View Poll Results: What is your car's build date?(for those who have broken the trans. input shaft)
Pre-03 9 9.89%
Jan. - Apr. of 2003 5 5.49%
May - Aug. of 2003 8 8.79%
Sept. - Dec. of 2003 10 10.99%
Jan. - Apr. of 2004 11 12.09%
May - Aug. of 2004 13 14.29%
Sept. - Dec. of 2004 7 7.69%
Jan. - Apr. of 2005 9 9.89%
May - Aug. of 2005 12 13.19%
Sept. - Dec. of 2005 7 7.69%
Voters: 91. You may not vote on this poll
Old 10-24-2007, 09:14 PM   #91 (permalink)
SRToc Member
Member Number: 25892
Blew my input shaft Oct 2006, had a CM Race clutch, the CM700 I think. WOT shift from 3-4th, nose dropped but didn't make any noise and the motor just revved. Twisted the input shaft about 2 inches from the end off like a hot tootsie roll, LOL! Purchased the Performance Autowerks Stage 1 upgrade and put a much less aggressive clutch in, one good for 4-500HP, no problems since, but no WOT shifts either!
www.bwoodyperformance.com
Mods: AGP GT3076R DBB Turbo
madwax is offline   Reply With Quote
Old 10-29-2007, 01:59 PM   #92 (permalink)
boostaddict04's Avatar
Member Number: 58855
i just had a problem with my car, dont quite know if it is the input shaft yet but its starting to lean towards that problem. i have an 05 with 24k. WOT shift from 2nd to 3rd. now i have nothing every gear is like neutral. almost like my clutch is stuck open
boostaddict04 is offline   Reply With Quote
Old 10-30-2007, 06:54 AM   #93 (permalink)
Member Number: 35183
Default 2nd shaft broken
Nine months to the day last night and I snapped a second shaft I put in. Going down hill in fifth 1/8 mile from my house not beating on it. This one was cryo treated, I guess that didnt work out too well. Car is 9/05 mods are similar to Aaronneon's 300hp list. This sucks, I'm thinking about going back to stock and unloading the car.
FastFirst is offline   Reply With Quote
Old 10-31-2007, 09:04 PM   #94 (permalink)
quicky4JR.'s Avatar
Member Number: 43042
Trader Rating: (28)
Rage-Tek will be putting another order in to have some more of the billet input shafts made. FYI
Davie,FL
Dyno tuning, installs, and custom build
Home to the fastest 5spd SRT.
quicky4JR. is offline   Reply With Quote
Old 11-08-2007, 06:47 AM   #95 (permalink)
darrell cox's Avatar
Member Number: 35031
Trader Rating: (159)
The ones we are doing are holding up as well. 3x stronger than stock sense our last adjustments in heat treat! They also come RIM Polished and CT Coated. Let me know if you guys need some and we will do a batch of ten and a group buy to get the price down to around $850.
Thanks,
Darrell Cox Racing 276-956-2082
PayPal Addy; darrell@dcrsrt.com
Email; darrell @dcrsrt.com
Website DCRSRT.COM
The leaders in SRT4 Performance. Engine & Cylinder Head Specialists
In House Dynojet Dyno! Full In House Machine Shop! Custom Fabrication!
darrell cox is offline   Reply With Quote
Old 01-27-2008, 07:33 PM   #96 (permalink)
bizzy's Avatar
Member Number: 13066
Trader Rating: (61)
FullyBuilt is also beginning production on billet input shafts....check their vendor section or pm myself , phucough , or fullybuiltjosh for more info......Watch for many other billet parts such as shift forks, shift selectors, engine mounts.......etc
thanks
AGP cai/750's/BC stg2 cams/fidanza gears/CCA Big FMIC/Full Blown fuel rail/TXS Dtec FC/AGP wires/Bwoody solid mounts/IPPCoilovers/welfare(pt)sways/RAGE billet lca bushings[/color]FULLYBUILTRace ported intake manifold/Race spacer/RPM 62mmtb/custom -6 an fuel feed/custom -6 an return
GT3076r full AGP bling opt
be afraid I am
bizzy is offline   Reply With Quote
Old 01-27-2008, 08:30 PM   #97 (permalink)
FullyBuiltJosh's Avatar
Member Number: 15749
Trader Rating: (99)
Have a whole line of billet input shafts due out in a couple weeks. Will be priced right around $1000. Will be able to make them as fast as you guys want.
FullyBuiltJosh is offline   Reply With Quote
Old 02-14-2008, 08:33 PM   #98 (permalink)
Member Number: 61648
Default lmao
I just did the same thing from 1st to 2nd but i don't know whats done to my 04, i just know its fast
Racerxmomo is offline   Reply With Quote
Old 02-15-2008, 12:07 AM   #99 (permalink)
Trader Rating: (99)
Confusing....
Old 02-15-2008, 12:43 AM   #100 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (24)
PM sent Josh
Old 02-17-2008, 03:19 PM   #101 (permalink)
whats confusing?????
Old 02-19-2008, 08:13 AM   #102 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (65)
Our new accelerator line of shafts have begun production.. time to delivery 4-5 weeks.
Be the first to get one and be the fastest 5 speed in your town.
Now taking deposits.. Price is $1800 this includes our exclusive longer first gear on our proven billet shaft. Our standard billet shaft was used in the two fastest 5 speed cars in the country. Our new first gear allows for you big turbo guys to stay in boost on the 1-2 shift and reduce your 60 times by 1 to 2 tenths. Overall ET reductions of 4 to 6 tenths on cars with full boost rpm of 4200 and higher will be the norm..
NemoFoss is offline   Reply With Quote
Old 02-26-2008, 06:26 AM   #103 (permalink)
Member Number: 61209
i think i broke my input shaft but i im a little low on the dough, how much am i looking at for a stocker vs one of the performance ones mentioned above?
sheffy1 is offline   Reply With Quote
Old 02-26-2008, 07:22 PM   #104 (permalink)
Trader Rating: (99)
Sounds like a good setup Nemo, great idea on the first gear. Should make huge changes.
Old 03-06-2008, 07:48 PM   #105 (permalink)
stage3acr's Avatar
Member Number: 54644
i snaped mine comletely off i dont no why but i can guess its becuz i got 470ft-tq.. lol an it realllly sux to changed out to!!
Stage 3 Turbo, Stage 1 ECU, Apexi AFC, AGP stg3 Wastegate, MPX 3in Turbo Back Exhaust, Inovate Lc-1 Wideband , AGP Race Intercooler, AGP Fuel Return, 680cc injectors, Meth Injection w/ MP-5 Meth, Cluch Master w/Aluminum Flywheel, Raptor BOV, BC type BR Coilovers.
370whp/410wtq @ 23psi pump gas
411whp/470wtq @ 27psi pump gas
stage3acr is offline   Reply With Quote
