Old 11-18-2008, 01:10 PM   #61 (permalink)
Mana4real's Avatar
Member Number: 25021
I sell the ACT setups for cheaper
-Matt- -SCT Tuned- By Yours Truely
Old 11-18-2008, 01:15 PM   #62 (permalink)
aaronneon@RealTune's Avatar
Member Number: 623
Trader Rating: (431)
Im betting if you paid to advertise than you wouldnt
www.Realtuned.com
Each car built/tuned/track prepped in house
{11.62@128 Realtune Caliber}{11.85@119 Whoosh@Realtune Caliber}
Home of the Worlds Quickest/Fastest CSRT-4, Manual NSRT4, and Stock turbo SRT4
Old 11-18-2008, 01:19 PM   #63 (permalink)
Member Number: 623
Quote: Originally Posted by 401tuner View Post
I just ordered the ACT 6 puck non-mod set up and PTP's cyro treated TOB fork. Little bit easier on the pocket than the SBC and CM.
EDIT: also picked up a pivot ball from S&P as well
I will wait for your PM in 6 months. Im already writing my reply and storing it.. It will say, I told you so . Hmm I wonder if we can get automated PM responses added to this site
Anyhow, yea ACT is a much cheaper clutch setup. Hopefully you will have luck with it
Old 11-18-2008, 01:32 PM   #64 (permalink)
401tuner's Avatar
Member Number: 61799
The only reason i went with it Aaron is because i dont plan on tracking the car that much. Season is pretty much almost over now, and by the time i get the clutch and turbo set up in, i wont be heading to the track untill next season. Car is my daily driver and yes i do drive it hard sometimes, but im not going to be at the track every other weekend running slicks. I just dident have the extra $1000 to spend on the clutch and ive talked to many people with the ACT 6 puck non-mod set up and they all seem to have no problems. I just needed something better than stock that would be able to hold the hp/tq levels that ill be at with the new set up. I do appreaciate all of your help with everything though. Deffenitly one of the most helpful guys in my opinion on the board.
401tuner is offline   Reply With Quote
Old 11-18-2008, 01:34 PM   #65 (permalink)
Member Number: 39550
Trader Rating: (30)
some guys like to learn the hard way aaron, he'll be back lol
Realtune built 2.6 DCR stroker
DCR Pro-series Head, Intake, PT76 Turbo kit
DCR full race auto trans
Realtune full race custom fuel system
Realtune race ignition
AEM EMS
Built and tuned by Realtune
9.98@144mph Canada's FIRST 10 and 9 second srt4
squishy332000 is offline   Reply With Quote
Old 11-18-2008, 01:35 PM   #66 (permalink)
Member Number: 623
I totally understand. I just feel pretty solid that you will not be happy with your choice in the long run. For now, the extra savings is a good thing.
Old 11-18-2008, 05:01 PM   #67 (permalink)
BoostinAMopar's Avatar
Member Number: 55767
Quote: Originally Posted by squishy332000 View Post
turboneonstore, lol you should be happy if they even send you the clutch, lol, let alone this weekend. you should research before you buy stuff rom some of these places, cause if you would have reasd the reviews about turbo neon store, you would see that a lot of guys have been screwed by them
Its been sent out I got the shipping number and everything today when I was at work so
BoostinAMopar is offline   Reply With Quote
Old 11-18-2008, 05:06 PM   #68 (permalink)
Quote: Originally Posted by 1fast4 View Post
good luck with the install. and make sure that the flywheel bolts are torqued down. double check them and then check again. also make sure that when you put them back in that you put enough sealer or thread locker to surround the bolt or you will get oil seeping past them because the holes for the bolts are through holes into the crankcase.
Word thanks for the info. I have the how to for both tranny and act clutch install. And at work I printed out everything from All data just as a back up. I got a 100 plus page book And use the red thread locker is what is said in the act how to.... Im going to go with the torque specs that are listed in that, plus what is listed the shit I got from all data has every spec for every bolt that deals with removal and install of the trans.
Im kinda excited and worried at the same time.
Old 11-18-2008, 05:28 PM   #69 (permalink)
Mana4real's Avatar
I don't advertise on here. I work for a speed shop and just hook up anyone that needs something. I am not on here to make money, this is my personal account. But if someone wants something, I will take care of em.
Old 11-19-2008, 08:20 AM   #70 (permalink)
Member Number: 63342
how long of a run? i've had my ACT sprung 6 puck on for about 2 months now and it is still holding stong. no signs of slipping at all.
E1 turbo, PTP pnp e-mani, FM wga, 3" O2, 3" DP, 2.5 DP back exhaust, full 2.5" IC piping, Boomba BOV w/13psi spring, AEM SRI, NGK plugs, MSD 8.5mm wires, AEM uego WB, Spearco DFFMIC, race motor mount inserts, ACT 6 puck, Maddog 80% sts;
best dyno 307whp/301wtq @ 19psi
13.676 @ 106 on 20spike, 16-17 redline.stocker
13.45 @ 103 ~18psi spike, 16 hold. pcm boost/stock WG
E1 at ~23psi 13.43 @ 111.65 w/non pcm boost(can't launch/no driver mod ftl)
1fast4 is offline   Reply With Quote
Old 11-19-2008, 09:55 AM   #71 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (29)
1fast do you run slicks at the track? If not, you should be just fine dude.
Old 11-19-2008, 10:01 AM   #72 (permalink)
^no slicks yet. i might run DRs next season but i might change my mind and run slicks. i really need something to help me get the power to the ground in first and second. even with good track prep i roast 1st and 2nd and chirp 3rd. all depends on if the wifey will let me get the rims and either set of tires to run them. otherwise i will just be running on slicks still.
what effect will slicks or DRs have on the ACT 6 puck?
Old 11-19-2008, 10:06 AM   #73 (permalink)
Philth's Avatar
Trader Rating: (29)
More traction = more of a load on the clutch. No spinning tires...or less spinning tires. I say its all hit and miss man, honestly. There are people that swear by all three brands for their own individual reasons.
Old 11-19-2008, 10:11 AM   #74 (permalink)
tusamni's Avatar
Member Number: 35294
Trader Rating: (32)
Exactly.
tusamni is online now   Reply With Quote
Old 11-19-2008, 12:26 PM   #75 (permalink)
i understand about the whole, more traction = more load; which means more torque per say, but if i am only making 430wtq on a clutch that is rated for 607, would using slicks going to make that big of a difference to make the clutch go bad? or am i getting my logic mixed up? not trying to be difficult, just trying to figure things out.
Page generated in 0.21798 seconds with 13 queries
