Old 11-13-2008, 07:38 PM   #31 (permalink)
Mana4real's Avatar
Member Number: 25021
Quote: Originally Posted by squishy332000 View Post
theres nothing wrong with the mod clutch unless your making lots of hp, its fine for stage 3
Never said there was anything wrong with it. But if you can buy a clutch for cheaper and it works great with a lighter flywheel, why not do it? Lighter rotating assembly is FTW!!
-Matt- -SCT Tuned- By Yours Truely
Old 11-13-2008, 07:55 PM   #32 (permalink)
NeonDan's Avatar
Member Number: 138
Trader Rating: (82)
act 6puck sprung....
Old 11-14-2008, 07:45 PM   #33 (permalink)
Double J's Avatar
Member Number: 25570
I got the ACT streetdisc. So far I like it. It's holding great on the stage 3 delta. Feels pretty close to stock. Just the clutch peddle is a little more firm. You should be ok with one of these. Seeing how you don't plan on using slicks.
AGP S3D /40 lb. wheel- Mopar Stage 3 W/Toys- Maxxfab 3" TBE w/out cat- Mopar STS- Exhaust Depot ic pipes w/ HKS ssq bov- AGP CAI - MSD wires-MM Inserts- PTP Check Valve- PTP 55mm TB- CCA FMIC- Slowboy crashbar- Megan Racing CO's- Hotchkis Swaybars- ACT Clutch/Flywheel
Double J is offline   Reply With Quote
Old 11-14-2008, 07:50 PM   #34 (permalink)
bpsrt4's Avatar
Member Number: 40796
Trader Rating: (29)
I got my sbc stg 3 w/ flywheel for $500
I have never been a fan of pucked clutches...but that's just me
bpsrt4 is offline   Reply With Quote
Old 11-16-2008, 02:08 PM   #35 (permalink)
BoostinAMopar's Avatar
Member Number: 55767
So your saying if your going to use slicks dont use this disc?? Im going with a Delta 44lb kit w/ supporting mods. and was looking at the clutch & disc your using?? 99% of the time Ill be on street but I know a friend with slicks so I might do a few run with slicks. Clutch wont hold or ill be fine with this??Did yours come with a TOB also??
BoostinAMopar is offline   Reply With Quote
Old 11-16-2008, 02:23 PM   #36 (permalink)
Mana4real's Avatar
Comes with the TOB... It's a complete kit part number DN4HDSS and that's Street disc with the flywheel. I have the same setup. I don't see why you can't run slicks with the setup. Just break it in correctly and make sure your torque output doesn't exceed what it's rated for (470 tq). A street disc setup will last longer then a 6 puck will. The 6 pucks eat through the flywheels and the pressure plates quickly.
Old 11-16-2008, 02:25 PM   #37 (permalink)
aaronneon@RealTune's Avatar
Member Number: 623
Trader Rating: (431)
I dont recommend the standard stage 3 non-modular.
I recommend the Race Series stage 3 non-modular. MUCH better pressure plate and steel flywheel. The weight is about the same as a modular unit.
The pressure plate used in the Stage 3RS is not the same pressure plate used by ACT or CM.
I would honestly stay away from modular clutches unless you dont do a lot of racing. They will hold the power, but its the crappy stock flywheel and flexplate that you have to worry about
www.Realtuned.com
Each car built/tuned/track prepped in house
{11.62@128 Realtune Caliber}{11.85@119 Whoosh@Realtune Caliber}
Home of the Worlds Quickest/Fastest CSRT-4, Manual NSRT4, and Stock turbo SRT4
Old 11-16-2008, 03:05 PM   #38 (permalink)
401tuner's Avatar
Member Number: 61799
Wanna PM me where the hell you got it for that price lol?
401tuner is offline   Reply With Quote
Old 11-16-2008, 04:46 PM   #39 (permalink)
Member Number: 623
PM Me 2!
Thats hundreds less than SBC vendors get them for
Old 11-16-2008, 05:04 PM   #40 (permalink)
c2k
c2k's Avatar
Member Number: 2639
Trader Rating: (65)
like 28
that would explain why my turbo failed prematurely.
that s okay, new iconel it goes!
http://www.SRTCanada.com <----- alternate site for canadians.
DiabloSport Trinity Beta Tester
Quote: Originally Posted by DODGETWEAKER
Boost is like crack and I am your dealer. Come here lil' junkie and take your medicine.
Dodgetweaker is a part of the SRT Engineering team
c2k is offline   Reply With Quote
Old 11-16-2008, 05:14 PM   #41 (permalink)
Fischy's Avatar
Member Number: 20133
Trader Rating: (13)
Default ACT Street Clutch
(To the OP; ACT doesn't sell an aluminum flywheel)
Dirk (at ACT) is real proud of the fact that his new 11 pound SRT-4 flywheels won't fracture with heat. It's made from high carbon steel, not cast iron like some others. I'm using their street clutch and love the feel.
I machined almost another 2 pounds of weight just inboard of the starter gear. Yes, it was rebalanced at ACT after machining.
Steve
Stage 3, Everything Ported.
Fischy is offline   Reply With Quote
Old 11-16-2008, 06:48 PM   #42 (permalink)
401tuner's Avatar
So you think the street clutch will be enough for my power goals? Or should i just go with there 6 puck? Im not to sure what the big difference is between the two? Im leaning towards the ACT because it is much more affordable, and i dont plan on beating the shit out of it so i think it should be sufficient.
Old 11-16-2008, 07:04 PM   #43 (permalink)
Fischy's Avatar
Trader Rating: (13)
I'm like you, this is my daily driver so, no slicks or wild slipping of the clutch. It would even be fine in a freeway traffic jam. But, no problem leaving rubber all over the road when wanted.
My mods roughly, big valve ported head, ported stg3 turbo/manifold/intake mani./ 2.0 cams/gears, all air flow restrictions removed, TB/ 3"O2/ Thermal with cat, ACT clutch etc.
Steve
Old 11-17-2008, 12:01 PM   #44 (permalink)
bpsrt4's Avatar
Trader Rating: (29)
I bought it from a member on here...brand new in the box
Old 11-17-2008, 12:05 PM   #45 (permalink)
mole''s Avatar
Member Number: 17477
Trader Rating: (204)
Quote: Originally Posted by mole' View Post
i have seen alot of locals go tho the CM S4 like crazy. i just put the one that was in my ACR (stock ported turbo) and it was gone in less than 10k. i have the PTP/SBC Stage 3 with flywheel on my 04 S3 car, GREAT CLUTCH. i have never used the ACT yet, but hear good things about it.
#1 SBC Stage 3
#2 ACT setup
#3 CM S4
i picked up another SRT last month. the clutch went out. it was the CM S4. it fell apart....................
car has Stage 2 with toys, intake, exhaust, ITM/TB, FMIC, ported stock turbo and a SAFC
only 10k on the clutch/flywheel
-1 for CM
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4 DSP or Trinity
For SoCal guys only! Now offering JD-M Specials!
Page generated in 0.19915 seconds with 13 queries
