Old 10-26-2009, 09:53 PM   #1 (permalink)
Member Number: 18430
Default Clunk when letting Clutch out.
Whenever I release the clutch I can feel a thud\clunk in the drivetrain as the clutch grabs.
I have inspected the Motor Mounts and they are fine and torqued to spec. The clunking only occurs when I first release the clutch going into a new gear. It does not occur when I try and buck the car by getting on it and off it.
The clutch appears to be in ok shape as it engages low when releasing the clutch.
A Google search of the site has come up with a lot threads but nothing that sounds like my issue completely.
Anyone have a similar issue?
____________________________________________
OB 05 SRT-4, FM WGA, Injen SRI,
3Bar Map/Tip, PTP Check Valve,
17x7 DP6, BC Coilovers, Mopure STS,
Scangauge, MM inserts, AEM Wideband
Injen Catback. Tuned By TDSAaron
ramage is offline   Reply With Quote
Old 10-26-2009, 10:41 PM   #2 (permalink)
apexcrazy's Avatar
Member Number: 24279
Ummm , My my reverse did that for a couple weeks before my 1st tranny locked up . I also had crunchy 3rd that also would kick out sometimes .
I hope your issue is not related , but your thud/clunk description fits .
_____ _____
apexcrazy is online now   Reply With Quote
Old 11-05-2009, 01:06 PM   #3 (permalink)
Member Number: 9051
Trader Rating: (17)
Could be axles.... when you are on the highway and you let off the gas and then put it back on.... do you get another clutch? Like a loose drivetrain?
pphilps is offline   Reply With Quote
Old 11-06-2009, 08:24 PM   #4 (permalink)
04SRT_08's Avatar
Member Number: 68190
im having the same issue. no matter how easy i let out the clutch its a thump almost like stomping on the floor.. and i'm noticing a whine coming from the tranny... on 50kmiles, hopefully its a simple thing i.e. tranny fluid change
'04 SILVER NSRT-4
3" B&B TBE(sold), AGP wga, AEM sri, Crane-Cam plug wires, Stage 1, turboXS rfl on ebay pipe, Boomba mm's, JMB catch can
50 Trim
04SRT_08 is offline   Reply With Quote
Old 11-06-2009, 08:41 PM   #5 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (29)
Are your inspection cover bolts all in? Reason why I am asking is that one of mine was left loose after a clutch job and worked its way out. The inspection cover was hitting the bell housing when the clutch was let out.
Old 11-06-2009, 08:47 PM   #6 (permalink)
04SRT_08's Avatar
i've never had any clutch wirk done if your asking me
Old 11-06-2009, 08:55 PM   #7 (permalink)
Member Number: 60623
Im actually having the same problem, but I figured it out. there is a mount in the frame that the engine is connected to, you have to remove the passenger side wheel and you will find a re-sessed hex bolt very large that is under the gromet, that bolt holds the motor to the frame and i had to loosen both motor mounts and that bolt to lower the motor down far enough to see the problem. Also have to take off the thick metal cover plate that to drop down far enough. But thats what my problem was. Its a very nice clunk/thud noise, when it goes bad. hope it helps.
spoolin03 is online now   Reply With Quote
Old 11-06-2009, 09:50 PM   #8 (permalink)
redstg2srt4's Avatar
Member Number: 74519
i am having the exact same problem... but reading what you found, was the main mount bad or what.. i am not really getting what your saying.
redstg2srt4 is offline   Reply With Quote
Old 11-07-2009, 12:28 AM   #9 (permalink)
gq4life's Avatar
Member Number: 10297
im getting the whine and weird noise when i let up clutch sometimes.. im changing fluid hopefully that fixes
Old 11-07-2009, 12:39 AM   #10 (permalink)
rollwitstyle's Avatar
Member Number: 60104
Trader Rating: (20)
what did you replace to get it to stop? your post is a little confusing
NY SRT CREW
rollwitstyle is online now   Reply With Quote
Old 11-07-2009, 11:12 AM   #11 (permalink)
Sorry for the confusion guys, I replaced the bushing in the frame. Passengers side you cannot see it visually. Like i said you have to basically drop that side of the motor down to see it. So that is what I replaced and solved my problem. Hope this is a little more clear.
Old 11-07-2009, 02:03 PM   #12 (permalink)
did you get the part from the dealer? Part #??
Old 11-07-2009, 02:10 PM   #13 (permalink)
Trader Rating: (20)
+1
Old 11-07-2009, 11:13 PM   #14 (permalink)
Unfortunantely not, I swiped it off an 04'! Its the one that was the donor for the motor and trans for my 03'. Also I had a hard time describing the part I needed to the parts guys at dodge first, they were retared and had no clue! So sorry about that one. I will look around and talk to a source and let you guys know unless you happen to find it first! the race is on!
Old 11-09-2009, 07:31 AM   #15 (permalink)
awesome thanks. i will try and swing by the dealer in my area. but they are no help either.
Page generated in 0.16220 seconds with 14 queries
