View Poll Results: What is your car's build date?(for those who have broken the trans. input shaft)
Pre-03 9 9.89%
Jan. - Apr. of 2003 5 5.49%
May - Aug. of 2003 8 8.79%
Sept. - Dec. of 2003 10 10.99%
Jan. - Apr. of 2004 11 12.09%
May - Aug. of 2004 13 14.29%
Sept. - Dec. of 2004 7 7.69%
Jan. - Apr. of 2005 9 9.89%
May - Aug. of 2005 12 13.19%
Sept. - Dec. of 2005 7 7.69%
Voters: 91. You may not vote on this poll
Old 05-15-2006, 12:25 PM   #31 (permalink)
nlschele1's Avatar
Member Number: 35128
Quote: Originally Posted by Masssilversrt4
Quote: Originally Posted by nlschele1
noob question here, what happens when the input shaft breaks? How do you know its broken? What are the symptoms?Thanks
Car doesn't move.
Thanks
nlschele1 is offline   Reply With Quote
Old 05-16-2006, 09:34 PM   #32 (permalink)
Member Number: 9728
anyone broken a cryoed shaft?
EBlue 04 w/sunroof as of 5/19/04
IcoolerthnU is offline   Reply With Quote
Old 07-19-2006, 08:56 AM   #33 (permalink)
Member Number: 43975
what are the symptons, and is this the same thing as a 'input bearing' ?
LIsrt478 is offline   Reply With Quote
Old 08-17-2006, 09:19 AM   #34 (permalink)
Member Number: 12302
I dont think cryro treating the input shaft is going to be a good idea. We looked into ion nitrating the shaft to harden it up, but like cryro treating it, it just makes the outside of it harder. The problem is that the input shaft needs to have some flexability with all the torque forced on it and if it cant flex at all, it will break even worse. If anyone can disprove this please do as we are putting a new shaft in my trans soon. thanks all.
SpecJ is offline   Reply With Quote
Old 08-20-2006, 06:51 PM   #35 (permalink)
dymondboy2f's Avatar
Member Number: 1630
Trader Rating: (13)
Awesome thread. Think I broke mine, felt like the shift selector broke and took out that whole assembly and it was fine. Guess I'll be tearing the tranny apart.
When it comes to envy y'all is green.
Quote: Originally Posted by Ultimateone
Lucas you crack me up
2004 Neon Mods: 435whp. Pump gas, nukka.
Hot Sales, Free Coupons and more daily from PinchFist.com deals megasite!
2006 GTO-full Holden Conversion, bolt ons+suspension.
dymondboy2f is offline   Reply With Quote
Old 08-20-2006, 07:07 PM   #36 (permalink)
Ant
Ant's Avatar
Member Number: 2834
im having trouble getting the car into gear sometimes under normal driving, could that be a symptom?
AGP 50 Trim
Stage 1 AGP SCT FLASHED
NGK plugs gapped .35
HP Racing/ Magnaflow 3" turboback
ED Hard Pipes w/Greddy Type S BOV
Accel 300+ RED Spark wires
Spearco BIG FMIC
EMANAGE / E01 / LM1 / FPR / Deatchwerks 750cc
injen intake
180 themo
Clutchmasters Stage 3
Bwoody Traction Bars
PTp Check valve
Aerforce/AAronneon Interceptor Scan Gauge
Ant is offline   Reply With Quote
Old 08-24-2006, 10:05 PM   #37 (permalink)
No, thats most likely your syncro.
We are actually having a input shaft tested with the cyro treatment to see if this indeed with help things out. We are having the techs do several types of tests to see how we can really strenghten this bad boy up. Stay tuned...
Old 08-25-2006, 08:28 AM   #38 (permalink)
Ant
Ant's Avatar
Member Number: 2834
well how could it be synchro if I have the clutch pedal all the way down and still doesn't go into gear.....sometimes......meaning the engagment is almost to the floor, and the pedal is adjusted as high as it can be.
Old 08-30-2006, 12:58 PM   #39 (permalink)
TurboGLH's Avatar
Member Number: 9873
Cryo treating works by causing the molecules in the material to reallign, creating a stronger material, with a more uniform grain and a greater ability to shed heat. It also helps stress relieve the part. I does not however increase the hardness or brittleness of the treated part, it does cause the piece to be more uniformly hard however (ie the variation in material hardness is reduced) but little to no increase in actual hardness.
All this is assume that you have the part properly done by a company using a deep cryogenic treatment, with temps below -258F. A shallow treament using a temp higher than -258 (ie using dry ice) will not produce the results your looking for.
QW FMIC, 3" BDJ Dump, Fuel Return, WGA and Map Clamp.
284whp/358wtq - uncorrected
Member - New England Shelby Dodge Auto Club
TurboGLH is offline   Reply With Quote
Old 08-30-2006, 07:58 PM   #40 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (552)
Ding, correct answer. Dont forget about the 24 hour cool down, that is what really makes the treatment set into the material.
Old 08-30-2006, 08:13 PM   #41 (permalink)
Chad's Avatar
Member Number: 3156
As I cannot "disprove" anything, I had my input shaft cryo treated. Have been beating up on it for over 1 year now with S3 and some bolt on-ons. 1.7x second 60' times and putting in a Spec clutch next weekend. Can't seem to find a decent clutch for the street and to run with slicks at the track. Clutch Masters doesn't seem to like the slicks, but wonderful on street tires...
S2 '04 SRT: S3 Very first pass
100 octane.... 93 octane
60' 1.807 60' 1.8109
330' 5.361 330' 5.2076
1/8 8.278 1/8 7.9927
MPH 84.76 MPH 87.70
Chad is offline   Reply With Quote
Old 09-02-2006, 01:40 AM   #42 (permalink)
SRToc Member
stunuts04's Avatar
Member Number: 20511
looks like I am going to try the cryo treating club with the input shaft, I think I just broke mine tonight.
SRTOC #740 2007 One Lap Media Noob
stunuts04 is offline   Reply With Quote
Old 09-18-2006, 04:29 PM   #43 (permalink)
vegasDSM's Avatar
Member Number: 726
my input shaft basically disintegrated...
at 48k miles.. same with the shift selector (this will be my second)
dealer is replacing all shift forks, selector, and input shaft (as well as some rods/connectors..)
i bought my srt in 4/2003, so im thinkin my build date was before that ;-)
F this forum and it's bullshit ads......ekool has jumped the shark
www.myspace.com/vegasdsmr<--vids....................
http://www.WebPeople.us
http://www.WebPeopleVideos.com
vegasDSM is offline   Reply With Quote
Old 09-22-2006, 09:12 AM   #44 (permalink)
chuck's_srt-4's Avatar
Member Number: 12569
Wow, this poll is turning into what looks like a transmission graveyard...LOL
Anyway, it seems that it's fairly even across the board, indicating that there never really was a particular "bad" batch of input shafts made, but rather that some/many input shafts are prone to the same problem, regardless of what batch they were in.
Good info. for everyone here. I'm also glad that I'm not the only one breaking them...LOL
2004 Solar Yellow SRT-4 - AEM EMS - AMS37R Turbo Kit - Custom fuel system - JMCylinderhead/Crower S2 cams - Stock bottom end...for now, anyway!
Best E.T. to date: 11.24
Best MPH to date: 129.77 MPH
chuck's_srt-4 is online now   Reply With Quote
Old 09-29-2006, 04:39 PM   #45 (permalink)
Have you broken any more?
