WOT, however, and the RPMs just skyrocket and I don't get anywhere. Basically all of my car's power is at 50% throttle (LOL). This is a regular happening? I was not under the impression that if a clutch is slipping it's not going to "transfer" the power at some times and then "slip" it at others. I figured when a clutch slips, it slips any time you add a decent amount of load to the motor, but I guess it's all indicative of throttle and how fast it has to transfer from the crank to the clutch assembly itself?
Powered by Turbonetics, South Bend Clutch, Wiseco, Crower, PTP, Realtune, Pwerks, SCT, DSS, AGP, HKS and some 93 octane!
