Old 04-21-2009, 12:10 PM   #1 (permalink)
D-ROK's Avatar
Member Number: 50159
Default Bearings and snap rings.
Anyone have a list of all the snap rings and bearings needed when replacing the input shaft?
TIA
D-ROK is offline   Reply With Quote
Old 04-21-2009, 12:20 PM   #2 (permalink)
D-ROK's Avatar
Is this all of them?
5102728AA Snap Ring
5013411AA shaft bearing (x2)
4762606 reteainer (x2)
5102726AA Ring
5114145AA Ring
5127737AA Ring
5102728AA Snap Ring
J8134488 Snap Ring (x2)
5069148AA Ring $1.95 ea (x2)
5069118AA int. shaft bearing (needle)
Old 04-21-2009, 12:32 PM   #3 (permalink)
supermech21's Avatar
Member Number: 42969
Trader Rating: (72)
Im a little late, here ya go.
Forks/Rails:
5/R Fork(05166421aa)…102.75
¾ Rail(05166422aa)… 37.16
5th/ Rev link(05010083aa)…1.43
Input shaft:
Nut, gear retaining(input)(05069168aa)…41.93
Thrust washer(05069158aa)…35
3rd Gear(05134146aa)…144
3rd/4th Synchro(05134147aa)…213
4th Gear(05134148aa)…145
Intermediate Shaft:
Race(05069101aa)…
Ring(05069148aa)…2
Bearing, Int shaft(05069118aa)…
Ring(05127737aa)…2
Ring(05114145aa)…3.34
Ring(05102726aa)…2
Needle Bearing(05069154aa)…
Thrust washer(05072203aa)…
Bearing(05013634aa)…
Snap ring(j8134488)…2.36
Old 04-21-2009, 12:35 PM   #4 (permalink)
thepowertowin's Avatar
Member Number: 13897
Trader Rating: (681)
here is the stuff i have listed for the input shaft and availability (to me)
5069158AA thrust washer 37.41 (3-4 days for me to get) No dealers close to you have them either.
5102728AA snap ring 1.89 (3-4 days for me to get) No dealers close to you have them either.
5134150AA 4th gear bearing 4.09 (1 day to get) No dealers close to you have them either.
5134141AA 5th gear bearing 4.97 (3-4 days for me to get) No dealers close to you have them either.
5069168AA gear retaining nut 41.18 (1 day to get) No dealers close to you have them either.
5013411AA input shaft bearing 42.88 No dealers close to you have them either.
J8134488 snap ring 2.32 (1 day to get) No dealers close to you have them either.
That's pretty much everything listed w/ the input shaft.
thepowertowin is offline   Reply With Quote
Old 04-21-2009, 12:49 PM   #5 (permalink)
D-ROK's Avatar
So is that what I should replace with my new input shaft? Sorry I just need to be sure.
Thanks guys.
Old 04-21-2009, 12:56 PM   #6 (permalink)
idon't knwo what's bad, but other than the gears, that's all the little hardware that is listed ON the shaft. someone who has actually replaced a few should chime in
Old 04-21-2009, 01:23 PM   #7 (permalink)
D-ROK's Avatar
I dunno either. I was just told I should replace all the bearings and snap rings
Old 04-21-2009, 04:46 PM   #8 (permalink)
boots's Avatar
Member Number: 67116
It's up to you, I say most of the time the needle bearings don't need replaced but there only $3 a piece. Your supposed to replace the snap rings and the input shaft nut everything.
2004 stage 2-AEM ems-DCR intake manifold-crane 16's(stock valve train)-act clutch-dss axles-boomba fuel rail-boomba mounts-boomba throtle body-3in side exit exhaust- maddog 58 STS-built trans( Rage accelerator, Rage 3/4 fork, and p-werks selector)- GT3076R
Soon to come, my high compression build New turbo setup and transmission setup
boots is offline   Reply With Quote
Page generated in 0.22398 seconds with 13 queries
