View Poll Results: What is your car's build date?(for those who have broken the trans. input shaft)
Pre-03 9 10.11%
Jan. - Apr. of 2003 5 5.62%
May - Aug. of 2003 7 7.87%
Sept. - Dec. of 2003 10 11.24%
Jan. - Apr. of 2004 11 12.36%
May - Aug. of 2004 13 14.61%
Sept. - Dec. of 2004 7 7.87%
Jan. - Apr. of 2005 8 8.99%
May - Aug. of 2005 12 13.48%
Sept. - Dec. of 2005 7 7.87%
Voters: 89. You may not vote on this poll
Old 10-05-2005, 08:17 AM   #1 (permalink)
chuck's_srt-4's Avatar
Member Number: 12569
Default ***POLL***Broken input shaft***POLL***
I have seen very few people that have broken an input shaft, but of the very few, all have been cars that have a build date of approximately August to december of 03. But that's only about 4 cars I know of so far.
I am trying to get a compilation of all people on the forums who have broken an input shaft to see if there may have been a time period in which the shafts could have been weaker for one reason or another.
I just got through breaking my input shaft doing a WOT shift from 2-3 gear. Now I am scared to ever shift like that again, but if enough info. comes back indicating that the later 03 srt-4's are more prone to this problem than the other time frames, then my worries as well as many other people's worries may decrease as to whether we should worry about this problem.
The more info. the better. If you have a friend that owns an SRT-4 and has broken their input shaft, but doesn't frequent the forums, see if you can get the build date of his/her car and post it up for all to see.
Edit: Also, if you have mods on your car, post them somewhere in the thread so that we can get an idea of about what power levels are breaking the shafts. Post miles on your car when the shaft broke as well.
2004 Solar Yellow SRT-4 - AEM EMS - AMS37R Turbo Kit - Custom fuel system - JMCylinderhead/Crower S2 cams - Stock bottom end...for now, anyway!
609 WHP, 518 WTQ @ 28 PSI!
Best E.T. to date: 11.24
Best MPH to date: 129.77 MPH
Old 10-05-2005, 08:29 AM   #2 (permalink)
I'll start. I have S3R with an aluminum flywheel and a CM S4 6-puck clutch. My car had 18,500 miles on it when it broke. I was WOT shifting from 2-3 gear without HOM on. So power levels should be around the 320-330 hp levels. I think that info should pretty much cover it.
Old 10-05-2005, 05:59 PM   #3 (permalink)
bump for evening/night crew!
Old 10-07-2005, 11:25 AM   #4 (permalink)
Now I know the saying usually goes, "No news is good news!" But I know there are at least a few more people out there that have broken an Input shaft. I Need INPUT!
Old 10-12-2005, 07:06 PM   #5 (permalink)
Super Moderator
Masssilversrt4's Avatar
Member Number: 3905
Kiiburn NO WOT when it broke normal shifting. Early 04/late 03 build. had 03 axles..
40k miles cm stage 4 clutch and gt35turbo. 350hp/ft/lbs
Hell bent on building fast cars!!!
Masssilversrt4 is offline   Reply With Quote
Old 10-17-2005, 08:26 PM   #6 (permalink)
SRT-URBO's Avatar
Member Number: 24497
Trader Rating: (27)
I broke mine twice same 2nd to 3rd gear shift, first one was under warranty, 2nd just happened so i'm thinking of fighting it, No wonder that part is on national back order, everyone is breaking them. I have heard of many more people braking them, just make a post on the buy/sell forum and you'll see.
I have a BDJS dump and MBC set to spike at 16.5psi drop to 14.5-15psi, open air lid...
We should just get together and sue DCX!!!
SRT-URBO is offline   Reply With Quote
Old 10-24-2005, 07:42 AM   #7 (permalink)
Member Number: 10026
broken input shaft here!!!! wot from 2nd to 3rd,,,stage 3 with street tires,,stage 4 clutch masters clutch,,,,im not sure of the make date but i bout in feb of 04,,,so im guessing i falls in that late 03 time frame
I REFUSE TO LOSE!
ROCKY_7_11 is offline   Reply With Quote
Old 10-29-2005, 08:05 PM   #8 (permalink)
well, this isn't looking too promising. Seems as though it is spread out pretty evenly between years and months
Now as for three of us that have posted what our mods are, it looks like we all have the S4 clutchmasters clutch. I am wondering if the clutch is just a little bit too grippy and thus applying a nasty shock to the input shaft, resulting in shearing it off. Now what we need is a list of mods from the other people that have broken their input shaft that states what clutch they are using!!!
Old 10-29-2005, 08:29 PM   #9 (permalink)
Member Number: 6333
Well I know of an early 04 that broke. CM stage 4 and stage 3 also. He has recently traded in the car. I guess he might have not seen this topic yet.
03 Neon srt-4 Stage 3 w/toys
05 Neon srt-4 Stage 3 w/toys ++++
08 Caliber srt-4 Stock
srtworkcar is offline   Reply With Quote
Old 11-02-2005, 09:47 PM   #10 (permalink)
SLCFast4's Avatar
Member Number: 12831
Hey Chuck.. I think if we can eliminate the broken Input shafts and the screwed up slider rings and syncros then we might be able to come up with a winning combo. I say gears and a more durable main shaft.
I HAVE THE CHUCK MOD, AUTHORIZED BY THE CARE BEARS, WITH DETAILED INFO BY RAINBOW BRITE!!!!!!!!
Race Deck Racing
B-Spec USA
The SRT-4 is a painful, sometimes expensive, and pleasurable journey... a legal drug.
SLCFast4 is offline   Reply With Quote
Old 11-02-2005, 10:02 PM   #11 (permalink)
Member Number: 5426
quick? anyone know how much a replacement costs if its not warrantied?
Life is an experiece, live it to its fullest!
SRT4chicago is offline   Reply With Quote
Old 11-02-2005, 10:05 PM   #12 (permalink)
yellowRS's Avatar
Member Number: 4817
I broke 2. One in my 03 tranny with 7k miles. Then replaced that with a 04 tranny with about 10k miles, and broke that one also.
yellowRS is offline   Reply With Quote
Old 11-04-2005, 03:43 PM   #13 (permalink)
babykat's Avatar
Member Number: 20440
A new input shaft is about $385 plus labor. I don't know if you guys have noticed but the T-850 input shaft has no real support. I think it should have some sort of support bearing somewhere after the throw out bearing and before the 1st cluster gear to absorb some vibration. just a thought.
babykat is offline   Reply With Quote
Old 11-06-2005, 03:33 PM   #14 (permalink)
SLCFast4's Avatar
That was a great suggestion..
Old 12-21-2005, 06:02 PM   #15 (permalink)
SLCFast4's Avatar
Here is an up close and personal look at a busted input shaft..
You would think they could use a little better material.
