I always recommend ACT 6 puck to locals. Although the SB clutches seem to have several good reviews with there redesigned setup.
x2 on the act 6 puck, works great for me
Project Spoolnup: First BIG turbo on ds pcm boost
420whp/445tq ON A MUSTANG DYNO making the switch to the corn side....e85 ftw Tuned byTURBO666/TDSAARON 7.15 @ 106mph 11.56 @ 122mph
i have the Act sprung 6 puck and it is the shit. haven't had a problem with the clutch itself yet. grabs like a MF'er. even when i messed up and didn't seal the fw bolts all the way around and oil leaked past them, the clutch still gripped to all get out. problem is fixed now and it is great. i say go with the Act because the clutch feel isn't too bad over stock and you know it will hold the power. plus if you aren't going to be on the edge of its capacity, it will last a lot longer than you think it would.
E1 turbo, PTP pnp e-mani, FM wga, 3" O2, 3" DP, 2.5 DP back exhaust, full 2.5" IC piping, Boomba BOV w/13psi spring, AEM SRI, NGK plugs, MSD 8.5mm wires, AEM uego WB, Spearco DFFMIC, race motor mount inserts, ACT 6 puck, Maddog 80% sts;
best dyno 307whp/301wtq @ 19psi
13.676 @ 106 on 20spike, 16-17 redline.stocker
13.45 @ 103 ~18psi spike, 16 hold. pcm boost/stock WG E1 at ~23psi 13.43 @ 111.65 w/non pcm boost(can't launch/no driver mod ftl)
im assuming you talked to aaron, so i would say do what he tells you, he wouldnt steer you the wrong way, and if you wanted to save a few bucks, i have the south bend stage 5x, i had a stage 44lb setup, made 429whp and over 450trq. i went auto so have no need for it, it has about 2000 mile son it, installed and uninstalled by realtune
Realtune built 2.6 DCR stroker
DCR Pro-series Head, Intake, PT76 Turbo kit
DCR full race auto trans
Realtune full race custom fuel system
Realtune race ignition
AEM EMS
Built and tuned by Realtune
9.98@144mph Canada's FIRST 10 and 9 second srt4
I talked to aaron and he suggested the SBC S3 at first.. its going to be my daily driver but can deal with most things. Is the S5 a 6 puck or somehitng? I know i read on ptp's website it said "race only" but who knows. And this is a non mod set up your tlaking about correct?
I just sold an ACT street disc setup with flywheel non modular to someone on here (don't know if he wants his name mentioned) for $550 plus shipping. He had to pay tax because he is in California though.
